18 #ifndef INCLUDED_LIBUHD_RFNOC_CONSTANTS_HPP    19 #define INCLUDED_LIBUHD_RFNOC_CONSTANTS_HPP    22 #include <boost/assign/list_of.hpp>    23 #include <boost/cstdint.hpp>    31 static const std::string XML_DEFAULT_PATH =
"share/uhd/rfnoc";
    33 static const std::string XML_PATH_ENV =
"UHD_RFNOC_DIR";
    36 static const std::string DEFAULT_BLOCK_NAME =
"Block";
    37 static const boost::uint64_t DEFAULT_NOC_ID = 0xFFFFFFFFFFFFFFFF;
    39 static const size_t MAX_PACKET_SIZE = 8000;
    40 static const size_t DEFAULT_PACKET_SIZE = 1456;
    43 static const size_t BYTES_PER_LINE = 8;
    46 static const size_t DEFAULT_FC_XBAR_PKTS_PER_ACK = 2;
    48 static const size_t DEFAULT_FC_RX_RESPONSE_FREQ = 64;
    50 static const size_t DEFAULT_FC_TX_RESPONSE_FREQ = 8;
    56 static const double DEFAULT_FC_RX_SW_BUFF_FULL_FACTOR = 0.80;
    59 static const boost::uint32_t SR_FLOW_CTRL_CYCS_PER_ACK          = 0;
    60 static const boost::uint32_t SR_FLOW_CTRL_PKTS_PER_ACK          = 1;
    61 static const boost::uint32_t SR_FLOW_CTRL_WINDOW_SIZE           = 2;
    62 static const boost::uint32_t SR_FLOW_CTRL_WINDOW_EN             = 3;
    63 static const boost::uint32_t SR_ERROR_POLICY                    = 4;
    64 static const boost::uint32_t SR_BLOCK_SID                       = 5;
    65 static const boost::uint32_t SR_NEXT_DST_SID                    = 6;
    66 static const boost::uint32_t SR_RESP_IN_DST_SID                 = 7;
    67 static const boost::uint32_t SR_RESP_OUT_DST_SID                = 8;
    69 static const boost::uint32_t SR_READBACK_ADDR                   = 124;
    70 static const boost::uint32_t SR_READBACK                        = 127;
    72 static const boost::uint32_t SR_CLEAR_RX_FC                     = 125;
    73 static const boost::uint32_t SR_CLEAR_TX_FC                     = 126;
    87 static const boost::uint32_t AXI_WRAPPER_BASE      = 128;
    88 static const boost::uint32_t AXIS_CONFIG_BUS       = AXI_WRAPPER_BASE+1;
    89 static const boost::uint32_t AXIS_CONFIG_BUS_TLAST = AXI_WRAPPER_BASE+2;
    93         (
"AXIS_CONFIG_BUS", AXIS_CONFIG_BUS)
    94         (
"AXIS_CONFIG_BUS_TLAST", AXIS_CONFIG_BUS_TLAST)
    98 static const size_t ANY_PORT = size_t(~0);
    99 static const size_t MAX_NUM_PORTS = 16;
   102 static const std::string VALID_BLOCKNAME_REGEX =
"[A-Za-z][A-Za-z0-9]*";
   103 static const std::string VALID_BLOCKID_REGEX =
"(?:(\\d+)(?:/))?([A-Za-z][A-Za-z0-9]*)(?:(?:_)(\\d\\d?))?";
 Definition: constants.hpp:78
Definition: constants.hpp:77
Definition: constants.hpp:79
settingsbus_reg_t
Settings register readback.
Definition: constants.hpp:76
Definition: build_info.hpp:25
Definition: constants.hpp:82
Definition: constants.hpp:81
Definition: constants.hpp:80
