18 #ifndef INCLUDED_LIBUHD_RFNOC_RADIO_CTRL_HPP    19 #define INCLUDED_LIBUHD_RFNOC_RADIO_CTRL_HPP    53     virtual double get_rate()
const = 0;
    59     virtual double set_rate(
double rate) = 0;
    65     virtual std::string get_tx_antenna(
const size_t chan)  = 0;
    71     virtual void set_tx_antenna(
const std::string &ant,
    77     virtual std::string get_rx_antenna(
    83     virtual void set_rx_antenna(
    92     virtual double get_tx_frequency(
   101     virtual double set_tx_frequency(
const double freq,
size_t chan) = 0;
   107     virtual double get_rx_frequency(
   116     virtual double set_rx_frequency(
const double freq,
   122     virtual double get_tx_gain(
   131     virtual double set_tx_gain(
const double gain,
   137     virtual double get_rx_gain(
   146     virtual double set_rx_gain(
const double gain,
   155     virtual void set_time_now(
const time_spec_t &time_spec) = 0;
   168     virtual void set_time_next_pps(
   192     virtual size_t get_chan_from_dboard_fe(
const std::string &fe,
const uhd::direction_t dir) = 0;
   196     virtual std::string get_dboard_fe_from_chan(
const size_t chan,
Definition: terminator_node_ctrl.hpp:40
#define UHD_RFNOC_BLOCK_OBJECT(class_name)
This macro must be put in the public section of an RFNoC.
Definition: block_ctrl_base.hpp:74
Definition: sink_block_ctrl_base.hpp:36
Definition: time_spec.hpp:39
Definition: rate_node_ctrl.hpp:38
Block controller for all RFNoC-based radio blocks.
Definition: radio_ctrl.hpp:34
Definition: build_info.hpp:25
Definition: tick_node_ctrl.hpp:35
#define UHD_RFNOC_API
Definition: config.hpp:103
Definition: source_block_ctrl_base.hpp:35
direction_t
Definition: direction.hpp:23
