18 #ifndef INCLUDED_UHD_TYPES_SERIAL_HPP    19 #define INCLUDED_UHD_TYPES_SERIAL_HPP    22 #include <boost/shared_ptr.hpp>    23 #include <boost/cstdint.hpp>    47         typedef boost::shared_ptr<i2c_iface>
sptr;
    59         virtual void write_i2c(
    61             const byte_vector_t &buf
    70         virtual byte_vector_t read_i2c(
    81         virtual void write_eeprom(
    83             boost::uint16_t offset,
    84             const byte_vector_t &buf
    94         virtual byte_vector_t read_eeprom(
    96             boost::uint16_t offset,
   134         typedef boost::shared_ptr<spi_iface>
sptr;
   147         virtual boost::uint32_t transact_spi(
   150             boost::uint32_t data,
   163         virtual boost::uint32_t read_spi(
   166             boost::uint32_t data,
   177         virtual void write_spi(
   180             boost::uint32_t data,
   190         typedef boost::shared_ptr<uart_iface>
sptr;
   198         virtual void write_uart(
const std::string &buf) = 0;
   206         virtual std::string read_uart(
double timeout) = 0;
 Definition: serial.hpp:132
Definition: serial.hpp:45
edge_t mosi_edge
on what edge is the mosi data valid?
Definition: serial.hpp:116
Definition: serial.hpp:105
boost::shared_ptr< spi_iface > sptr
Definition: serial.hpp:134
std::vector< boost::uint8_t > byte_vector_t
Definition: byte_vector.hpp:33
Definition: config.h:66
edge_t miso_edge
on what edge is the miso data valid?
Definition: serial.hpp:119
Definition: serial.hpp:188
Definition: serial.hpp:190
edge_t
Definition: serial.hpp:110
boost::shared_ptr< i2c_iface > sptr
Definition: serial.hpp:47
