blockdef.hpp
2 // Copyright 2014-2015 Ettus Research LLC
18 #ifndef INCLUDED_LIBUHD_RFNOC_BLOCKDEF_HPP
19 #define INCLUDED_LIBUHD_RFNOC_BLOCKDEF_HPP
21 #include <boost/cstdint.hpp>
22 #include <boost/enable_shared_from_this.hpp>
23 #include <uhd/config.hpp>
25 #include <vector>
26 #include <set>
27
28 namespace uhd { namespace rfnoc {
29
32 class UHD_RFNOC_API blockdef : public boost::enable_shared_from_this<blockdef>
33 {
34 public:
35  typedef boost::shared_ptr<blockdef> sptr;
36
38  //
39  // This is not the same as a uhd::rfnoc::stream_sig_t. This is used
40  // to describe which ports are defined in a block definition, and
41  // to describe what kind of connection is allowed for this port.
42  //
43  // All the keys listed in PORT_ARGS will be available in this class.
44  class port_t : public uhd::dict<std::string, std::string> {
45  public:
47  static const device_addr_t PORT_ARGS;
48
49  port_t();
50
52  bool is_variable(const std::string &key) const;
54  bool is_keyword(const std::string &key) const;
56  // keywords are not resolved.
57  bool is_valid() const;
59  std::string to_string() const;
60  };
61  typedef std::vector<port_t> ports_t;
62
64  class arg_t : public uhd::dict<std::string, std::string> {
65  public:
67  static const device_addr_t ARG_ARGS;
68  static const std::set<std::string> VALID_TYPES;
69
70  arg_t();
71
73  bool is_valid() const;
75  std::string to_string() const;
76
77  };
78  typedef std::vector<arg_t> args_t;
79
81
88  static sptr make_from_noc_id(boost::uint64_t noc_id);
89
91  virtual bool is_block() const = 0;
92
94  virtual bool is_component() const = 0;
95
97  virtual std::string get_key() const = 0;
98
100  virtual std::string get_name() const = 0;
101
103  virtual boost::uint64_t noc_id() const = 0;
104
105  virtual ports_t get_input_ports() = 0;
106  virtual ports_t get_output_ports() = 0;
107
109  virtual std::vector<size_t> get_all_port_numbers() = 0;
110
112  //
113  // \throws uhd::runtime_error if args are invalid.
114  virtual args_t get_args() = 0;
115
117  virtual registers_t get_settings_registers() = 0;
118
120  virtual registers_t get_readback_registers() = 0;
121 };
122
123 }} /* namespace uhd::rfnoc */
124
125 #endif /* INCLUDED_LIBUHD_RFNOC_BLOCKDEF_HPP */
126 // vim: sw=4 et:
Definition: blockdef.hpp:32
uhd::dict< std::string, size_t > registers_t
Definition: blockdef.hpp:80
Definition: dict.hpp:30
static const std::set< std::string > VALID_TYPES
Definition: blockdef.hpp:68
std::vector< arg_t > args_t
Definition: blockdef.hpp:78
Definition: build_info.hpp:25
#define UHD_RFNOC_API
Definition: config.hpp:103
boost::shared_ptr< blockdef > sptr
Definition: blockdef.hpp:35
Describes port options for a block definition.
Definition: blockdef.hpp:44
A list of args a port can have.
Definition: blockdef.hpp:47
A list of args an argument can have.
Definition: blockdef.hpp:67
Describes arguments in a block definition.
Definition: blockdef.hpp:64
std::vector< port_t > ports_t
Definition: blockdef.hpp:61
