USRP Hardware Driver and USRP Manual  Version: 003.009.002-0-gf18abe54
metadata.hpp
18 #ifndef INCLUDED_UHD_TYPES_METADATA_HPP
19 #define INCLUDED_UHD_TYPES_METADATA_HPP
24 #include <string>
25
26 namespace uhd{
27
34
37  {
38  reset();
39  }
40
42  void reset()
43  {
44  has_time_spec = false;
45  time_spec = time_spec_t(0.0);
46  more_fragments = false;
47  fragment_offset = 0;
48  start_of_burst = false;
49  end_of_burst = false;
50  error_code = ERROR_CODE_NONE;
51  out_of_sequence = false;
52  }
53
56
59
67
74
77
80
95  enum error_code_t {
97  ERROR_CODE_NONE = 0x0,
99  ERROR_CODE_TIMEOUT = 0x1,
101  ERROR_CODE_LATE_COMMAND = 0x2,
103  ERROR_CODE_BROKEN_CHAIN = 0x4,
112  ERROR_CODE_OVERFLOW = 0x8,
114  ERROR_CODE_ALIGNMENT = 0xc,
116  ERROR_CODE_BAD_PACKET = 0xf
117  } error_code;
118
121
128  std::string to_pp_string(bool compact=true) const;
129
134  std::string strerror(void) const;
135  };
136
149
152
155
158
163  tx_metadata_t(void);
164  };
165
171  size_t channel;
172
175
178
184  EVENT_CODE_BURST_ACK = 0x1,
186  EVENT_CODE_UNDERFLOW = 0x2,
188  EVENT_CODE_SEQ_ERROR = 0x4,
190  EVENT_CODE_TIME_ERROR = 0x8,
192  EVENT_CODE_UNDERFLOW_IN_PACKET = 0x10,
194  EVENT_CODE_SEQ_ERROR_IN_BURST = 0x20,
196  EVENT_CODE_USER_PAYLOAD = 0x40
197  } event_code;
198
202  boost::uint32_t user_payload[4];
203
204  };
205
206 } //namespace uhd
207
208 #endif /* INCLUDED_UHD_TYPES_METADATA_HPP */
time_spec_t time_spec
Time of the first sample.
Definition: metadata.hpp:58
bool end_of_burst
Definition: metadata.hpp:157
Definition: metadata.hpp:151
void reset()
Reset values.
Definition: metadata.hpp:42
Definition: time_spec.hpp:39
bool has_time_spec
Has time specification?
Definition: metadata.hpp:174
rx_metadata_t()
Default constructor.
Definition: metadata.hpp:36
size_t fragment_offset
Definition: metadata.hpp:73
event_code_t
Definition: metadata.hpp:182
Definition: metadata.hpp:33
Definition: metadata.hpp:142
bool has_time_spec
Definition: metadata.hpp:148
bool start_of_burst
Start of burst will be true for the first packet in the chain.
Definition: metadata.hpp:76
error_code_t
Definition: metadata.hpp:95
bool start_of_burst
Definition: metadata.hpp:154
bool has_time_spec
Definition: metadata.hpp:55
Definition: config.h:66
Definition: metadata.hpp:169
size_t channel
The channel number in a mimo configuration.
Definition: metadata.hpp:171
bool more_fragments
Definition: metadata.hpp:66
bool end_of_burst
End of burst will be true for the last packet in the chain.
Definition: metadata.hpp:79
When the async event occurred.
Definition: metadata.hpp:177
bool out_of_sequence
Out of sequence. The transport has either dropped a packet or received data out of order...
Definition: metadata.hpp:120
