build_info.hpp
2 // Copyright 2015 National Instruments Corp.
18 #ifndef INCLUDED_UHD_BUILD_INFO_HPP
19 #define INCLUDED_UHD_BUILD_INFO_HPP
22
23 #include <string>
25 namespace uhd { namespace build_info {
26
28  UHD_API const std::string boost_version();
29
31  UHD_API const std::string build_date();
32
34  UHD_API const std::string c_compiler();
35
37  UHD_API const std::string cxx_compiler();
38
40  UHD_API const std::string c_flags();
41
43  UHD_API const std::string cxx_flags();
44
46  UHD_API const std::string enabled_components();
47
49  UHD_API const std::string install_prefix();
50
52  UHD_API const std::string libusb_version();
53 }}
54
55 #endif /* INCLUDED_UHD_BUILD_INFO_HPP */
Return the date and time (GMT) this UHD build was built.
Return the C flags passed into this build.
Return the default CMake install prefix for this build.
Return the version of Boost this build was built with.
Return the version of libusb this build was built with.
Definition: build_info.hpp:25
Return the C compiler used for this build.
Return the C++ compiler used for this build.
Return the C++ flags passed into this build.
Return the UHD components enabled for this build, comma-delimited.
Definition: config.h:73
