usrp.h
18 #ifndef INCLUDED_UHD_USRP_H
19 #define INCLUDED_UHD_USRP_H
21 #include <uhd/config.h>
22 #include <uhd/error.h>
23 #include <uhd/types/metadata.h>
24 #include <uhd/types/ranges.h>
25 #include <uhd/types/sensors.h>
27 #include <uhd/types/tune_request.h>
28 #include <uhd/types/tune_result.h>
29 #include <uhd/types/usrp_info.h>
30 #include <uhd/usrp/mboard_eeprom.h>
31 #include <uhd/usrp/dboard_eeprom.h>
32 #include <uhd/usrp/subdev_spec.h>
33 /* version.hpp is safe to include in C: */
34 #include <uhd/version.hpp> /* Provides UHD_VERSION */
35
36 #include <stdbool.h>
37 #include <stdlib.h>
38 #include <stdint.h>
39 #include <time.h>
40
42 typedef struct {
43  size_t bitwidth;
44  bool readable;
45  bool writable;
47
48 /*
49  * Streamers
50  */
51
53
56 typedef struct {
58  char* cpu_format;
60  char* otw_format;
62  char* args;
64  size_t* channel_list;
68
70
73 typedef enum {
83
85
88 typedef struct {
92  size_t num_samps;
94  bool stream_now;
100
101 struct uhd_rx_streamer;
102 struct uhd_tx_streamer;
103
105
108 typedef struct uhd_rx_streamer* uhd_rx_streamer_handle;
109
111
114 typedef struct uhd_tx_streamer* uhd_tx_streamer_handle;
115
116 #ifdef __cplusplus
117 extern "C" {
118 #endif
119
120 /*
121  * RX Streamer
122  */
123
125
131 );
132
134
140 );
141
145  size_t *num_channels_out
146 );
147
151  size_t *max_num_samps_out
152 );
153
155
168  void** buffs,
169  size_t samps_per_buff,
171  double timeout,
172  bool one_packet,
173  size_t *items_recvd
174 );
175
177
182  const uhd_stream_cmd_t *stream_cmd
183 );
184
186
196  char* error_out,
197  size_t strbuffer_len
198 );
199
200 /*
201  * TX Streamer
202  */
203
205
211 );
212
214
220 );
221
225  size_t *num_channels_out
226 );
227
231  size_t *max_num_samps_out
232 );
233
235
247  const void **buffs,
248  size_t samps_per_buff,
250  double timeout,
251  size_t *items_sent
252 );
253
255
261  double timeout,
262  bool *valid
263 );
264
266
276  char* error_out,
277  size_t strbuffer_len
278 );
279
280 #ifdef __cplusplus
281 }
282 #endif
283
284 /****************************************************************************
285  * Public Datatypes for USRP / streamer handling.
286  ***************************************************************************/
287 struct uhd_usrp;
288
290 /*
291  * See uhd::usrp::multi_usrp for more details.
292  *
293  * NOTE: You must pass this handle into uhd_usrp_make before using it.
294  */
295 typedef struct uhd_usrp* uhd_usrp_handle;
296
297 /****************************************************************************
298  * USRP Make / Free API calls
299  ***************************************************************************/
300 #ifdef __cplusplus
301 extern "C" {
302 #endif
303
305
309  const char* args,
310  uhd_string_vector_handle *strings_out
311 );
312
314
319  uhd_usrp_handle *h,
320  const char *args
321 );
322
324
329  uhd_usrp_handle *h
330 );
331
334  uhd_usrp_handle h,
335  char* error_out,
336  size_t strbuffer_len
337 );
338
341  uhd_usrp_handle h,
342  uhd_stream_args_t *stream_args,
344 );
345
348  uhd_usrp_handle h,
349  uhd_stream_args_t *stream_args,
351 );
352
353 /****************************************************************************
354  * multi_usrp API calls
355  ***************************************************************************/
356
358
362  uhd_usrp_handle h,
363  size_t chan,
364  uhd_usrp_rx_info_t *info_out
365 );
366
368
372  uhd_usrp_handle h,
373  size_t chan,
374  uhd_usrp_tx_info_t *info_out
375 );
376
377 /****************************************************************************
378  * Motherboard methods
379  ***************************************************************************/
380
382
386  uhd_usrp_handle h,
387  double rate,
388  size_t mboard
389 );
390
392
396  uhd_usrp_handle h,
397  size_t mboard,
398  double *clock_rate_out
399 );
400
402
406  uhd_usrp_handle h,
407  char* pp_string_out,
408  size_t strbuffer_len
409 );
410
412
416  uhd_usrp_handle h,
417  size_t mboard,
418  char* mboard_name_out,
419  size_t strbuffer_len
420 );
421
423
427  uhd_usrp_handle h,
428  size_t mboard,
429  time_t *full_secs_out,
430  double *frac_secs_out
431 );
432
434
438  uhd_usrp_handle h,
439  size_t mboard,
440  time_t *full_secs_out,
441  double *frac_secs_out
442 );
443
445
449  uhd_usrp_handle h,
450  time_t full_secs,
451  double frac_secs,
452  size_t mboard
453 );
454
456
460  uhd_usrp_handle h,
461  time_t full_secs,
462  double frac_secs,
463  size_t mboard
464 );
465
467
471  uhd_usrp_handle h,
472  time_t full_secs,
473  double frac_secs
474 );
475
478  uhd_usrp_handle h,
479  bool *result_out
480 );
481
483
487  uhd_usrp_handle h,
488  time_t full_secs,
489  double frac_secs,
490  size_t mboard
491 );
492
495  uhd_usrp_handle h,
496  size_t mboard
497 );
498
500
504  uhd_usrp_handle h,
505  const char* time_source,
506  size_t mboard
507 );
508
510
514  uhd_usrp_handle h,
515  size_t mboard,
516  char* time_source_out,
517  size_t strbuffer_len
518 );
519
522  uhd_usrp_handle h,
523  size_t mboard,
524  uhd_string_vector_handle *time_sources_out
525 );
526
528
532  uhd_usrp_handle h,
533  const char* clock_source,
534  size_t mboard
535 );
536
538
542  uhd_usrp_handle h,
543  size_t mboard,
544  char* clock_source_out,
545  size_t strbuffer_len
546 );
547
550  uhd_usrp_handle h,
551  size_t mboard,
552  uhd_string_vector_handle *clock_sources_out
553 );
554
556
560  uhd_usrp_handle h,
561  bool enb,
562  size_t mboard
563 );
564
566
570  uhd_usrp_handle h,
571  bool enb,
572  size_t mboard
573 );
574
577  uhd_usrp_handle h,
578  size_t *num_mboards_out
579 );
580
583  uhd_usrp_handle h,
584  const char* name,
585  size_t mboard,
586  uhd_sensor_value_handle *sensor_value_out
587 );
588
591  uhd_usrp_handle h,
592  size_t mboard,
593  uhd_string_vector_handle *mboard_sensor_names_out
594 );
595
597
601  uhd_usrp_handle h,
602  uint8_t addr,
603  uint32_t data,
604  size_t mboard
605 );
606
607 /****************************************************************************
608  * EEPROM access methods
609  ***************************************************************************/
610
613  uhd_usrp_handle h,
614  uhd_mboard_eeprom_handle mb_eeprom,
615  size_t mboard
616 );
617
620  uhd_usrp_handle h,
621  uhd_mboard_eeprom_handle mb_eeprom,
622  size_t mboard
623 );
624
627  uhd_usrp_handle h,
628  uhd_dboard_eeprom_handle db_eeprom,
629  const char* unit,
630  const char* slot,
631  size_t mboard
632 );
633
636  uhd_usrp_handle h,
637  uhd_dboard_eeprom_handle db_eeprom,
638  const char* unit,
639  const char* slot,
640  size_t mboard
641 );
642
643 /****************************************************************************
644  * RX methods
645  ***************************************************************************/
646
648
652  uhd_usrp_handle h,
653  uhd_subdev_spec_handle subdev_spec,
654  size_t mboard
655 );
656
659  uhd_usrp_handle h,
660  size_t mboard,
661  uhd_subdev_spec_handle subdev_spec_out
662 );
663
666  uhd_usrp_handle h,
667  size_t *num_channels_out
668 );
669
672  uhd_usrp_handle h,
673  size_t chan,
674  char* rx_subdev_name_out,
675  size_t strbuffer_len
676 );
677
680  uhd_usrp_handle h,
681  double rate,
682  size_t chan
683 );
684
687  uhd_usrp_handle h,
688  size_t chan,
689  double *rate_out
690 );
691
694  uhd_usrp_handle h,
695  size_t chan,
696  uhd_meta_range_handle rates_out
697 );
698
701  uhd_usrp_handle h,
702  uhd_tune_request_t *tune_request,
703  size_t chan,
704  uhd_tune_result_t *tune_result
705 );
706
709  uhd_usrp_handle h,
710  size_t chan,
711  double *freq_out
712 );
713
715
719  uhd_usrp_handle h,
720  size_t chan,
721  uhd_meta_range_handle freq_range_out
722 );
723
726  uhd_usrp_handle h,
727  size_t chan,
728  uhd_meta_range_handle freq_range_out
729 );
730
733  uhd_usrp_handle h,
734  double gain,
735  size_t chan,
736  const char *gain_name
737 );
738
740
744  uhd_usrp_handle h,
745  double gain,
746  size_t chan
747 );
748
750
754  uhd_usrp_handle h,
755  bool enable,
756  size_t chan
757 );
758
761  uhd_usrp_handle h,
762  size_t chan,
763  const char *gain_name,
764  double *gain_out
765 );
766
768
772  uhd_usrp_handle h,
773  size_t chan,
774  double *gain_out
775 );
776
779  uhd_usrp_handle h,
780  const char* name,
781  size_t chan,
782  uhd_meta_range_handle gain_range_out
783 );
784
787  uhd_usrp_handle h,
788  size_t chan,
789  uhd_string_vector_handle *gain_names_out
790 );
791
794  uhd_usrp_handle h,
795  const char* ant,
796  size_t chan
797 );
798
801  uhd_usrp_handle h,
802  size_t chan,
803  char* ant_out,
804  size_t strbuffer_len
805 );
806
809  uhd_usrp_handle h,
810  size_t chan,
811  uhd_string_vector_handle *antennas_out
812 );
813
816  uhd_usrp_handle h,
817  size_t chan,
818  uhd_string_vector_handle *sensor_names_out
819 );
820
823  uhd_usrp_handle h,
824  double bandwidth,
825  size_t chan
826 );
827
830  uhd_usrp_handle h,
831  size_t chan,
832  double *bandwidth_out
833 );
834
837  uhd_usrp_handle h,
838  size_t chan,
839  uhd_meta_range_handle bandwidth_range_out
840 );
841
844  uhd_usrp_handle h,
845  const char* name,
846  size_t chan,
847  uhd_sensor_value_handle *sensor_value_out
848 );
849
851
855  uhd_usrp_handle h,
856  bool enb,
857  size_t chan
858 );
859
862  uhd_usrp_handle h,
863  bool enb,
864  size_t chan
865 );
866
867 /****************************************************************************
868  * TX methods
869  ***************************************************************************/
870
872
876  uhd_usrp_handle h,
877  uhd_subdev_spec_handle subdev_spec,
878  size_t mboard
879 );
880
883  uhd_usrp_handle h,
884  size_t mboard,
885  uhd_subdev_spec_handle subdev_spec_out
886 );
887
890  uhd_usrp_handle h,
891  size_t *num_channels_out
892 );
893
896  uhd_usrp_handle h,
897  size_t chan,
898  char* tx_subdev_name_out,
899  size_t strbuffer_len
900 );
901
904  uhd_usrp_handle h,
905  double rate,
906  size_t chan
907 );
908
911  uhd_usrp_handle h,
912  size_t chan,
913  double *rate_out
914 );
915
918  uhd_usrp_handle h,
919  size_t chan,
920  uhd_meta_range_handle rates_out
921 );
922
925  uhd_usrp_handle h,
926  uhd_tune_request_t *tune_request,
927  size_t chan,
928  uhd_tune_result_t *tune_result
929 );
930
933  uhd_usrp_handle h,
934  size_t chan,
935  double *freq_out
936 );
937
939
943  uhd_usrp_handle h,
944  size_t chan,
945  uhd_meta_range_handle freq_range_out
946 );
947
950  uhd_usrp_handle h,
951  size_t chan,
952  uhd_meta_range_handle freq_range_out
953 );
954
957  uhd_usrp_handle h,
958  double gain,
959  size_t chan,
960  const char *gain_name
961 );
962
964
968  uhd_usrp_handle h,
969  double gain,
970  size_t chan
971 );
972
975  uhd_usrp_handle h,
976  const char* name,
977  size_t chan,
978  uhd_meta_range_handle gain_range_out
979 );
980
983  uhd_usrp_handle h,
984  size_t chan,
985  const char *gain_name,
986  double *gain_out
987 );
988
990
994  uhd_usrp_handle h,
995  size_t chan,
996  double *gain_out
997 );
998
1001  uhd_usrp_handle h,
1002  size_t chan,
1003  uhd_string_vector_handle *gain_names_out
1004 );
1005
1008  uhd_usrp_handle h,
1009  const char* ant,
1010  size_t chan
1011 );
1012
1015  uhd_usrp_handle h,
1016  size_t chan,
1017  char* ant_out,
1018  size_t strbuffer_len
1019 );
1020
1023  uhd_usrp_handle h,
1024  size_t chan,
1025  uhd_string_vector_handle *antennas_out
1026 );
1027
1030  uhd_usrp_handle h,
1031  double bandwidth,
1032  size_t chan
1033 );
1034
1037  uhd_usrp_handle h,
1038  size_t chan,
1039  double *bandwidth_out
1040 );
1041
1044  uhd_usrp_handle h,
1045  size_t chan,
1046  uhd_meta_range_handle bandwidth_range_out
1047 );
1048
1051  uhd_usrp_handle h,
1052  const char* name,
1053  size_t chan,
1054  uhd_sensor_value_handle *sensor_value_out
1055 );
1056
1059  uhd_usrp_handle h,
1060  size_t chan,
1061  uhd_string_vector_handle *sensor_names_out
1062 );
1063
1065
1069  uhd_usrp_handle h,
1070  bool enb,
1071  size_t chan
1072 );
1073
1076  uhd_usrp_handle h,
1077  bool enb,
1078  size_t chan
1079 );
1080
1081 /****************************************************************************
1082  * GPIO methods
1083  ***************************************************************************/
1084
1087  uhd_usrp_handle h,
1088  size_t mboard,
1089  uhd_string_vector_handle *gpio_banks_out
1090 );
1091
1093
1097  uhd_usrp_handle h,
1098  const char* bank,
1099  const char* attr,
1100  uint32_t value,
1101  uint32_t mask,
1102  size_t mboard
1103 );
1104
1106
1110  uhd_usrp_handle h,
1111  const char* bank,
1112  const char* attr,
1113  size_t mboard,
1114  uint32_t *attr_out
1115 );
1116
1119  uhd_usrp_handle h,
1120  size_t mboard,
1121  uhd_string_vector_handle *registers_out
1122 );
1123
1126  uhd_usrp_handle h,
1127  const char* path,
1128  size_t mboard,
1129  uhd_usrp_register_info_t *register_info_out
1130 );
1131
1134  uhd_usrp_handle h,
1135  const char* path,
1136  uint32_t field,
1137  uint64_t value,
1138  size_t mboard
1139 );
1140
1143  uhd_usrp_handle h,
1144  const char* path,
1145  uint32_t field,
1146  size_t mboard,
1147  uint64_t *value_out
1148 );
1149
1150 #ifdef __cplusplus
1151 }
1152 #endif
1153
1154 #endif /* INCLUDED_UHD_USRP_H */
Stream samples indefinitely.
Definition: usrp.h:75
UHD_API uhd_error uhd_usrp_set_tx_freq(uhd_usrp_handle h, uhd_tune_request_t *tune_request, size_t chan, uhd_tune_result_t *tune_result)
Set the given channel&#39;s center TX frequency.
UHD_API uhd_error uhd_usrp_set_clock_source(uhd_usrp_handle h, const char *clock_source, size_t mboard)
Set the given device&#39;s clock source.
UHD_API uhd_error uhd_usrp_set_tx_antenna(uhd_usrp_handle h, const char *ant, size_t chan)
Set the TX antenna for the given channel.
UHD_API uhd_error uhd_usrp_get_time_source(uhd_usrp_handle h, size_t mboard, char *time_source_out, size_t strbuffer_len)
Get the time source for the given device.
bool stream_now
Stream now?
Definition: usrp.h:94
UHD_API uhd_error uhd_usrp_set_rx_agc(uhd_usrp_handle h, bool enable, size_t chan)
Enable or disable the given channel&#39;s RX AGC module.
struct uhd_rx_metadata_t * uhd_rx_metadata_handle
RX metadata interface for describing sent IF data.
Definition: metadata.h:62
UHD_API uhd_error uhd_usrp_enumerate_registers(uhd_usrp_handle h, size_t mboard, uhd_string_vector_handle *registers_out)
Enumerate the full paths of USRP registers available for read/write.
UHD_API uhd_error uhd_usrp_set_gpio_attr(uhd_usrp_handle h, const char *bank, const char *attr, uint32_t value, uint32_t mask, size_t mboard)
Set a GPIO attribute for a given GPIO bank.
UHD_API uhd_error uhd_usrp_get_time_now(uhd_usrp_handle h, size_t mboard, time_t *full_secs_out, double *frac_secs_out)
Get the USRP device&#39;s current internal time.
UHD_API uhd_error uhd_usrp_set_tx_rate(uhd_usrp_handle h, double rate, size_t chan)
Set the given RX channel&#39;s sample rate (in Sps)
UHD_API uhd_error uhd_usrp_get_rx_antenna(uhd_usrp_handle h, size_t chan, char *ant_out, size_t strbuffer_len)
Get the RX antenna for the given channel.
UHD_API uhd_error uhd_usrp_get_rx_antennas(uhd_usrp_handle h, size_t chan, uhd_string_vector_handle *antennas_out)
Get a list of RX antennas associated with the given channels.
A struct of parameters to construct a stream.
Definition: usrp.h:56
UHD_API uhd_error uhd_usrp_get_tx_sensor_names(uhd_usrp_handle h, size_t chan, uhd_string_vector_handle *sensor_names_out)
Get a list of TX sensors associated with the given channels.
UHD_API uhd_error uhd_usrp_get_rx_stream(uhd_usrp_handle h, uhd_stream_args_t *stream_args, uhd_rx_streamer_handle h_out)
Create RX streamer from a USRP handle and given stream args.
bool readable
Definition: usrp.h:44
UHD_API uhd_error uhd_usrp_get_tx_gain_range(uhd_usrp_handle h, const char *name, size_t chan, uhd_meta_range_handle gain_range_out)
Get all possible gain ranges for the given channel and name.
uhd_stream_mode_t stream_mode
How streaming is issued to the device.
Definition: usrp.h:90
UHD_API uhd_error uhd_usrp_set_time_source(uhd_usrp_handle h, const char *time_source, size_t mboard)
Set the time source for the given device.
Definition: ranges.h:55
UHD_API uhd_error uhd_usrp_get_tx_antenna(uhd_usrp_handle h, size_t chan, char *ant_out, size_t strbuffer_len)
Get the TX antenna for the given channel.
size_t mask(const soft_reg_field_t field)
Definition: soft_register.hpp:98
UHD_API uhd_error uhd_usrp_get_gpio_attr(uhd_usrp_handle h, const char *bank, const char *attr, size_t mboard, uint32_t *attr_out)
Get a GPIO attribute on a particular GPIO bank.
UHD_API uhd_error uhd_usrp_get_tx_subdev_name(uhd_usrp_handle h, size_t chan, char *tx_subdev_name_out, size_t strbuffer_len)
Get the name for the RX frontend.
UHD_API uhd_error uhd_usrp_set_mboard_eeprom(uhd_usrp_handle h, uhd_mboard_eeprom_handle mb_eeprom, size_t mboard)
Set values in the given motherboard&#39;s EEPROM.
UHD_API uhd_error uhd_usrp_set_user_register(uhd_usrp_handle h, uint8_t addr, uint32_t data, size_t mboard)
Perform a write on a user configuration register bus.
UHD_API uhd_error uhd_usrp_set_tx_dc_offset_enabled(uhd_usrp_handle h, bool enb, size_t chan)
Enable or disable TX DC offset correction for the given channel.
double time_spec_frac_secs
If not now, then fractional seconds into future to stream.
Definition: usrp.h:98
bool writable
Definition: usrp.h:45
struct uhd_tx_metadata_t * uhd_tx_metadata_handle
TX metadata interface for describing received IF data.
Definition: metadata.h:71
struct uhd_usrp * uhd_usrp_handle
C-level interface for working with a USRP device.
Definition: usrp.h:295
UHD_API uhd_error uhd_usrp_set_normalized_rx_gain(uhd_usrp_handle h, double gain, size_t chan)
Set the normalized RX gain [0.0, 1.0] for the given channel.
UHD_API uhd_error uhd_tx_streamer_last_error(uhd_tx_streamer_handle h, char *error_out, size_t strbuffer_len)
Get the last error reported by the TX streamer.
UHD_API uhd_error uhd_usrp_get_num_mboards(uhd_usrp_handle h, size_t *num_mboards_out)
Get the number of devices associated with the given USRP handle.
UHD_API uhd_error uhd_usrp_get_mboard_sensor(uhd_usrp_handle h, const char *name, size_t mboard, uhd_sensor_value_handle *sensor_value_out)
Get the value associated with the given sensor name.
UHD_API uhd_error uhd_usrp_get_time_synchronized(uhd_usrp_handle h, bool *result_out)
Are all motherboard times synchronized?
UHD_API uhd_error uhd_usrp_get_tx_antennas(uhd_usrp_handle h, size_t chan, uhd_string_vector_handle *antennas_out)
Get a list of tx antennas associated with the given channels.
UHD_API uhd_error uhd_tx_streamer_num_channels(uhd_tx_streamer_handle h, size_t *num_channels_out)
Get the number of channels associated with this streamer.
UHD_API uhd_error uhd_rx_streamer_make(uhd_rx_streamer_handle *h)
Create an RX streamer handle.
UHD_API uhd_error uhd_usrp_set_time_now(uhd_usrp_handle h, time_t full_secs, double frac_secs, size_t mboard)
Set the USRP device&#39;s time.
struct uhd_mboard_eeprom_t * uhd_mboard_eeprom_handle
A C-level interface for interacting with a USRP motherboard&#39;s EEPROM.
Definition: mboard_eeprom.h:45
UHD_API uhd_error uhd_usrp_make(uhd_usrp_handle *h, const char *args)
Create a USRP handle.
Stores RF and DSP tuned frequencies.
Definition: tune_result.h:29
End continuous streaming.
Definition: usrp.h:77
size_t bitwidth
Definition: usrp.h:43
char * cpu_format
Format of host memory.
Definition: usrp.h:58
UHD_API uhd_error uhd_usrp_set_normalized_tx_gain(uhd_usrp_handle h, double gain, size_t chan)
Set the normalized TX gain [0.0, 1.0] for the given channel.
Register info.
Definition: usrp.h:42
char * args
Other stream args.
Definition: usrp.h:62
UHD_API uhd_error uhd_usrp_get_rx_sensor(uhd_usrp_handle h, const char *name, size_t chan, uhd_sensor_value_handle *sensor_value_out)
Get the value for the given RX sensor.
UHD_API uhd_error uhd_rx_streamer_recv(uhd_rx_streamer_handle h, void **buffs, size_t samps_per_buff, uhd_rx_metadata_handle *md, double timeout, bool one_packet, size_t *items_recvd)
Receive buffers containing samples into the given RX streamer.
UHD_API uhd_error uhd_usrp_get_tx_bandwidth(uhd_usrp_handle h, size_t chan, double *bandwidth_out)
Get the bandwidth for the given channel&#39;s TX frontend.
UHD_API uhd_error uhd_usrp_get_rx_bandwidth(uhd_usrp_handle h, size_t chan, double *bandwidth_out)
Get the bandwidth for the given channel&#39;s RX frontend.
UHD_API uhd_error uhd_usrp_get_tx_num_channels(uhd_usrp_handle h, size_t *num_channels_out)
Get the number of TX channels for the given handle.
UHD_API uhd_error uhd_usrp_get_register_info(uhd_usrp_handle h, const char *path, size_t mboard, uhd_usrp_register_info_t *register_info_out)
Get more information about a low-level device register.
UHD_API uhd_error uhd_usrp_get_tx_bandwidth_range(uhd_usrp_handle h, size_t chan, uhd_meta_range_handle bandwidth_range_out)
Get all possible bandwidth ranges for the given channel&#39;s TX frontend.
UHD_API uhd_error uhd_usrp_set_rx_dc_offset_enabled(uhd_usrp_handle h, bool enb, size_t chan)
Enable or disable RX DC offset correction for the given channel.
UHD_API uhd_error uhd_usrp_get_tx_sensor(uhd_usrp_handle h, const char *name, size_t chan, uhd_sensor_value_handle *sensor_value_out)
Get the value for the given TX sensor.
UHD_API uhd_error uhd_usrp_get_rx_freq_range(uhd_usrp_handle h, size_t chan, uhd_meta_range_handle freq_range_out)
Get all possible center frequency ranges for the given channel.
Stream some number of samples and finish.
Definition: usrp.h:79
UHD_API uhd_error uhd_usrp_get_tx_gain(uhd_usrp_handle h, size_t chan, const char *gain_name, double *gain_out)
Get the given channel&#39;s RX gain.
UHD_API uhd_error uhd_usrp_get_fe_rx_freq_range(uhd_usrp_handle h, size_t chan, uhd_meta_range_handle freq_range_out)
Get all possible RF frequency ranges for the given channel&#39;s RX RF frontend.
UHD_API uhd_error uhd_usrp_get_gpio_banks(uhd_usrp_handle h, size_t mboard, uhd_string_vector_handle *gpio_banks_out)
Get a list of GPIO banks associated with the given channels.
UHD_API uhd_error uhd_usrp_set_tx_gain(uhd_usrp_handle h, double gain, size_t chan, const char *gain_name)
Set the TX gain for the given channel and name.
UHD_API uhd_error uhd_usrp_get_pp_string(uhd_usrp_handle h, char *pp_string_out, size_t strbuffer_len)
Get a pretty-print representation of the USRP device.
UHD_API uhd_error uhd_usrp_get_tx_stream(uhd_usrp_handle h, uhd_stream_args_t *stream_args, uhd_tx_streamer_handle h_out)
Create TX streamer from a USRP handle and given stream args.
UHD_API uhd_error uhd_tx_streamer_make(uhd_tx_streamer_handle *h)
Create an TX streamer handle.
UHD_API uhd_error uhd_usrp_get_rx_sensor_names(uhd_usrp_handle h, size_t chan, uhd_string_vector_handle *sensor_names_out)
Get a list of RX sensors associated with the given channels.
UHD_API uhd_error uhd_usrp_get_rx_freq(uhd_usrp_handle h, size_t chan, double *freq_out)
Get the given channel&#39;s center RX frequency.
UHD_API uhd_error uhd_rx_streamer_max_num_samps(uhd_rx_streamer_handle h, size_t *max_num_samps_out)
Get the max number of samples per buffer per packet.
struct uhd_async_metadata_t * uhd_async_metadata_handle
Interface for describing transmit-related events.
Definition: metadata.h:80
UHD_API uhd_error uhd_usrp_get_tx_freq(uhd_usrp_handle h, size_t chan, double *freq_out)
Get the given channel&#39;s center TX frequency.
UHD_API uhd_error uhd_usrp_get_rx_num_channels(uhd_usrp_handle h, size_t *num_channels_out)
Get the number of RX channels for the given handle.
uhd_error
UHD error codes.
Definition: error.h:31
UHD_API uhd_error uhd_usrp_clear_command_time(uhd_usrp_handle h, size_t mboard)
Clear the command time so that commands are sent ASAP.
UHD_API uhd_error uhd_usrp_get_rx_gain_names(uhd_usrp_handle h, size_t chan, uhd_string_vector_handle *gain_names_out)
Get a list of RX gain names for the given channel.
USRP RX info.
Definition: usrp_info.h:28
struct uhd_dboard_eeprom_t * uhd_dboard_eeprom_handle
A C-level interface for interacting with a daughterboard EEPROM.
Definition: dboard_eeprom.h:45
Define how device streams to host.
Definition: usrp.h:88
UHD_API uhd_error uhd_usrp_get_dboard_eeprom(uhd_usrp_handle h, uhd_dboard_eeprom_handle db_eeprom, const char *unit, const char *slot, size_t mboard)
Get a handle for the given device&#39;s daughterboard EEPROM.
UHD_API uhd_error uhd_usrp_set_time_unknown_pps(uhd_usrp_handle h, time_t full_secs, double frac_secs)
Synchronize the time across all motherboards.
UHD_API uhd_error uhd_usrp_set_command_time(uhd_usrp_handle h, time_t full_secs, double frac_secs, size_t mboard)
Set the time at which timed commands will take place.
UHD_API uhd_error uhd_usrp_get_time_sources(uhd_usrp_handle h, size_t mboard, uhd_string_vector_handle *time_sources_out)
Get a list of time sources for the given device.
UHD_API uhd_error uhd_usrp_set_tx_subdev_spec(uhd_usrp_handle h, uhd_subdev_spec_handle subdev_spec, size_t mboard)
Map the given device&#39;s TX frontend to a channel.
UHD_API uhd_error uhd_usrp_get_rx_info(uhd_usrp_handle h, size_t chan, uhd_usrp_rx_info_t *info_out)
Get RX info from the USRP device.
UHD_API uhd_error uhd_usrp_get_tx_subdev_spec(uhd_usrp_handle h, size_t mboard, uhd_subdev_spec_handle subdev_spec_out)
Get the TX frontend specification for the given device.
UHD_API uhd_error uhd_usrp_get_tx_rate(uhd_usrp_handle h, size_t chan, double *rate_out)
Get the given RX channel&#39;s sample rate (in Sps)
UHD_API uhd_error uhd_usrp_get_time_last_pps(uhd_usrp_handle h, size_t mboard, time_t *full_secs_out, double *frac_secs_out)
Get the time when this device&#39;s last PPS pulse occurred.
UHD_API uhd_error uhd_usrp_set_tx_bandwidth(uhd_usrp_handle h, double bandwidth, size_t chan)
Set the bandwidth for the given channel&#39;s TX frontend.
UHD_API uhd_error uhd_usrp_set_rx_iq_balance_enabled(uhd_usrp_handle h, bool enb, size_t chan)
Enable or disable RX IQ imbalance correction for the given channel.
UHD_API uhd_error uhd_tx_streamer_free(uhd_tx_streamer_handle *h)
Free an TX streamer handle.
UHD_API uhd_error uhd_rx_streamer_issue_stream_cmd(uhd_rx_streamer_handle h, const uhd_stream_cmd_t *stream_cmd)
Issue the given stream command.
UHD_API uhd_error uhd_usrp_set_rx_gain(uhd_usrp_handle h, double gain, size_t chan, const char *gain_name)
Set the RX gain for the given channel and name.
UHD_API uhd_error uhd_usrp_free(uhd_usrp_handle *h)
Safely destroy the USRP object underlying the handle.
UHD_API uhd_error uhd_usrp_get_fe_tx_freq_range(uhd_usrp_handle h, size_t chan, uhd_meta_range_handle freq_range_out)
Get all possible RF frequency ranges for the given channel&#39;s TX RF frontend.
UHD_API uhd_error uhd_usrp_read_register(uhd_usrp_handle h, const char *path, uint32_t field, size_t mboard, uint64_t *value_out)
Read a low-level register field from a device register in the USRP hardware.
UHD_API uhd_error uhd_usrp_set_master_clock_rate(uhd_usrp_handle h, double rate, size_t mboard)
Set the master clock rate.
UHD_API uhd_error uhd_usrp_get_rx_subdev_name(uhd_usrp_handle h, size_t chan, char *rx_subdev_name_out, size_t strbuffer_len)
UHD_API uhd_error uhd_usrp_get_tx_info(uhd_usrp_handle h, size_t chan, uhd_usrp_tx_info_t *info_out)
Get TX info from the USRP device.
UHD_API uhd_error uhd_usrp_set_tx_iq_balance_enabled(uhd_usrp_handle h, bool enb, size_t chan)
Enable or disable TX IQ imbalance correction for the given channel.
uhd_stream_mode_t
Definition: usrp.h:73
UHD_API uhd_error uhd_rx_streamer_last_error(uhd_rx_streamer_handle h, char *error_out, size_t strbuffer_len)
Get the last error reported by the RX streamer.
struct uhd_rx_streamer * uhd_rx_streamer_handle
C-level interface for working with an RX streamer.
Definition: usrp.h:108
UHD_API uhd_error uhd_usrp_set_time_source_out(uhd_usrp_handle h, bool enb, size_t mboard)
Enable or disable sending the time source to an output connector.
UHD_API uhd_error uhd_usrp_get_tx_freq_range(uhd_usrp_handle h, size_t chan, uhd_meta_range_handle freq_range_out)
UHD_API uhd_error uhd_usrp_set_rx_subdev_spec(uhd_usrp_handle h, uhd_subdev_spec_handle subdev_spec, size_t mboard)
Map the given device&#39;s RX frontend to a channel.
UHD_API uhd_error uhd_usrp_last_error(uhd_usrp_handle h, char *error_out, size_t strbuffer_len)
Get the last error reported by the USRP handle.
UHD_API uhd_error uhd_usrp_get_rx_rates(uhd_usrp_handle h, size_t chan, uhd_meta_range_handle rates_out)
Get a range of possible RX rates for the given channel.
uhd_string_vector_t * uhd_string_vector_handle
Definition: string_vector.h:43
USRP TX info.
Definition: usrp_info.h:51
Definition: config.h:66
UHD_API uhd_error uhd_usrp_get_rx_gain_range(uhd_usrp_handle h, const char *name, size_t chan, uhd_meta_range_handle gain_range_out)
UHD_API uhd_error uhd_usrp_write_register(uhd_usrp_handle h, const char *path, uint32_t field, uint64_t value, size_t mboard)
Write a low-level register field for a device register in the USRP hardware.
Instructs implementation how to tune the RF chain.
Definition: tune_request.h:39
UHD_API uhd_error uhd_tx_streamer_max_num_samps(uhd_tx_streamer_handle h, size_t *max_num_samps_out)
UHD_API uhd_error uhd_usrp_get_rx_gain(uhd_usrp_handle h, size_t chan, const char *gain_name, double *gain_out)
Stream some number of samples but expect more.
Definition: usrp.h:81
Definition: sensors.h:44
UHD_API uhd_error uhd_usrp_set_rx_rate(uhd_usrp_handle h, double rate, size_t chan)
size_t * channel_list
Array that lists channels.
Definition: usrp.h:64
UHD_API uhd_error uhd_usrp_get_mboard_sensor_names(uhd_usrp_handle h, size_t mboard, uhd_string_vector_handle *mboard_sensor_names_out)
Get a list of motherboard sensors for the given device.
UHD_API uhd_error uhd_tx_streamer_send(uhd_tx_streamer_handle h, const void **buffs, size_t samps_per_buff, uhd_tx_metadata_handle *md, double timeout, size_t *items_sent)
Send buffers containing samples described by the metadata.
int n_channels
Number of channels.
Definition: usrp.h:66
UHD_API uhd_error uhd_usrp_get_tx_rates(uhd_usrp_handle h, size_t chan, uhd_meta_range_handle rates_out)
UHD_API uhd_error uhd_usrp_set_clock_source_out(uhd_usrp_handle h, bool enb, size_t mboard)
Enable or disable sending the clock source to an output connector.
UHD_API uhd_error uhd_usrp_get_tx_gain_names(uhd_usrp_handle h, size_t chan, uhd_string_vector_handle *gain_names_out)
Get a list of TX gain names for the given channel.
UHD_API uhd_error uhd_tx_streamer_recv_async_msg(uhd_tx_streamer_handle h, uhd_async_metadata_handle *md, double timeout, bool *valid)
Receive an asynchronous message from this streamer.
UHD_API uhd_error uhd_usrp_get_mboard_name(uhd_usrp_handle h, size_t mboard, char *mboard_name_out, size_t strbuffer_len)
Get the motherboard name for the given device.
UHD_API uhd_error uhd_usrp_set_rx_antenna(uhd_usrp_handle h, const char *ant, size_t chan)
Set the RX antenna for the given channel.
UHD_API uhd_error uhd_rx_streamer_num_channels(uhd_rx_streamer_handle h, size_t *num_channels_out)
struct uhd_subdev_spec_t * uhd_subdev_spec_handle
A C-level interface for working with a list of subdevice specifications.
Definition: subdev_spec.h:55
UHD_API uhd_error uhd_usrp_set_rx_freq(uhd_usrp_handle h, uhd_tune_request_t *tune_request, size_t chan, uhd_tune_result_t *tune_result)
Set the given channel&#39;s center RX frequency.
UHD_API uhd_error uhd_usrp_get_normalized_rx_gain(uhd_usrp_handle h, size_t chan, double *gain_out)
Get the given channel&#39;s normalized RX gain [0.0, 1.0].
size_t num_samps
Number of samples.
Definition: usrp.h:92
UHD_API uhd_error uhd_usrp_get_rx_subdev_spec(uhd_usrp_handle h, size_t mboard, uhd_subdev_spec_handle subdev_spec_out)
Get the RX frontend specification for the given device.
UHD_API uhd_error uhd_usrp_get_clock_sources(uhd_usrp_handle h, size_t mboard, uhd_string_vector_handle *clock_sources_out)
Get a list of clock sources for the given device.
UHD_API uhd_error uhd_usrp_get_normalized_tx_gain(uhd_usrp_handle h, size_t chan, double *gain_out)
Get the given channel&#39;s normalized TX gain [0.0, 1.0].
UHD_API uhd_error uhd_usrp_set_rx_bandwidth(uhd_usrp_handle h, double bandwidth, size_t chan)
Set the bandwidth for the given channel&#39;s RX frontend.
UHD_API uhd_error uhd_usrp_set_time_next_pps(uhd_usrp_handle h, time_t full_secs, double frac_secs, size_t mboard)
Set the USRP device&#39;s time to the given value upon the next PPS detection.
struct uhd_tx_streamer * uhd_tx_streamer_handle
C-level interface for working with a TX streamer.
Definition: usrp.h:114
UHD_API uhd_error uhd_usrp_get_rx_rate(uhd_usrp_handle h, size_t chan, double *rate_out)
UHD_API uhd_error uhd_usrp_get_clock_source(uhd_usrp_handle h, size_t mboard, char *clock_source_out, size_t strbuffer_len)
Get the given device&#39;s clock source.
UHD_API uhd_error uhd_usrp_get_rx_bandwidth_range(uhd_usrp_handle h, size_t chan, uhd_meta_range_handle bandwidth_range_out)
Get all possible bandwidth ranges for the given channel&#39;s RX frontend.
UHD_API uhd_error uhd_usrp_find(const char *args, uhd_string_vector_handle *strings_out)
Find all connected USRP devices.
UHD_API uhd_error uhd_usrp_get_mboard_eeprom(uhd_usrp_handle h, uhd_mboard_eeprom_handle mb_eeprom, size_t mboard)
Get a handle for the given motherboard&#39;s EEPROM.
UHD_API uhd_error uhd_usrp_get_master_clock_rate(uhd_usrp_handle h, size_t mboard, double *clock_rate_out)
Get the master clock rate.
UHD_API uhd_error uhd_usrp_set_dboard_eeprom(uhd_usrp_handle h, uhd_dboard_eeprom_handle db_eeprom, const char *unit, const char *slot, size_t mboard)
Set values in the given daughterboard&#39;s EEPROM.
char * otw_format
Over-the-wire format.
Definition: usrp.h:60
time_t time_spec_full_secs
If not now, then full seconds into future to stream.
Definition: usrp.h:96
UHD_API uhd_error uhd_rx_streamer_free(uhd_rx_streamer_handle *h)
Free an RX streamer handle.
