USRP1
Comparative features list
  • Hardware Capabilities:
    • 2 transceiver card slots
    • 64 MHz fixed clock rate
  • FPGA Capabilities:
    • 2 RX DDC chains in FPGA
    • sc16 sample modes - RX & TX
    • sc8 sample mode - RX only
Specify a Non-standard Image
fpga=usrp1_fpga_4rx.rbf
-- OR --
fw=usrp1_fw_custom.ihx
-- OR --
Missing and Emulated Features
List of emulated features
List of missing features
Hardware Setup Notes
External clock modification
The user may override the clock rate specified in the EEPROM by using a device address. Example:
