18 #ifndef INCLUDED_LIBUHD_SOURCE_NODE_CTRL_BASE_HPP    19 #define INCLUDED_LIBUHD_SOURCE_NODE_CTRL_BASE_HPP    24 #include <boost/thread.hpp>    40     typedef boost::shared_ptr<source_node_ctrl>
sptr;
    41     typedef std::map< size_t, boost::weak_ptr<source_node_ctrl> >
node_map_t;
   106             const size_t suggested_port,
   114     boost::mutex _output_mutex;
   126     void _register_downstream_node(
 Definition: stream_cmd.hpp:46
std::pair< size_t, boost::weak_ptr< source_node_ctrl > > node_map_pair_t
Definition: source_node_ctrl.hpp:42
Definition: source_node_ctrl.hpp:34
boost::shared_ptr< source_node_ctrl > sptr
Definition: source_node_ctrl.hpp:40
virtual void issue_stream_cmd(const uhd::stream_cmd_t &stream_cmd, const size_t chan=0)=0
Definition: build_info.hpp:25
boost::shared_ptr< node_ctrl_base > sptr
Definition: node_ctrl_base.hpp:47
#define UHD_RFNOC_API
Definition: config.hpp:103
virtual size_t _request_output_port(const size_t suggested_port, const uhd::device_addr_t &args) const
size_t connect_downstream(node_ctrl_base::sptr downstream_node, size_t port=ANY_PORT, const uhd::device_addr_t &args=uhd::device_addr_t())
virtual void set_rx_streamer(bool active, const size_t port)
std::map< size_t, bool > _rx_streamer_active
Definition: source_node_ctrl.hpp:93
std::map< size_t, boost::weak_ptr< source_node_ctrl > > node_map_t
Definition: source_node_ctrl.hpp:41
Definition: node_ctrl_base.hpp:41
