USRP Hardware Driver and USRP Manual  Version: 003.009.002-0-gf18abe54
Internal GPSDO Application Notes (USRP-B2x0 Models)
This application note describes the use of integrated GPS-disciplined oscillators with Ettus Research USRP devices.
Specifications
  • 10MHz ADEV: 5e-11 over >24h
  • 1PPS RMS jitter: <50ns 1-sigma
  • Holdover: <20us over 3h
Phase noise:
Offset Phase Noise Power
1Hz -65dBc/Hz
10Hz > -102dBc/Hz
100Hz -132dBc/Hz
1kHz -148dBc/Hz
10kHz -152dBc/Hz
100kHz < -155dBc/Hz
Antenna Types:
Installation Instructions
To install the GPSDO, you must insert it into the slot on the board near the 10 MHz Reference SMA. Keep in mind that the two sides of the GPSDO have a different number of pins. When inserting the GPSDO, make sure to press down firmly and evenly. When turning on the USRP B2X0 device, a green LED should illuminate on the GPSDO. This signifies that the unit has successfully been placed.
By default, if a GPSDO is detected at startup, the USRP will be configured to use it as a frequency and time reference. The internal VITA timestamp will be initialized to the GPS time, and the internal oscillator will be phase-locked to the 10MHz GPSDO reference. If the GPSDO is not locked to satellites, the VITA time will not be initialized.
