USRP Hardware Driver and USRP Manual  Version: 003.009.002-0-gf18abe54
USRP B100 Series
Comparative features list
  • Hardware Capabilities:
    • 1 transceiver card slot
    • Configurable clock rate (defaults 64 MHz)
  • FPGA Capabilities:
    • 1 RX DDC chain in FPGA
    • 1 TX DUC chain in FPGA
    • Timed commands in FPGA
    • Timed sampling in FPGA
    • sc8 and sc16 sample modes
Specify a Non-standard Image
UHD software will automatically select the USRP B100 images from the installed images package. The image selection can be overridden with the --fpga= and --fw= device address parameters.
Example device address string representations to specify non-standard images:
fpga=usrp_b100_fpga_2rx.bin
-- OR --
fw=usrp_b100_fw.ihx
Changing the Master Clock Rate
The master clock rate of the B100 feeds both the FPGA DSP and the codec chip. Hundreds of rates between 32 MHz and 64 MHz are available. A few notable rates are:
  • 64 MHz: maximum rate of the codec chip
  • 61.44 MHz: good for UMTS/WCDMA applications
  • 52 MHz: good for GSM applications
Set 61.44 MHz - uses external VCXO
To use the 61.44 MHz clock rate, the USRP embedded will require one jumper to be moved, and X4 must be populated with a 61.44 MHz oscillator.
  • J15 is a three pin header, move the jumper to (pin1, pin2)
  • 357LB3I061M4400 is the recommended oscillator for X4
Note: See instructions below to communicate the desired clock rate into UHD software.
Set other rates - uses internal VCO
To use other clock rates, the jumper will need to be in the default position.
  • J15 is a three pin header, move the jumper to (pin2, pin3)
To communicate the desired clock rate into UHD software, specify the special device address argument, where the key is master_clock_rate and the value is a rate in Hz. Example:
uhd_usrp_probe --args="master_clock_rate=52e6"
Hardware setup notes
Front panel LEDs
  • LED A: transmitting
  • LED B: FPGA loaded
  • LED C: receiving
  • LED D: FPGA loaded
  • LED E: reference lock
  • LED F: board power
Miscellaneous
Available Sensors
The following sensors are available; they can be queried through the API.
  • ref_locked: clock reference locked (internal/external)
