byte_vector.hpp
18 #ifndef INCLUDED_UHD_TYPES_BYTE_VECTOR_HPP
19 #define INCLUDED_UHD_TYPES_BYTE_VECTOR_HPP
21 #include <algorithm>
22 #include <string>
23 #include <vector>
25 #include <boost/assign.hpp>
26 #include <boost/cstdint.hpp>
27
28 #include <uhd/config.hpp>
29
30 namespace uhd{
31
33  typedef std::vector<boost::uint8_t> byte_vector_t;
34
35  template<typename RangeSrc, typename RangeDst> UHD_INLINE
36  void byte_copy(const RangeSrc &src, RangeDst &dst){
37  std::copy(boost::begin(src), boost::end(src), boost::begin(dst));
38  }
39
41  UHD_API std::string bytes_to_string(const byte_vector_t &bytes);
42
44  UHD_API byte_vector_t string_to_bytes(const std::string &str, size_t max_length);
45
46 } //namespace uhd
47
48 #endif /* INCLUDED_UHD_TYPES_BYTE_VECTOR_HPP */
Definition: byte_vector.hpp:36
#define UHD_INLINE
Definition: config.h:56
std::vector< boost::uint8_t > byte_vector_t
Definition: byte_vector.hpp:33
Definition: config.h:66
