property_tree.hpp
2 // Copyright 2011,2014-2016 Ettus Research
18 #ifndef INCLUDED_UHD_PROPERTY_TREE_HPP
19 #define INCLUDED_UHD_PROPERTY_TREE_HPP
24 #include <boost/function.hpp>
25 #include <vector>
26
27 namespace uhd{
28
76 template <typename T> class property : boost::noncopyable{
77 public:
78  typedef boost::function<void(const T &)> subscriber_type;
79  typedef boost::function<T(void)> publisher_type;
80  typedef boost::function<T(const T &)> coercer_type;
81
82  virtual ~property<T>(void) = 0;
83
94  virtual property<T> &set_coercer(const coercer_type &coercer) = 0;
95
106  virtual property<T> &set_publisher(const publisher_type &publisher) = 0;
107
117  virtual property<T> &add_desired_subscriber(const subscriber_type &subscriber) = 0;
118
128  virtual property<T> &add_coerced_subscriber(const subscriber_type &subscriber) = 0;
129
136  virtual property<T> &update(void) = 0;
137
150  virtual property<T> &set(const T &value) = 0;
151
163  virtual property<T> &set_coerced(const T &value) = 0;
164
173  virtual const T get(void) const = 0;
174
181  virtual const T get_desired(void) const = 0;
182
189  virtual bool empty(void) const = 0;
190 };
191
192 template <typename T>
194  /* NOP */
195 }
196
204 struct fs_path : std::string{
205  UHD_API fs_path(void);
206  UHD_API fs_path(const char *);
207  UHD_API fs_path(const std::string &);
208  UHD_API std::string leaf(void) const;
209  UHD_API fs_path branch_path(void) const;
210 };
211
212 UHD_API fs_path operator/(const fs_path &, const fs_path &);
213 UHD_API fs_path operator/(const fs_path &, size_t);
214
218 class UHD_API property_tree : boost::noncopyable{
219 public:
220  typedef boost::shared_ptr<property_tree> sptr;
221
222  enum coerce_mode_t { AUTO_COERCE, MANUAL_COERCE };
223
224  virtual ~property_tree(void) = 0;
225
227  static sptr make(void);
228
230  virtual sptr subtree(const fs_path &path) const = 0;
231
233  virtual void remove(const fs_path &path) = 0;
234
236  virtual bool exists(const fs_path &path) const = 0;
237
239  virtual std::vector<std::string> list(const fs_path &path) const = 0;
240
242  template <typename T> property<T> &create(
243  const fs_path &path,
244  coerce_mode_t coerce_mode = AUTO_COERCE);
245
247  template <typename T> property<T> &access(const fs_path &path);
248
249 private:
251  virtual void _create(const fs_path &path, const boost::shared_ptr<void> &prop) = 0;
252
254  virtual boost::shared_ptr<void> &_access(const fs_path &path) const = 0;
255
256 };
257
258 } //namespace uhd
259
260 #include <uhd/property_tree.ipp>
261
262 #endif /* INCLUDED_UHD_PROPERTY_TREE_HPP */
boost::function< void(const T &)> subscriber_type
Definition: property_tree.hpp:78
virtual ~property(void)=0
Definition: property_tree.hpp:193
virtual property< T > & update(void)=0
Definition: property_tree.hpp:204
Definition: property_tree.hpp:220
virtual property< T > & add_coerced_subscriber(const subscriber_type &subscriber)=0
Definition: build_info.hpp:25
boost::function< T(const T &)> coercer_type
Definition: property_tree.hpp:80
virtual property< T > & set_publisher(const publisher_type &publisher)=0
virtual bool empty(void) const =0
virtual const T get_desired(void) const =0
virtual property< T > & set_coerced(const T &value)=0
boost::function< T(void)> publisher_type
Definition: property_tree.hpp:79
Definition: config.h:73
coerce_mode_t
Definition: property_tree.hpp:222
Definition: property_tree.hpp:218
virtual property< T > & add_desired_subscriber(const subscriber_type &subscriber)=0
Definition: property_tree.hpp:76
virtual property< T > & set_coercer(const coercer_type &coercer)=0
