USRP Hardware Driver and USRP Manual  Version: 003.009.002-0-gf18abe54
USRP-E1x0 Series
Comparative features list
  • Hardware Capabilities:
    • 1 transceiver card slot
    • Internal PPS reference input
    • Internal 10 MHz reference input
    • Configurable clock rate (defaults to 64 MHz)
    • Internal GPSDO option
  • FPGA Capabilities:
    • 2 RX DDC chains in FPGA
    • 1 TX DUC chain in FPGA
    • Timed commands in FPGA
    • Timed sampling in FPGA
    • sc8 and sc16 sample modes
Specify a Non-standard Image
UHD software will automatically select the USRP-Embedded FPGA image from the installed images package. The FPGA image selection can be overridden with the fpga device address parameter.
Example device address string representations to specify non-standard FPGA image:
fpga=usrp_e100_custom.bin
Changing the Master Clock Rate
The master clock rate of the USRP-Embedded feeds both the FPGA DSP and the codec chip. Hundreds of rates between 32 MHz and 64 MHz are available. A few notable rates are:
  • 64 MHz: maximum rate of the codec chip
  • 61.44 MHz: good for UMTS/WCDMA applications
  • 52 MHz: good for GSM applications
Set 61.44MHz - uses external VCXO
To use the 61.44 MHz clock rate with the USRP-Embedded, two jumpers must be moved on the device.
  • J16 is a two pin header; remove the jumper (or leave it on pin1 only).
  • J15 is a three pin header; move the jumper to (pin1, pin2).
    Note:** See instructions below to communicate the desired clock rate to UHD software.
Set other rates - uses internal VCO
To use other clock rates, the jumpers will need to be in the default position.
  • J16 is a two pin header; move the jumper to (pin1, pin2).
  • J15 is a three pin header; move the jumper to (pin2, pin3).
To communicate the desired clock rate into UHD software, specify the a special device address argument, where the key is master_clock_rate and the value is a rate in Hz. Example:
uhd_usrp_probe --args="master_clock_rate=52e6"
Clock Synchronization
Ref Clock - 10MHz
The E1xx has a 10MHz TCXO which can be used to discipline the flexible clocking by selecting REF_INT for the uhd::clock_config_t.
Alternately, an external 10MHz reference clock can be supplied by soldering a connector.
  • Connector J10 (REF_IN) needs MCX connector WM5541-ND or similar.
  • Square wave will offer the best phase noise performance, but sinusoid is acceptable.
  • Power level: 0 to 15dBm
  • Select REF_SMA in uhd::clock_config_t.
PPS - Pulse Per Second
An external PPS signal for timestamp synchronization can be supplied by soldering a connector.
  • Connector J13 (PPS) needs MCX connector WM5541-ND or similar.
  • Requires a square wave signal.
  • Amplitude: 3.3 to 5 Vpp
Test the PPS input with the following app (<args> are device address arguments, optional if only one USRP device is on your machine):
cd <install-path>/lib/uhd/examples
./test_pps_input --args=<args>
Internal GPSDO
Please see the Internal GPSDO (USRP-N2x0/E1X0 Models) for information on configuring and using the internal GPSDO.
UHD software will always try to detect an installed GPSDO at runtime. It is not necessary to burn a special EEPROM value for GPSDO detection.
Hardware Setup Notes
Front panel LEDs
  • LED A: transmitting
  • LED B: PPS signal
  • LED C: receiving
  • LED D: FPGA loaded
  • LED E: reference lock
  • LED F: board power
Miscellaneous
Available Sensors
The following sensors are available; they can be queried through the API.
  • ref_locked: clock reference locked (internal/external)
  • other sensors are added when the GPSDO is enabled
