stream.hpp
2 // Copyright 2011-2013 Ettus Research LLC
18 #ifndef INCLUDED_UHD_STREAM_HPP
19 #define INCLUDED_UHD_STREAM_HPP
22 #include <uhd/types/metadata.hpp>
24 #include <uhd/types/stream_cmd.hpp>
25 #include <uhd/types/ref_vector.hpp>
26 #include <boost/utility.hpp>
27 #include <boost/shared_ptr.hpp>
28 #include <vector>
29 #include <string>
30
31 namespace uhd{
32
58
61  const std::string &cpu = "",
62  const std::string &otw = ""
63  ){
64  cpu_format = cpu;
65  otw_format = otw;
66  }
67
84  std::string cpu_format;
85
104  std::string otw_format;
105
154
174  std::vector<size_t> channels;
175 };
176
182 class UHD_API rx_streamer : boost::noncopyable{
183 public:
184  typedef boost::shared_ptr<rx_streamer> sptr;
185
186  virtual ~rx_streamer(void);
187
189  virtual size_t get_num_channels(void) const = 0;
190
192  virtual size_t get_max_num_samps(void) const = 0;
193
196
227  virtual size_t recv(
228  const buffs_type &buffs,
229  const size_t nsamps_per_buff,
230  rx_metadata_t &metadata,
231  const double timeout = 0.1,
232  const bool one_packet = false
233  ) = 0;
234
246  virtual void issue_stream_cmd(const stream_cmd_t &stream_cmd) = 0;
247 };
248
254 class UHD_API tx_streamer : boost::noncopyable{
255 public:
256  typedef boost::shared_ptr<tx_streamer> sptr;
257
258  virtual ~tx_streamer(void);
259
261  virtual size_t get_num_channels(void) const = 0;
262
264  virtual size_t get_max_num_samps(void) const = 0;
265
268
290  virtual size_t send(
291  const buffs_type &buffs,
292  const size_t nsamps_per_buff,
293  const tx_metadata_t &metadata,
294  const double timeout = 0.1
295  ) = 0;
296
303  virtual bool recv_async_msg(
304  async_metadata_t &async_metadata, double timeout = 0.1
305  ) = 0;
306 };
307
308 } //namespace uhd
309
310 #endif /* INCLUDED_UHD_STREAM_HPP */
Definition: stream_cmd.hpp:46
Definition: stream.hpp:182
Definition: stream.hpp:254
std::vector< size_t > channels
Definition: stream.hpp:174
Definition: stream.hpp:184
Definition: stream.hpp:104
Definition: metadata.hpp:33
Definition: metadata.hpp:142
Definition: build_info.hpp:25
Definition: stream.hpp:84
Definition: ref_vector.hpp:31
ref_vector< void * > buffs_type
Typedef for a pointer to a single, or a collection of recv buffers.
Definition: stream.hpp:195
stream_args_t(const std::string &cpu="", const std::string &otw="")
Convenience constructor for streamer args.
Definition: stream.hpp:60
size_t send(const send_buffs_type &buffs, size_t nsamps_per_buff, const tx_metadata_t &metadata, const io_type_t &io_type, send_mode_t send_mode, double timeout=0.1)
Definition: device_deprecated.ipp:74
device_addr_t args
Definition: stream.hpp:153
ref_vector< const void * > buffs_type
Typedef for a pointer to a single, or a collection of send buffers.
Definition: stream.hpp:267
Definition: stream.hpp:57
Definition: config.h:73
Definition: metadata.hpp:169
Definition: stream.hpp:256
size_t recv(const recv_buffs_type &buffs, size_t nsamps_per_buff, rx_metadata_t &metadata, const io_type_t &io_type, recv_mode_t recv_mode, double timeout=0.1)
Definition: device_deprecated.ipp:130
virtual bool recv_async_msg(async_metadata_t &async_metadata, double timeout=0.1)=0
