sensors.h
18 #ifndef INCLUDED_UHD_TYPES_SENSORS_H
19 #define INCLUDED_UHD_TYPES_SENSORS_H
21 #include <uhd/config.h>
22 #include <uhd/error.h>
23
24 #ifdef __cplusplus
25 #include <uhd/types/sensors.hpp>
26 #include <string>
27
28 struct uhd_sensor_value_t {
29  // No default constructor, so we need a pointer
30  uhd::sensor_value_t* sensor_value_cpp;
31  std::string last_error;
32 };
33 extern "C" {
34 #else
35 struct uhd_sensor_value_t;
36 #endif
37
39
44 typedef struct uhd_sensor_value_t* uhd_sensor_value_handle;
45
47 typedef enum {
53
55
64  uhd_sensor_value_handle* h,
65  const char* name,
66  bool value,
67  const char* utrue,
68  const char* ufalse
69 );
70
72
81  uhd_sensor_value_handle* h,
82  const char* name,
83  int value,
84  const char* unit,
85  const char* formatter
86 );
87
89
98  uhd_sensor_value_handle* h,
99  const char* name,
100  double value,
101  const char* unit,
102  const char* formatter
103 );
104
106
114  uhd_sensor_value_handle* h,
115  const char* name,
116  const char* value,
117  const char* unit
118 );
119
121
126  uhd_sensor_value_handle* h
127 );
128
131  uhd_sensor_value_handle h,
132  bool *value_out
133 );
134
137  uhd_sensor_value_handle h,
138  int *value_out
139 );
140
143  uhd_sensor_value_handle h,
144  double *value_out
145 );
146
148
157  uhd_sensor_value_handle h,
158  char* name_out,
159  size_t strbuffer_len
160 );
161
163
172  uhd_sensor_value_handle h,
173  char* value_out,
174  size_t strbuffer_len
175 );
176
178
187  uhd_sensor_value_handle h,
188  char* unit_out,
189  size_t strbuffer_len
190 );
191
193  uhd_sensor_value_handle h,
194  uhd_sensor_value_data_type_t *data_type_out
195 );
196
198
207  uhd_sensor_value_handle h,
208  char* pp_string_out,
209  size_t strbuffer_len
210 );
211
213
222  uhd_sensor_value_handle h,
223  char* error_out,
224  size_t strbuffer_len
225 );
226
227 #ifdef __cplusplus
228 }
229 #endif
230
231 #endif /* INCLUDED_UHD_TYPES_SENSORS_H */
UHD_API uhd_error uhd_sensor_value_to_realnum(uhd_sensor_value_handle h, double *value_out)
Get the sensor&#39;s value as a real number.
UHD_API uhd_error uhd_sensor_value_make_from_int(uhd_sensor_value_handle *h, const char *name, int value, const char *unit, const char *formatter)
Make a UHD sensor from an integer.
UHD_API uhd_error uhd_sensor_value_last_error(uhd_sensor_value_handle h, char *error_out, size_t strbuffer_len)
Get the last error logged by the sensor handle.
Definition: sensors.h:51
UHD_API uhd_error uhd_sensor_value_unit(uhd_sensor_value_handle h, char *unit_out, size_t strbuffer_len)
Get the sensor&#39;s unit.
UHD_API uhd_error uhd_sensor_value_value(uhd_sensor_value_handle h, char *value_out, size_t strbuffer_len)
Get the sensor&#39;s value.
UHD_API uhd_error uhd_sensor_value_make_from_string(uhd_sensor_value_handle *h, const char *name, const char *value, const char *unit)
Make a UHD sensor from a string.
Definition: sensors.h:50
UHD_API uhd_error uhd_sensor_value_free(uhd_sensor_value_handle *h)
Free the given sensor handle.
UHD_API uhd_error uhd_sensor_value_make_from_bool(uhd_sensor_value_handle *h, const char *name, bool value, const char *utrue, const char *ufalse)
Make a UHD sensor from a boolean.
Sensor value types.
Definition: sensors.h:47
UHD_API uhd_error uhd_sensor_value_data_type(uhd_sensor_value_handle h, uhd_sensor_value_data_type_t *data_type_out)
uhd_error
UHD error codes.
Definition: error.h:31
Definition: sensors.hpp:38
Definition: sensors.h:48
UHD_API uhd_error uhd_sensor_value_to_pp_string(uhd_sensor_value_handle h, char *pp_string_out, size_t strbuffer_len)
Get a pretty-print representation of the given sensor.
Definition: config.h:66
UHD_API uhd_error uhd_sensor_value_make_from_realnum(uhd_sensor_value_handle *h, const char *name, double value, const char *unit, const char *formatter)
Make a UHD sensor from a real number.
Definition: sensors.h:44
Definition: sensors.h:49
UHD_API uhd_error uhd_sensor_value_name(uhd_sensor_value_handle h, char *name_out, size_t strbuffer_len)
Get the sensor&#39;s name.
UHD_API uhd_error uhd_sensor_value_to_int(uhd_sensor_value_handle h, int *value_out)
Get the sensor&#39;s value as an integer.
UHD_API uhd_error uhd_sensor_value_to_bool(uhd_sensor_value_handle h, bool *value_out)
Get the sensor&#39;s value as a boolean.
