The USRP FPGA build system requires a UNIX-like environment with the following dependencies
source <install_dir>/Xilinx/14.7/ISE_DS/settings64.sh (64-bit platform)source <install_dir>/Xilinx/14.7/ISE_DS/settings32.sh (32-bit platform)usrp3/top/{project} where project is:make <target> where the target is specific to each product. To get a list of supported targets run make help.usrp3/top/{project}/build directory. Run make help for more information.usrp3/top/{project} where project is:source setupenv.sh (If Vivado is installed in the default path /opt/Xilinx/Vivado) ORsource setupenv.sh --vivado-path=<VIVADO_PATH> (where VIVADO_PATH is a non-default installation path)make <target> where the target is specific to each product. To get a list of supported targets run make help.usrp3/top/{project}/build directory. Run make help for more information.build/usrp_<product>_fpga.bit : Configuration bitstream with headerbuild/usrp_<product>_fpga.bin : Configuration bitstream without headerbuild/usrp_<product>_fpga.syr : Xilinx system reportbuild/usrp_<product>_fpga.twr : Xilinx timing reportbuild/usrp_<product>_fpga_<image_type>.bit : Configuration bitstream with headerbuild/usrp_<product>_fpga_<image_type>.bin : Configuration bitstream without headerbuild/usrp_<product>_fpga_<image_type>.lvbitx : Configuration bitstream for PCIe (NI-RIO)build/usrp_<product>_fpga_<image_type>.rpt : System, utilization and timing summary reportbuild/usrp_<product>_fpga.bit : Configuration bitstream with headerbuild/usrp_<product>_fpga.bin : Configuration bitstream without headerbuild/usrp_<product>_fpga.rpt : System, utilization and timing summary reportIt is possible to make a target and specific additional options in the form VAR=VALUE in the command. For example: make B210 PROJECT_ONLY=1
Here are the supported options:
PROJECT_ONLY=1 : Only create a Xilinx project for the specified target(s). Useful for use with the ISE GUI. (NOTE: this option is only valid for Xilinx ISE)EXPORT_ONLY=1 : Export build targets from a GUI build to the build directory. Requires the project in build-*_* to be built. (NOTE: this option is only valid for Xilinx ISE)GUI=1 : Run the Vivado build in GUI mode instead of batch mode. After the build is complete, Vivado provides an option to save the fully configured project for customization (NOTE: this option is only valid for Xilinx Vivado)
