property_tree.hpp
2 // Copyright 2011,2014 Ettus Research LLC
18 #ifndef INCLUDED_UHD_PROPERTY_TREE_HPP
19 #define INCLUDED_UHD_PROPERTY_TREE_HPP
24 #include <boost/function.hpp>
25 #include <vector>
26
27 namespace uhd{
28
33 template <typename T> class property : boost::noncopyable{
34 public:
35  typedef boost::function<void(const T &)> subscriber_type;
36  typedef boost::function<T(void)> publisher_type;
37  typedef boost::function<T(const T &)> coercer_type;
38
39  virtual ~property<T>(void) = 0;
40
49  virtual property<T> &coerce(const coercer_type &coercer) = 0;
50
60  virtual property<T> &publish(const publisher_type &publisher) = 0;
61
69  virtual property<T> &subscribe(const subscriber_type &subscriber) = 0;
70
75  virtual property<T> &update(void) = 0;
76
84  virtual property<T> &set(const T &value) = 0;
85
92  virtual T get(void) const = 0;
93
99  virtual bool empty(void) const = 0;
100 };
101
102 template <typename T>
104  /* NOP */
105 }
106
114 struct fs_path : std::string{
115  UHD_API fs_path(void);
116  UHD_API fs_path(const char *);
117  UHD_API fs_path(const std::string &);
118  UHD_API std::string leaf(void) const;
119  UHD_API fs_path branch_path(void) const;
120 };
121
122 UHD_API fs_path operator/(const fs_path &, const fs_path &);
123 UHD_API fs_path operator/(const fs_path &, size_t);
124
128 class UHD_API property_tree : boost::noncopyable{
129 public:
130  typedef boost::shared_ptr<property_tree> sptr;
131
132  virtual ~property_tree(void) = 0;
133
135  static sptr make(void);
136
138  virtual sptr subtree(const fs_path &path) const = 0;
139
141  virtual void remove(const fs_path &path) = 0;
142
144  virtual bool exists(const fs_path &path) const = 0;
145
147  virtual std::vector<std::string> list(const fs_path &path) const = 0;
148
150  template <typename T> property<T> &create(const fs_path &path);
151
153  template <typename T> property<T> &access(const fs_path &path);
154
155 private:
157  virtual void _create(const fs_path &path, const boost::shared_ptr<void> &prop) = 0;
158
160  virtual boost::shared_ptr<void> &_access(const fs_path &path) const = 0;
161
162 };
163
164 } //namespace uhd
165
166 #include <uhd/property_tree.ipp>
167
168 #endif /* INCLUDED_UHD_PROPERTY_TREE_HPP */
boost::function< void(const T &)> subscriber_type
Definition: property_tree.hpp:35
virtual ~property(void)=0
Definition: property_tree.hpp:103
virtual property< T > & update(void)=0
Definition: property_tree.hpp:114
Definition: property_tree.hpp:130
virtual property< T > & publish(const publisher_type &publisher)=0
boost::function< T(const T &)> coercer_type
Definition: property_tree.hpp:37
virtual bool empty(void) const =0
virtual property< T > & coerce(const coercer_type &coercer)=0
boost::function< T(void)> publisher_type
Definition: property_tree.hpp:36
Definition: config.h:66
virtual property< T > & subscribe(const subscriber_type &subscriber)=0
Definition: property_tree.hpp:128
Definition: property_tree.hpp:33
