18 #ifndef INCLUDED_UHD_USRP_DBOARD_IFACE_HPP    19 #define INCLUDED_UHD_USRP_DBOARD_IFACE_HPP    25 #include <boost/shared_ptr.hpp>    26 #include <boost/cstdint.hpp>    30 namespace uhd{
namespace usrp{
    61     typedef boost::shared_ptr<dboard_iface>
sptr;
    72         ATR_REG_IDLE        = int(
'i'),
    73         ATR_REG_TX_ONLY     = int(
't'),
    74         ATR_REG_RX_ONLY     = int(
'r'),
    75         ATR_REG_FULL_DUPLEX = int(
'f')
    98     virtual special_props_t get_special_props(
void) = 0;
   107     virtual void write_aux_dac(
unit_t unit,
aux_dac_t which_dac,
double value) = 0;
   125     virtual void set_pin_ctrl(
   126         unit_t unit, boost::uint16_t value, boost::uint16_t
mask = 0xffff
   135     virtual boost::uint16_t get_pin_ctrl(
unit_t unit);
   145     virtual void set_atr_reg(
   165     virtual void set_gpio_ddr(
   166         unit_t unit, boost::uint16_t value, boost::uint16_t
mask = 0xffff
   175     virtual boost::uint16_t get_gpio_ddr(
unit_t unit);
   184     virtual void set_gpio_out(
   185         unit_t unit, boost::uint16_t value, boost::uint16_t
mask = 0xffff
   194     virtual boost::uint16_t get_gpio_out(
unit_t unit);
   202     virtual void set_gpio_debug(
unit_t unit,
int which) = 0;
   210     virtual boost::uint16_t read_gpio(
unit_t unit) = 0;
   220     virtual void write_spi(
   223         boost::uint32_t data,
   236     virtual boost::uint32_t read_write_spi(
   239         boost::uint32_t data,
   249     virtual void set_clock_rate(
unit_t unit,
double rate) = 0;
   257     virtual double get_clock_rate(
unit_t unit) = 0;
   265     virtual std::vector<double> get_clock_rates(
unit_t unit) = 0;
   273     virtual void set_clock_enabled(
unit_t unit,
bool enb) = 0;
   282     virtual double get_codec_rate(
unit_t unit) = 0;
   299     virtual void _set_pin_ctrl(
unit_t unit, boost::uint16_t value) = 0;
   300     virtual void _set_atr_reg(
unit_t unit,
atr_reg_t reg, boost::uint16_t value) = 0;
   301     virtual void _set_gpio_ddr(
   302     virtual void _set_gpio_out(
aux_adc_t
Definition: dboard_iface.hpp:87
Definition: serial.hpp:45
size_t mask(const soft_reg_field_t field)
Definition: soft_register.hpp:98
Definition: time_spec.hpp:39
aux_dac_t
Definition: dboard_iface.hpp:79
Definition: dboard_iface.hpp:59
bool soft_clock_divider
Definition: dboard_iface.hpp:40
Definition: serial.hpp:105
#define UHD_PIMPL_DECL(_name)
Definition: pimpl.hpp:42
Definition: config.h:66
Definition: dboard_iface.hpp:62
Definition: dboard_iface.hpp:33
unit_t
Definition: dboard_iface.hpp:65
bool mangle_i2c_addrs
Definition: dboard_iface.hpp:50
atr_reg_t
possible atr registers
Definition: dboard_iface.hpp:71
