Writing a Testbench
Writing a unit test or system level test is easy with the Vivado makefile infrastructure! Most of the overhead of building and running a testbench is handled by the build tools. Even recurring tasks like reporting and monitoring are implemented by framework libraries.
Each executable FPGA unit test must have the following components:
  1. A Makefile
  2. A Testbench top-level module
Testbench Makefile
The Testbench Makefile tell the build tools what to build, where to build it, dependency information and runtime information. The build infrastructure will handle the how-to part for each supported simulation tool.
Here is a sample Makefile (you are encouraged to use this as a starting point)
# Copyright 2015 Ettus Research LLC
# Top-of-Makefile
# Define BASE_DIR to point to the "top" dir
BASE_DIR = $(abspath ../../..)
# Include viv_sim_preample after defining BASE_DIR
include $(BASE_DIR)/../tools/make/viv_sim_preamble.mak
# Design Specific
# Define part using PART_ID (<device>/<package>/<speedgrade>)
ARCH = kintex7
PART_ID = xc7k410t/ffg900/-2
# Include makefiles and sources for the DUT and its dependencies
include $(BASE_DIR)/../lib/fifo/Makefile.srcs
include $(BASE_DIR)/../lib/axi/Makefile.srcs
include $(BASE_DIR)/../lib/control/Makefile.srcs
DESIGN_SRCS = $(abspath \
$(FIFO_SRCS) \
$(AXI_SRCS) \
$(CONTROL_LIB_SRCS) \
# IP Specific
# If simulation contains IP, define the IP_DIR and point
# it to the base level IP directory
IP_DIR = ../../ip
# Include makefiles and sources for all IP components
# *after* defining the IP_DIR
include $(IP_DIR)/ddr3_32bit/Makefile.inc
include $(IP_DIR)/axi_intercon_2x64_128/Makefile.inc
include $(IP_DIR)/fifo_short_2clk/Makefile.inc
include $(IP_DIR)/fifo_4k_2clk/Makefile.inc
include $(IP_DIR)/axi4_bram_1kx64/Makefile.inc
DESIGN_SRCS += $(abspath \
$(IP_DDR3_32BIT_SRCS) \
$(IP_AXI_INTERCON_2X64_128_SRCS) \
$(IP_FIFO_4K_2CLK_SRCS) \
$(IP_FIFO_SHORT_2CLK_SRCS) \
$(IP_AXI4_BRAM_1KX64_SRCS) \
# Testbench Specific
include $(BASE_DIR)/../sim/general/Makefile.srcs
include $(BASE_DIR)/../sim/axi/Makefile.srcs
# Define only one toplevel module
SIM_TOP = dram_fifo_tb
# Simulation runtime in microseconds
SIM_RUNTIME_US = 80
SIM_SRCS = \
$(abspath dram_fifo_tb.sv) \
$(abspath axis_dram_fifo_single.sv) \
$(IP_DDR3_32BIT_SIM_OUTS) \
$(SIM_GENERAL_SRCS) \
$(SIM_AXI_SRCS)
# Bottom-of-Makefile
# Include all simulator specific makefiles here
# Each should define a unique target to simulate
# e.g. xsim, vsim, etc and a common "clean" target
include $(BASE_DIR)/../tools/make/viv_simulator.mak
You will notice that the Makefile has 5 distinct sections.
Section 1: Boilerplate
# Top-of-Makefile
Before declaring any variables or using any recipes, the following must be done (in order):
  • Define BASE_DIR to tell the build system where the <repo>/usrp3/top directory is relative to the current testbench directory.
  • Include viv_sim_preamble.mak to initialize boilerplate variables and functions
Section 2: Design Specific
# Design Specific
ARCH = kintex7
$(FIFO_SRCS) \
$(AXI_SRCS) \
This section contains pointers to sources and other variables for the DUT to function. In the example above, we are including all sources from the lib/fifo, lib/axi, lib/control directories.
The following makefile variables are special and must be defined:
  • ARCH: The architecture targeted for the simulation.
  • PART_ID: The exact part targeted for the simulation. Format: <device>/<package>/<speedgrade>
  • DESIGN_SRCS: Space-separated paths to the DUT and all of its dependencies.
Section 3: IP Specific
# IP Specific
IP_DIR = ../../ip
If the DUT depends on any Xilinx IP then this section is required. It tell the tools which IP cores need to be built in order to run the simulation. The IP specific Makefile includes handle the "how" part of building IP. As long as the correct Mafefile is included and the IP XCI sources are added to DESIGN_SRCS, the IP intermediates will be built correctly.
The IP_DIR variable must be defined to point to the base ip directory that contains XCI sources.
Section 4: Testbench Specific
SIM_RUNTIME_US = 80
SIM_SRCS = \
$(SIM_AXI_SRCS)
This section contains all sources and parameters for the actual testbench. Any simulation dependency makefiles can be included here.
The following variables must be defined:
  • SIM_TOP: The toplevel module name for the simulation project
  • SIM_RUNTIME_US: The maximum runtime of the simulation in microseconds. At this time $finish will be called to terminate the testbench.
  • SIM_SRCS: This is similar to DESIGN_SRCS except that that should contain a path to SIM_TOP and all of its dependencies.
Section 5: Tool Support
Now that the Makefile knows all the basic information about the testbench, include tool-specific makefiles to implement simulation targets. Currently the following simulator makefiles exits:
  • <repo>/tools/make/viv_simulator.mak
Please refer to the next section for more information about targets
Testbench Top Level
The top-level module will instantiate the DUT and implement self-checking behavior. Test benches could be written in any language (SystemVerilog, Verilog, VHDL) but to take advantage of our repository of simulation libraries, it is recommended that SystemVerilog be used.
Here is a sample SystemVerilog top module (you are encouraged to use this as a starting point)
// Copyright 2015 Ettus Research LLC
`timescale 1ns/1ps
`define NS_PER_TICK     1
`define NUM_TEST_CASES  3
`include "sim_clks_rsts.vh"
`include "sim_exec_report.vh"
`include "sim_cvita_lib.sv"
module example_fifo_tb();
  `TEST_BENCH_INIT("example_fifo_tb",`NUM_TEST_CASES,`NS_PER_TICK)
  // Define all clocks and resets
  `DEFINE_CLK(bus_clk, 1000/166.6667, 50) //166MHz bus_clk
  `DEFINE_RESET(bus_rst, 0, 100)          //100ns for GSR to deassert
  cvita_stream_t chdr_i (.clk(bus_clk));
  cvita_stream_t chdr_o (.clk(bus_clk));
  // Initialize DUT
  axi_fifo #(.WIDTH(65), .SIZE(24)) dut_single (
    .clk(bus_clk),
    .reset(bus_rst),
    .clear(1'b0),
    .i_tdata({chdr_i.axis.tlast, chdr_i.axis.tdata}),
    .i_tvalid(chdr_i.axis.tvalid),
    .i_tready(chdr_i.axis.tready),
    .o_tdata({chdr_o.axis.tlast, chdr_o.axis.tdata}),
    .o_tvalid(chdr_o.axis.tvalid),
    .o_tready(chdr_o.axis.tready),
    .space(),
    .occupied()
  //Testbench variables
  cvita_hdr_t   header, header_out;
  cvita_stats_t stats;
  //Main thread for testbench execution
  initial begin : tb_main
    `TEST_CASE_START("Wait for reset");
    while (bus_rst) @(posedge bus_clk);
    `TEST_CASE_DONE((~bus_rst));
    repeat (200) @(posedge bus_clk);
    header = '{
      pkt_type:DATA, has_time:0, eob:0, seqno:12'h666,
      length:0, sid:$random, timestamp:64'h0};
    `TEST_CASE_START("Fill up empty FIFO then drain (short packet)");
      chdr_o.axis.tready = 0;
      chdr_i.push_ramp_pkt(16, 64'd0, 64'h100, header);
      chdr_o.axis.tready = 1;
      chdr_o.wait_for_pkt_get_info(header_out, stats);
      `ASSERT_ERROR(stats.count==16,            "Bad packet: Length mismatch");
      `ASSERT_ERROR(header.sid==header_out.sid, "Bad packet: Wrong SID");
      `ASSERT_ERROR(chdr_i.axis.tready,         "Bus not ready");
    `TEST_CASE_DONE(1);
    header = '{
      pkt_type:DATA, has_time:1, eob:0, seqno:12'h666,
    `TEST_CASE_START("Concurrent read and write (single packet)");
      fork
          begin
            chdr_i.push_ramp_pkt(20, 64'd0, 64'h100, header);
          end
          begin
          end
      join
    `ASSERT_ERROR(stats.count==20,      "Bad packet: Length mismatch");
    `TEST_CASE_DONE(1);
  end
endmodule
Each testbench should have the following basic components:
Timescale Defines and Includes
`timescale 1ns/1ps
In addition to the timescale, the infrastructure needs to know the number of nanoseconds per simulator tick. This can be a floating point number.
In addition to the timescale, you may include any Verilog/SystemVerilog headers here.
Main Module Definition
  end
endmodule
The name of the main module must match the SIM_TOP variable value in the Makefile. To register this module with the framework, the TEST_BENCH_INIT macro must be called. This macro is defined in <repo>/usrp3/sim/general/sim_exec_report.vh.
TEST_BENCH_INIT:
// Initializes state for a test bench.
// This macro *must be* called within the testbench module but
// outside the primary initial block
// Its sets up boilerplate code for:
// - Logging to console
// - Test execution tracking
// - Gathering test results
// - Bounding execution time based on the SIM_RUNTIME_US vdef
// Usage: `TEST_BENCH_INIT(test_name,min_tc_run_count,ns_per_tick)
// where
//  - tb_name:          Name of the testbench. (Only used during reporting)
//  - min_tc_run_count: Number of test cases in testbench. (Used to detect stalls and inf-loops)
//  - ns_per_tick:      The time_unit_base from the timescale declaration
The testbench must also have at least one initial block that consists tests cases (covered later). For the sake of convention it should be called tb_main. All test cases must live in tb_main. You may have other initial block but they must not call macros from sim_exec_report.vh because the code there is not thread-safe.
Test Cases
A test case in this context is defined as an independent entity that validates an aspect of the DUT behavior and which is independent from other test cases i.e. the result of one test case should ideally not affect others.
Test cases are wrapped in the TEST_CASE_START and TEST_CASE_DONE macros:
`TEST_CASE_DONE(1);
Here are the signatures of the two macros:
TEST_CASE_START:
// Indicates the start of a test case
// This macro *must be* called inside the primary initial block
// Usage: `TEST_CASE_START(test_name)
// where
//  - test_name:        The name of the test.
TEST_CASE_DONE:
// Indicates the end of a test case
// The pass/fail status of test case is determined based on the
// the user specified outcome and the number of fatal or error
// ASSERTs triggered in the test case.
// Usage: `TEST_CASE_DONE(test_result)
// where
//  - test_result:  User specified outcome
In addition to the test case status, it is also possible to have asserts within a test case. We have wrappers for the different kinds of SystemVerilog asserts that additionally fail the test case in case the assert fails. An assert triggered in a test case will not affect the outcome of another (except for a fatal assert which halts the simulator). Supported assert macros:
// Wrapper around a an assert.
// ASSERT_FATAL throws an error assertion and halts the simulator
// if cond is not satisfied
// Usage: `ASSERT_FATAL(cond,msg)
// where
//  - cond: Condition for the assert
//  - msg:  Message for the assert
// ASSERT_ERROR throws an error assertion and fails the test case
// if cond is not satisfied. The simulator will *not* halt
// Usage: `ASSERT_ERROR(cond,msg)
// where
// ASSERT_WARNING throws an warning assertion but does not fail the
// test case if cond is not satisfied. The simulator will *not* halt
// Usage: `ASSERT_WARNING(cond,msg)
// where
Optional Libraries
It is encouraged to use (and create) reusable libraries in product specific test benches. Libraries can provide macros, modules, tasks and functions for ease-of-use with particular protocols and subsystems.
The Simulation Libraries page has more information.
