multi_usrp.hpp
2 // Copyright 2010-2012,2014-2015 Ettus Research LLC
18 #ifndef INCLUDED_UHD_USRP_MULTI_USRP_HPP
19 #define INCLUDED_UHD_USRP_MULTI_USRP_HPP
21 //define API capabilities for compile time detection of new features
22 #define UHD_USRP_MULTI_USRP_REF_SOURCES_API
23 #define UHD_USRP_MULTI_USRP_GET_RATES_API
24 #define UHD_USRP_MULTI_USRP_FRONTEND_CAL_API
25 #define UHD_USRP_MULTI_USRP_FRONTEND_IQ_AUTO_API
26 #define UHD_USRP_MULTI_USRP_COMMAND_TIME_API
27 #define UHD_USRP_MULTI_USRP_BW_RANGE_API
28 #define UHD_USRP_MULTI_USRP_USER_REGS_API
29 #define UHD_USRP_MULTI_USRP_GET_USRP_INFO_API
30 #define UHD_USRP_MULTI_USRP_NORMALIZED_GAIN
31 #define UHD_USRP_MULTI_USRP_GPIO_API
32 #define UHD_USRP_MULTI_USRP_REGISTER_API
33 #define UHD_USRP_MULTI_USRP_FILTER_API
34
35 #include <uhd/config.hpp>
36 #include <uhd/device.hpp>
37 #include <uhd/deprecated.hpp>
38 #include <uhd/types/ranges.hpp>
39 #include <uhd/types/stream_cmd.hpp>
42 #include <uhd/types/sensors.hpp>
43 #include <uhd/types/filters.hpp>
44 #include <uhd/usrp/subdev_spec.hpp>
46 #include <boost/shared_ptr.hpp>
47 #include <boost/utility.hpp>
48 #include <complex>
49 #include <string>
50 #include <vector>
51
52 namespace uhd{ namespace usrp{
53
100 class UHD_API multi_usrp : boost::noncopyable{
101 public:
102  typedef boost::shared_ptr<multi_usrp> sptr;
103
104  virtual ~multi_usrp(void) = 0;
105
107  static const size_t ALL_MBOARDS = size_t(~0);
108
110  static const size_t ALL_CHANS = size_t(~0);
111
113  static const std::string ALL_GAINS;
114
120  static sptr make(const device_addr_t &dev_addr);
121
127  virtual device::sptr get_device(void) = 0;
128
130  virtual rx_streamer::sptr get_rx_stream(const stream_args_t &args) = 0;
131
133  virtual tx_streamer::sptr get_tx_stream(const stream_args_t &args) = 0;
134
142  virtual dict<std::string, std::string> get_usrp_rx_info(size_t chan = 0) = 0;
143
151  virtual dict<std::string, std::string> get_usrp_tx_info(size_t chan = 0) = 0;
152
153  /*******************************************************************
154  * Mboard methods
155  ******************************************************************/
156
179  virtual void set_master_clock_rate(double rate, size_t mboard = ALL_MBOARDS) = 0;
180
186  virtual double get_master_clock_rate(size_t mboard = 0) = 0;
187
192  virtual std::string get_pp_string(void) = 0;
193
199  virtual std::string get_mboard_name(size_t mboard = 0) = 0;
200
206  virtual time_spec_t get_time_now(size_t mboard = 0) = 0;
207
213  virtual time_spec_t get_time_last_pps(size_t mboard = 0) = 0;
214
226  virtual void set_time_now(const time_spec_t &time_spec, size_t mboard = ALL_MBOARDS) = 0;
227
240  virtual void set_time_next_pps(const time_spec_t &time_spec, size_t mboard = ALL_MBOARDS) = 0;
241
257  virtual void set_time_unknown_pps(const time_spec_t &time_spec) = 0;
258
265  virtual bool get_time_synchronized(void) = 0;
266
277  virtual void set_command_time(const uhd::time_spec_t &time_spec, size_t mboard = ALL_MBOARDS) = 0;
278
284  virtual void clear_command_time(size_t mboard = ALL_MBOARDS) = 0;
285
298  virtual void issue_stream_cmd(const stream_cmd_t &stream_cmd, size_t chan = ALL_CHANS) = 0;
299
308  virtual void set_clock_config(const clock_config_t &clock_config, size_t mboard = ALL_MBOARDS) = 0;
309
318  virtual void set_time_source(const std::string &source, const size_t mboard = ALL_MBOARDS) = 0;
319
325  virtual std::string get_time_source(const size_t mboard) = 0;
326
332  virtual std::vector<std::string> get_time_sources(const size_t mboard) = 0;
333
341  virtual void set_clock_source(const std::string &source, const size_t mboard = ALL_MBOARDS) = 0;
342
348  virtual std::string get_clock_source(const size_t mboard) = 0;
349
355  virtual std::vector<std::string> get_clock_sources(const size_t mboard) = 0;
356
365  virtual void set_clock_source_out(const bool enb, const size_t mboard = ALL_MBOARDS) = 0;
366
375  virtual void set_time_source_out(const bool enb, const size_t mboard = ALL_MBOARDS) = 0;
376
380  virtual size_t get_num_mboards(void) = 0;
381
388  virtual sensor_value_t get_mboard_sensor(const std::string &name, size_t mboard = 0) = 0;
389
395  virtual std::vector<std::string> get_mboard_sensor_names(size_t mboard = 0) = 0;
396
404  virtual void set_user_register(const boost::uint8_t addr, const boost::uint32_t data, size_t mboard = ALL_MBOARDS) = 0;
405
406  /*******************************************************************
407  * RX methods
408  ******************************************************************/
417  virtual void set_rx_subdev_spec(const uhd::usrp::subdev_spec_t &spec, size_t mboard = ALL_MBOARDS) = 0;
418
424  virtual uhd::usrp::subdev_spec_t get_rx_subdev_spec(size_t mboard = 0) = 0;
425
431  virtual size_t get_rx_num_channels(void) = 0;
432
438  virtual std::string get_rx_subdev_name(size_t chan = 0) = 0;
439
445  virtual void set_rx_rate(double rate, size_t chan = ALL_CHANS) = 0;
446
452  virtual double get_rx_rate(size_t chan = 0) = 0;
453
459  virtual meta_range_t get_rx_rates(size_t chan = 0) = 0;
460
467  virtual tune_result_t set_rx_freq(
468  const tune_request_t &tune_request, size_t chan = 0
469  ) = 0;
470
476  virtual double get_rx_freq(size_t chan = 0) = 0;
477
487  virtual freq_range_t get_rx_freq_range(size_t chan = 0) = 0;
488
494  virtual freq_range_t get_fe_rx_freq_range(size_t chan = 0) = 0;
495
503  virtual void set_rx_gain(double gain, const std::string &name, size_t chan = 0) = 0;
504
506  void set_rx_gain(double gain, size_t chan = 0){
507  return this->set_rx_gain(gain, ALL_GAINS, chan);
508  }
509
526  virtual void set_normalized_rx_gain(double gain, size_t chan = 0) = 0;
527
536  virtual void set_rx_agc(bool enable, size_t chan = 0) = 0;
537
545  virtual double get_rx_gain(const std::string &name, size_t chan = 0) = 0;
546
548  double get_rx_gain(size_t chan = 0){
549  return this->get_rx_gain(ALL_GAINS, chan);
550  }
551
562  virtual double get_normalized_rx_gain(size_t chan = 0) = 0;
563
571  virtual gain_range_t get_rx_gain_range(const std::string &name, size_t chan = 0) = 0;
572
574  gain_range_t get_rx_gain_range(size_t chan = 0){
575  return this->get_rx_gain_range(ALL_GAINS, chan);
576  }
577
584  virtual std::vector<std::string> get_rx_gain_names(size_t chan = 0) = 0;
585
591  virtual void set_rx_antenna(const std::string &ant, size_t chan = 0) = 0;
592
598  virtual std::string get_rx_antenna(size_t chan = 0) = 0;
599
605  virtual std::vector<std::string> get_rx_antennas(size_t chan = 0) = 0;
606
612  virtual void set_rx_bandwidth(double bandwidth, size_t chan = 0) = 0;
613
619  virtual double get_rx_bandwidth(size_t chan = 0) = 0;
620
626  virtual meta_range_t get_rx_bandwidth_range(size_t chan = 0) = 0;
627
635  virtual dboard_iface::sptr get_rx_dboard_iface(size_t chan = 0) = 0;
636
643  virtual sensor_value_t get_rx_sensor(const std::string &name, size_t chan = 0) = 0;
644
650  virtual std::vector<std::string> get_rx_sensor_names(size_t chan = 0) = 0;
651
664  virtual void set_rx_dc_offset(const bool enb, size_t chan = ALL_CHANS) = 0;
665
673  virtual void set_rx_dc_offset(const std::complex<double> &offset, size_t chan = ALL_CHANS) = 0;
674
681  virtual void set_rx_iq_balance(const bool enb, size_t chan) = 0;
682
690  virtual void set_rx_iq_balance(const std::complex<double> &correction, size_t chan = ALL_CHANS) = 0;
691
692  /*******************************************************************
693  * TX methods
694  ******************************************************************/
703  virtual void set_tx_subdev_spec(const uhd::usrp::subdev_spec_t &spec, size_t mboard = ALL_MBOARDS) = 0;
704
710  virtual uhd::usrp::subdev_spec_t get_tx_subdev_spec(size_t mboard = 0) = 0;
711
717  virtual size_t get_tx_num_channels(void) = 0;
718
724  virtual std::string get_tx_subdev_name(size_t chan = 0) = 0;
725
731  virtual void set_tx_rate(double rate, size_t chan = ALL_CHANS) = 0;
732
738  virtual double get_tx_rate(size_t chan = 0) = 0;
739
745  virtual meta_range_t get_tx_rates(size_t chan = 0) = 0;
746
753  virtual tune_result_t set_tx_freq(
754  const tune_request_t &tune_request, size_t chan = 0
755  ) = 0;
756
762  virtual double get_tx_freq(size_t chan = 0) = 0;
763
773  virtual freq_range_t get_tx_freq_range(size_t chan = 0) = 0;
774
780  virtual freq_range_t get_fe_tx_freq_range(size_t chan = 0) = 0;
781
789  virtual void set_tx_gain(double gain, const std::string &name, size_t chan = 0) = 0;
790
792  void set_tx_gain(double gain, size_t chan = 0){
793  return this->set_tx_gain(gain, ALL_GAINS, chan);
794  }
795
806  virtual void set_normalized_tx_gain(double gain, size_t chan = 0) = 0;
807
815  virtual double get_tx_gain(const std::string &name, size_t chan = 0) = 0;
816
818  double get_tx_gain(size_t chan = 0){
819  return this->get_tx_gain(ALL_GAINS, chan);
820  }
821
832  virtual double get_normalized_tx_gain(size_t chan = 0) = 0;
833
841  virtual gain_range_t get_tx_gain_range(const std::string &name, size_t chan = 0) = 0;
842
844  gain_range_t get_tx_gain_range(size_t chan = 0){
845  return this->get_tx_gain_range(ALL_GAINS, chan);
846  }
847
854  virtual std::vector<std::string> get_tx_gain_names(size_t chan = 0) = 0;
855
861  virtual void set_tx_antenna(const std::string &ant, size_t chan = 0) = 0;
862
868  virtual std::string get_tx_antenna(size_t chan = 0) = 0;
869
875  virtual std::vector<std::string> get_tx_antennas(size_t chan = 0) = 0;
876
882  virtual void set_tx_bandwidth(double bandwidth, size_t chan = 0) = 0;
883
889  virtual double get_tx_bandwidth(size_t chan = 0) = 0;
890
896  virtual meta_range_t get_tx_bandwidth_range(size_t chan = 0) = 0;
897
905  virtual dboard_iface::sptr get_tx_dboard_iface(size_t chan = 0) = 0;
906
913  virtual sensor_value_t get_tx_sensor(const std::string &name, size_t chan = 0) = 0;
914
920  virtual std::vector<std::string> get_tx_sensor_names(size_t chan = 0) = 0;
921
928  virtual void set_tx_dc_offset(const std::complex<double> &offset, size_t chan = ALL_CHANS) = 0;
929
937  virtual void set_tx_iq_balance(const std::complex<double> &correction, size_t chan = ALL_CHANS) = 0;
938
939  /*******************************************************************
940  * GPIO methods
941  ******************************************************************/
942
948  virtual std::vector<std::string> get_gpio_banks(const size_t mboard) = 0;
949
966  virtual void set_gpio_attr(const std::string &bank, const std::string &attr, const boost::uint32_t value, const boost::uint32_t mask = 0xffffffff, const size_t mboard = 0) = 0;
967
984  virtual boost::uint32_t get_gpio_attr(const std::string &bank, const std::string &attr, const size_t mboard = 0) = 0;
985
986  /*******************************************************************
987  * Register IO methods
988  ******************************************************************/
990  size_t bitwidth;
991  bool readable;
992  bool writable;
993  };
994
1000  virtual std::vector<std::string> enumerate_registers(const size_t mboard = 0) = 0;
1001
1008  virtual register_info_t get_register_info(const std::string &path, const size_t mboard = 0) = 0;
1009
1017  virtual void write_register(const std::string &path, const boost::uint32_t field, const boost::uint64_t value, const size_t mboard = 0) = 0;
1018
1026  virtual boost::uint64_t read_register(const std::string &path, const boost::uint32_t field, const size_t mboard = 0) = 0;
1027
1028  /*******************************************************************
1029  * Filter API methods
1030  ******************************************************************/
1031
1042  virtual std::vector<std::string> get_filter_names(const std::string &search_mask = "") = 0;
1043
1049  virtual filter_info_base::sptr get_filter(const std::string &path) = 0;
1050
1058  virtual void set_filter(const std::string &path, filter_info_base::sptr filter) = 0;
1059
1060 };
1061
1062 }}
1063
1064 #endif /* INCLUDED_UHD_USRP_MULTI_USRP_HPP */
Definition: multi_usrp.hpp:574
Definition: stream_cmd.hpp:46
Definition: tune_result.hpp:29
Definition: multi_usrp.hpp:818
size_t mask(const soft_reg_field_t field)
Definition: soft_register.hpp:98
Definition: multi_usrp.hpp:792
Definition: time_spec.hpp:39
bool readable
Definition: multi_usrp.hpp:991
Definition: device.hpp:41
boost::shared_ptr< multi_usrp > sptr
Definition: multi_usrp.hpp:102
Definition: multi_usrp.hpp:989
Definition: multi_usrp.hpp:548
Definition: tune_request.hpp:33
Definition: stream.hpp:184
A wildcard gain element name.
Definition: multi_usrp.hpp:113
Definition: sensors.hpp:38
boost::shared_ptr< filter_info_base > sptr
Definition: filters.hpp:38
Definition: multi_usrp.hpp:100
Definition: stream.hpp:57
Definition: config.h:66
Definition: multi_usrp.hpp:506
bool writable
Definition: multi_usrp.hpp:992
Definition: ranges.hpp:68
size_t bitwidth
Definition: multi_usrp.hpp:990
Definition: stream.hpp:260
Definition: multi_usrp.hpp:844
