18 #ifndef INCLUDED_UHD_USRP_MULTI_USRP_HPP    19 #define INCLUDED_UHD_USRP_MULTI_USRP_HPP    22 #define UHD_USRP_MULTI_USRP_REF_SOURCES_API    23 #define UHD_USRP_MULTI_USRP_GET_RATES_API    24 #define UHD_USRP_MULTI_USRP_FRONTEND_CAL_API    25 #define UHD_USRP_MULTI_USRP_FRONTEND_IQ_AUTO_API    26 #define UHD_USRP_MULTI_USRP_COMMAND_TIME_API    27 #define UHD_USRP_MULTI_USRP_BW_RANGE_API    28 #define UHD_USRP_MULTI_USRP_USER_REGS_API    29 #define UHD_USRP_MULTI_USRP_GET_USRP_INFO_API    30 #define UHD_USRP_MULTI_USRP_NORMALIZED_GAIN    31 #define UHD_USRP_MULTI_USRP_GPIO_API    32 #define UHD_USRP_MULTI_USRP_REGISTER_API    33 #define UHD_USRP_MULTI_USRP_FILTER_API    46 #include <boost/shared_ptr.hpp>    47 #include <boost/utility.hpp>    52 namespace uhd{
namespace usrp{
   102     typedef boost::shared_ptr<multi_usrp>
sptr;
   107     static const size_t ALL_MBOARDS = size_t(~0);
   110     static const size_t ALL_CHANS = size_t(~0);
   172     virtual void set_master_clock_rate(
double rate,
size_t mboard = ALL_MBOARDS) = 0;
   179     virtual double get_master_clock_rate(
size_t mboard = 0) = 0;
   185     virtual std::string get_pp_string(
void) = 0;
   192     virtual std::string get_mboard_name(
   199     virtual time_spec_t get_time_now(
   206     virtual time_spec_t get_time_last_pps(
   219     virtual void set_time_now(
const time_spec_t &time_spec,
   233     virtual void set_time_next_pps(
   250     virtual void set_time_unknown_pps(
const time_spec_t &time_spec) = 0;
   258     virtual bool get_time_synchronized(
void) = 0;
   270     virtual void set_command_time(
const uhd::time_spec_t &time_spec,
   277     virtual void clear_command_time(
   291     virtual void issue_stream_cmd(
const stream_cmd_t &stream_cmd,
size_t chan = ALL_CHANS) = 0;
   301     virtual void set_clock_config(
const clock_config_t &clock_config,
   311     virtual void set_time_source(
const std::string &source,
const size_t mboard = ALL_MBOARDS) = 0;
   318     virtual std::string get_time_source(
const size_t mboard) = 0;
   325     virtual std::vector<std::string> get_time_sources(
   334     virtual void set_clock_source(
   341     virtual std::string get_clock_source(
   348     virtual std::vector<std::string> get_clock_sources(
   358     virtual void set_clock_source_out(
const bool enb,
   368     virtual void set_time_source_out(
const bool enb,
   373     virtual size_t get_num_mboards(
void) = 0;
   381     virtual sensor_value_t get_mboard_sensor(
const std::string &name,
   388     virtual std::vector<std::string> get_mboard_sensor_names(
   397     virtual void set_user_register(
const boost::uint8_t addr,
const boost::uint32_t data,
   424     virtual size_t get_rx_num_channels(
void) = 0;
   431     virtual std::string get_rx_subdev_name(
size_t chan = 0) = 0;
   438     virtual void set_rx_rate(
double rate,
   445     virtual double get_rx_rate(
   469     virtual double get_rx_freq(
   480     virtual freq_range_t get_rx_freq_range(
   487     virtual freq_range_t get_fe_rx_freq_range(
   496     virtual void set_rx_gain(
double gain,
   500         return this->set_rx_gain(gain, ALL_GAINS, chan);
   519     virtual void set_normalized_rx_gain(
double gain,
   529     virtual void set_rx_agc(
bool enable,
   538     virtual double get_rx_gain(
   542         return this->get_rx_gain(ALL_GAINS, chan);
   555     virtual double get_normalized_rx_gain(
   564     virtual gain_range_t get_rx_gain_range(
   568         return this->get_rx_gain_range(ALL_GAINS, chan);
   577     virtual std::vector<std::string> get_rx_gain_names(
   584     virtual void set_rx_antenna(
const std::string &ant,
   591     virtual std::string get_rx_antenna(
   598     virtual std::vector<std::string> get_rx_antennas(
   605     virtual void set_rx_bandwidth(
double bandwidth,
   612     virtual double get_rx_bandwidth(
   619     virtual meta_range_t get_rx_bandwidth_range(
   636     virtual sensor_value_t get_rx_sensor(
   643     virtual std::vector<std::string> get_rx_sensor_names(
   657     virtual void set_rx_dc_offset(
const bool enb,
   666     virtual void set_rx_dc_offset(
const std::complex<double> &offset,
   674     virtual void set_rx_iq_balance(
const bool enb,
size_t chan) = 0;
   683     virtual void set_rx_iq_balance(
const std::complex<double> &correction,
   710     virtual size_t get_tx_num_channels(
void) = 0;
   717     virtual std::string get_tx_subdev_name(
   724     virtual void set_tx_rate(
double rate,
   731     virtual double get_tx_rate(
   755     virtual double get_tx_freq(
   766     virtual freq_range_t get_tx_freq_range(
   773     virtual freq_range_t get_fe_tx_freq_range(
   782     virtual void set_tx_gain(
double gain,
   786         return this->set_tx_gain(gain, ALL_GAINS, chan);
   799     virtual void set_normalized_tx_gain(
double gain,
   808     virtual double get_tx_gain(
   812         return this->get_tx_gain(ALL_GAINS, chan);
   825     virtual double get_normalized_tx_gain(
   834     virtual gain_range_t get_tx_gain_range(
   838         return this->get_tx_gain_range(ALL_GAINS, chan);
   847     virtual std::vector<std::string> get_tx_gain_names(
   854     virtual void set_tx_antenna(
   861     virtual std::string get_tx_antenna(
   868     virtual std::vector<std::string> get_tx_antennas(
   875     virtual void set_tx_bandwidth(
double bandwidth,
   882     virtual double get_tx_bandwidth(
   889     virtual meta_range_t get_tx_bandwidth_range(
   906     virtual sensor_value_t get_tx_sensor(
   913     virtual std::vector<std::string> get_tx_sensor_names(
   921     virtual void set_tx_dc_offset(
   930     virtual void set_tx_iq_balance(
   941     virtual std::vector<std::string> get_gpio_banks(
   959     virtual void set_gpio_attr(
const std::string &bank,
const std::string &attr,
const boost::uint32_t value,
mask = 0xffffffff,
const size_t mboard = 0) = 0;
   977     virtual boost::uint32_t get_gpio_attr(
   993     virtual std::vector<std::string> enumerate_registers(
  1001     virtual register_info_t get_register_info(
const std::string &path,
  1010     virtual void write_register(
const boost::uint32_t field,
const boost::uint64_t value,
  1019     virtual boost::uint64_t read_register(
  1035     virtual std::vector<std::string> get_filter_names(
const std::string &search_mask =
"") = 0;
Definition: multi_usrp.hpp:567
Definition: stream_cmd.hpp:46
Definition: tune_result.hpp:29
Definition: multi_usrp.hpp:811
size_t mask(const soft_reg_field_t field)
Definition: soft_register.hpp:98
Definition: multi_usrp.hpp:785
Definition: time_spec.hpp:39
bool readable
Definition: multi_usrp.hpp:984
Definition: device.hpp:41
boost::shared_ptr< multi_usrp > sptr
Definition: multi_usrp.hpp:102
Definition: multi_usrp.hpp:982
Definition: multi_usrp.hpp:541
Definition: tune_request.hpp:33
Definition: stream.hpp:184
static const std::string ALL_GAINS
A wildcard gain element name.
Definition: multi_usrp.hpp:113
Definition: sensors.hpp:38
boost::shared_ptr< filter_info_base > sptr
Definition: filters.hpp:38
Definition: multi_usrp.hpp:100
Definition: stream.hpp:57
Definition: config.h:66
Definition: multi_usrp.hpp:499
bool writable
Definition: multi_usrp.hpp:985
size_t bitwidth
Definition: multi_usrp.hpp:983
Definition: stream.hpp:256
Definition: multi_usrp.hpp:837
