USRP Hardware Driver and USRP Manual  Version: 003.009.002-0-gf18abe54
Generation 3 USRP Build Documentation
Dependencies and Requirements
Dependencies
The USRP FPGA build system requires a UNIX-like environment with the following dependencies
Requirements
What FPGA does my USRP have?
  • USRP B200: Spartan 6 XC6SLX75
  • USRP B210: Spartan 6 XC6SLX150
  • USRP X300: Kintex 7 XC7K325T
  • USRP X310: Kintex 7 XC7K410T
  • USRP E310: Zynq-7000 XC7Z020
Build Instructions (Xilinx ISE only)
  • Download and install Xilinx ISE 14.7
    • You may need to acquire an implementation license to build some USRP designs. Please check the Xilinx Requirements document above for the FPGA technology used by your USRP device.
  • To add xtclsh to the PATH and to setup up the Xilinx build environment run
    • source <install_dir>/Xilinx/14.7/ISE_DS/settings64.sh (64-bit platform)
    • source <install_dir>/Xilinx/14.7/ISE_DS/settings32.sh (32-bit platform)
  • Navigate to usrp3/top/{project} where project is:
    • b200: For USRP B200 and USRP B210
  • To build a binary configuration bitstream run make <target> where the target is specific to each product. To get a list of supported targets run make help.
  • The build output will be specific to the product and will be located in the usrp3/top/{project}/build directory. Run make help for more information.
Build Instructions (Xilinx Vivado only)
  • Download and install Xilinx Vivado 2014.4 (Not 2014.4.1)
    • x300: For USRP X300 and USRP X310
    • e300: For USRP E310
  • To add vivado to the PATH and to setup up the Xilinx build environment run
    • source setupenv.sh (If Vivado is installed in the default path /opt/Xilinx/Vivado) OR
    • source setupenv.sh --vivado-path=<VIVADO_PATH> (where VIVADO_PATH is a non-default installation path)
B2x0 Targets and Outputs
Supported Targets
  • B200: Builds the USRP B200 design.
  • B210: Builds the USRP B210 design.
Outputs
  • build/usrp_<product>_fpga.bit : Configuration bitstream with header
  • build/usrp_<product>_fpga.bin : Configuration bitstream without header
  • build/usrp_<product>_fpga.syr : Xilinx system report
  • build/usrp_<product>_fpga.twr : Xilinx timing report
X3x0 Targets and Outputs
Supported Targets
  • X310_1G: USRP X310. 1GigE on both SFP+ ports. DRAM TX FIFO (experimental!).
  • X300_1G: USRP X300. 1GigE on both SFP+ ports. DRAM TX FIFO (experimental!).
  • X310_HG: USRP X310. 1GigE on SFP+ Port0, 10Gig on SFP+ Port1. DRAM TX FIFO (experimental!).
  • X300_HG: USRP X300. 1GigE on SFP+ Port0, 10Gig on SFP+ Port1. DRAM TX FIFO (experimental!).
  • X310_XG: USRP X310. 10GigE on both SFP+ ports. DRAM TX FIFO (experimental!).
  • X300_XG: USRP X300. 10GigE on both SFP+ ports. DRAM TX FIFO (experimental!).
  • X310_HGS: USRP X310. 1GigE on SFP+ Port0, 10Gig on SFP+ Port1. SRAM TX FIFO.
  • X300_HGS: USRP X300. 1GigE on SFP+ Port0, 10Gig on SFP+ Port1. SRAM TX FIFO.
  • X310_XGS: USRP X310. 10GigE on both SFP+ ports. SRAM TX FIFO.
  • X300_XGS: USRP X300. 10GigE on both SFP+ ports. SRAM TX FIFO.
Outputs
  • build/usrp_<product>_fpga_<image_type>.bit : Configuration bitstream with header
  • build/usrp_<product>_fpga_<image_type>.bin : Configuration bitstream without header
  • build/usrp_<product>_fpga_<image_type>.lvbitx : Configuration bitstream for PCIe (NI-RIO)
  • build/usrp_<product>_fpga_<image_type>.rpt : System, utilization and timing summary report
E310 Targets and Outputs
Supported Targets
  • E310: Builds the USRP E310 design.
Outputs
  • build/usrp_<product>_fpga.rpt : System, utilization and timing summary report
Additional Build Options
It is possible to make a target and specific additional options in the form VAR=VALUE in the command. For example: make B210 PROJECT_ONLY=1
Here are the supported options:
  • PROJECT_ONLY=1 : Only create a Xilinx project for the specified target(s). Useful for use with the ISE GUI. (NOTE: this option is only valid for Xilinx ISE)
  • EXPORT_ONLY=1 : Export build targets from a GUI build to the build directory. Requires the project in build-*_* to be built. (NOTE: this option is only valid for Xilinx ISE)
  • GUI=1 : Run the Vivado build in GUI mode instead of batch mode. After the build is complete, Vivado provides an option to save the fully configured project for customization (NOTE: this option is only valid for Xilinx Vivado)
