18 #ifndef INCLUDED_UHD_USRP_DBOARD_IFACE_HPP    19 #define INCLUDED_UHD_USRP_DBOARD_IFACE_HPP    27 #include <boost/shared_ptr.hpp>    28 #include <boost/cstdint.hpp>    29 #include <boost/thread/thread.hpp>    33 namespace uhd{
namespace usrp{
    64     typedef boost::shared_ptr<dboard_iface>
sptr;
    98     virtual special_props_t get_special_props(
void) = 0;
   107     virtual void write_aux_dac(
unit_t unit,
aux_dac_t which_dac,
double value) = 0;
   125     virtual void set_pin_ctrl(
   126         unit_t unit, boost::uint32_t value, boost::uint32_t
mask = 0xffff
   135     virtual boost::uint32_t get_pin_ctrl(
unit_t unit) = 0;
   145     virtual void set_atr_reg(
   146         unit_t unit, atr_reg_t reg, boost::uint32_t value, boost::uint32_t
mask = 0xffff
   156     virtual boost::uint32_t get_atr_reg(
unit_t unit, atr_reg_t reg) = 0;
   165     virtual void set_gpio_ddr(
   166         unit_t unit, boost::uint32_t value, boost::uint32_t
mask = 0xffff
   175     virtual boost::uint32_t get_gpio_ddr(
unit_t unit) = 0;
   184     virtual void set_gpio_out(
   185         unit_t unit, boost::uint32_t value, boost::uint32_t
mask = 0xffff
   194     virtual boost::uint32_t get_gpio_out(
unit_t unit) = 0;
   202     virtual boost::uint32_t read_gpio(
unit_t unit) = 0;
   212     virtual void write_spi(
   215         boost::uint32_t data,
   228     virtual boost::uint32_t read_write_spi(
   231         boost::uint32_t data,
   241     virtual void set_clock_rate(
unit_t unit,
double rate) = 0;
   249     virtual double get_clock_rate(
unit_t unit) = 0;
   257     virtual std::vector<double> get_clock_rates(
unit_t unit) = 0;
   265     virtual void set_clock_enabled(
unit_t unit,
bool enb) = 0;
   274     virtual double get_codec_rate(
unit_t unit) = 0;
   283     virtual void set_fe_connection(
   285         const std::string& fe_name,
   305     virtual void sleep(
const boost::chrono::nanoseconds& time);
 virtual ~dboard_iface(void)
Definition: dboard_iface.hpp:90
aux_adc_t
Definition: dboard_iface.hpp:83
Definition: serial.hpp:45
uhd::usrp::gpio_atr::gpio_atr_reg_t atr_reg_t
Definition: dboard_iface.hpp:88
Definition: time_spec.hpp:39
aux_dac_t
Definition: dboard_iface.hpp:75
Definition: build_info.hpp:25
Definition: dboard_iface.hpp:62
bool soft_clock_divider
Definition: dboard_iface.hpp:43
Definition: serial.hpp:105
Definition: fe_connection.hpp:27
gpio_atr_reg_t
Definition: gpio_defs.hpp:28
Definition: config.h:73
Definition: dboard_iface.hpp:64
UHD_INLINE size_t mask(const soft_reg_field_t field)
Definition: soft_register.hpp:98
Definition: dboard_iface.hpp:65
Definition: dboard_iface.hpp:36
unit_t
Definition: dboard_iface.hpp:68
bool mangle_i2c_addrs
Definition: dboard_iface.hpp:53
