| ATR_REG_FULL_DUPLEX enum value | uhd::usrp::dboard_iface |  |
  | ATR_REG_IDLE enum value | uhd::usrp::dboard_iface |  |
  | ATR_REG_RX_ONLY enum value | uhd::usrp::dboard_iface |  |
  | atr_reg_t enum name | uhd::usrp::dboard_iface |  |
  | ATR_REG_TX_ONLY enum value | uhd::usrp::dboard_iface |  |
  | AUX_ADC_A enum value | uhd::usrp::dboard_iface |  |
  | AUX_ADC_B enum value | uhd::usrp::dboard_iface |  |
  | aux_adc_t enum name | uhd::usrp::dboard_iface |  |
  | AUX_DAC_A enum value | uhd::usrp::dboard_iface |  |
  | AUX_DAC_B enum value | uhd::usrp::dboard_iface |  |
  | AUX_DAC_C enum value | uhd::usrp::dboard_iface |  |
  | AUX_DAC_D enum value | uhd::usrp::dboard_iface |  |
  | aux_dac_t enum name | uhd::usrp::dboard_iface |  |
  | dboard_iface(void) | uhd::usrp::dboard_iface | protected |
  | eeprom16(void) | uhd::i2c_iface |  |
  | get_atr_reg(unit_t unit, atr_reg_t reg) | uhd::usrp::dboard_iface | virtual |
  | get_clock_rate(unit_t unit)=0 | uhd::usrp::dboard_iface | pure virtual |
  | get_clock_rates(unit_t unit)=0 | uhd::usrp::dboard_iface | pure virtual |
  | get_codec_rate(unit_t unit)=0 | uhd::usrp::dboard_iface | pure virtual |
  | get_command_time(void) | uhd::usrp::dboard_iface | virtual |
  | get_gpio_ddr(unit_t unit) | uhd::usrp::dboard_iface | virtual |
  | get_gpio_out(unit_t unit) | uhd::usrp::dboard_iface | virtual |
  | get_pin_ctrl(unit_t unit) | uhd::usrp::dboard_iface | virtual |
  | get_special_props(void)=0 | uhd::usrp::dboard_iface | pure virtual |
  | read_aux_adc(unit_t unit, aux_adc_t which_adc)=0 | uhd::usrp::dboard_iface | pure virtual |
  | read_eeprom(boost::uint16_t addr, boost::uint16_t offset, size_t num_bytes) | uhd::i2c_iface | virtual |
  | read_gpio(unit_t unit)=0 | uhd::usrp::dboard_iface | pure virtual |
  | read_i2c(boost::uint16_t addr, size_t num_bytes)=0 | uhd::i2c_iface | pure virtual |
  | read_write_spi(unit_t unit, const spi_config_t &config, boost::uint32_t data, size_t num_bits)=0 | uhd::usrp::dboard_iface | pure virtual |
  | set_atr_reg(unit_t unit, atr_reg_t reg, boost::uint16_t value, boost::uint16_t mask=0xffff) | uhd::usrp::dboard_iface | virtual |
  | set_clock_enabled(unit_t unit, bool enb)=0 | uhd::usrp::dboard_iface | pure virtual |
  | set_clock_rate(unit_t unit, double rate)=0 | uhd::usrp::dboard_iface | pure virtual |
  | set_command_time(const uhd::time_spec_t &t) | uhd::usrp::dboard_iface | virtual |
  | set_gpio_ddr(unit_t unit, boost::uint16_t value, boost::uint16_t mask=0xffff) | uhd::usrp::dboard_iface | virtual |
  | set_gpio_debug(unit_t unit, int which)=0 | uhd::usrp::dboard_iface | pure virtual |
  | set_gpio_out(unit_t unit, boost::uint16_t value, boost::uint16_t mask=0xffff) | uhd::usrp::dboard_iface | virtual |
  | set_pin_ctrl(unit_t unit, boost::uint16_t value, boost::uint16_t mask=0xffff) | uhd::usrp::dboard_iface | virtual |
  | special_props_t typedef | uhd::usrp::dboard_iface |  |
  | sptr typedef | uhd::usrp::dboard_iface |  |
  | UNIT_RX enum value | uhd::usrp::dboard_iface |  |
  | unit_t enum name | uhd::usrp::dboard_iface |  |
  | UNIT_TX enum value | uhd::usrp::dboard_iface |  |
  | write_aux_dac(unit_t unit, aux_dac_t which_dac, double value)=0 | uhd::usrp::dboard_iface | pure virtual |
  | write_eeprom(boost::uint16_t addr, boost::uint16_t offset, const byte_vector_t &buf) | uhd::i2c_iface | virtual |
  | write_i2c(boost::uint16_t addr, const byte_vector_t &buf)=0 | uhd::i2c_iface | pure virtual |
  | ~dboard_iface(void) | uhd::usrp::dboard_iface | virtual |
  | ~i2c_iface(void) | uhd::i2c_iface | virtual |
