USRP Hardware Driver and USRP Manual  Version: 003.009.002-0-gf18abe54
Running a Testbench
Each executable testbench has its own Makefile that automatically pulls in support for all supported simulators. The build infrastructure supports the following simulators:
  • Xilinx Vivado (XSim)
  • Mentor Graphics ModelSim (may require an additional license)
In general running make <sim_target> will run the simulation and report results in the console. Running make help will print out all supported simulator targets. Currently, the following targets will work:
Supported Targets:
ipclean:    Cleanup all IP intermediate files
clean:      Cleanup all simulator intermediate files
cleanall:   Cleanup everything!
xsim:       Run the simulation using the Xilinx Vivado Simulator
xclean:     Cleanup Xilinx Vivado Simulator intermediate files
vsim:       Run the simulation using Modelsim
vclean:     Cleanup Modelsim intermediate files
Using Xilinx Vivado XSim
XSim is the built-in simulator in the Xilinx Vivado toolchain. If you already met the prerequisites for building an FPGA image, then you don't need to install anything else.
Follow these steps to run a testbench:
  • Navigate to the directory that contains the top level testbench and Makefile
  • Run the setenv.sh script for the USRP product that you are trying to simulate
    $ source <repo>/usrp3/top/<product>/setupenv.sh
    This step is required even if the simulation is generic because the toolchain requires an FPGA part number to load simulation models.
  • Run the simulator specific target
    $ make xsim
Using Mentor Graphics ModelSim
ModelSim is a third-party simulation tool that is compatible with Vivado and the USRP FPGA build infrastructure.
Use the following one-time setup to install and configure Modelsim on your system
  • Install Modelsim from the Mentor Graphics website. It is recommended that you install it to the default location (/opt/mentor/modelsim)
  • Build the Xilinx simulation libraries $ build_simlibs
To validate that everything was install properly run setupenv.sh again. You should see the following
Setting up X3x0 FPGA build environment (64-bit)...
- Vivado: Found (/opt/Xilinx/Vivado/2014.4/bin)
- Modelsim: Found (/opt/mentor/modelsim/modeltech/bin)
- Modelsim Compiled Libs: Found (/opt/Xilinx/Vivado/2014.4/modelsim)
Environment successfully initialized.
    $ make vsim
Troubleshooting
Vivado Not Found
If running the setupenv.sh script return an error like the following:
Vivado: Not found! (ERROR.. Builds and simulations will not work)
then it is possible that Vivado was not installed or it was not installed in the default location. If Vivado is installed in a non-default location, just run the following:
$ source <repo>/usrp3/top/<product>/setupenv.sh --vivado-path=<PATH>
Modelsim Not Found
- Modelsim: Not found! (WARNING.. Simulations with vsim will not work)
or something like this (even when Modelsim is installed)
then it is possible that Modelsim was not installed or it was not installed in the default location. If Modelsim is installed in a non-default location, just run the following:
$ source <repo>/usrp3/top/<product>/setupenv.sh --modelsim-path=<PATH>
Modelsim Simulation Libraries Not Found
- Modelsim Compiled Libs: Not found! (Run build_simlibs to generate them.)
$ build_simlibs
