multi_usrp.hpp
2 // Copyright 2010-2012,2014-2015 Ettus Research LLC
18 #ifndef INCLUDED_UHD_USRP_MULTI_USRP_HPP
19 #define INCLUDED_UHD_USRP_MULTI_USRP_HPP
21 //define API capabilities for compile time detection of new features
22 #define UHD_USRP_MULTI_USRP_REF_SOURCES_API
23 #define UHD_USRP_MULTI_USRP_GET_RATES_API
24 #define UHD_USRP_MULTI_USRP_FRONTEND_CAL_API
25 #define UHD_USRP_MULTI_USRP_FRONTEND_IQ_AUTO_API
26 #define UHD_USRP_MULTI_USRP_COMMAND_TIME_API
27 #define UHD_USRP_MULTI_USRP_BW_RANGE_API
28 #define UHD_USRP_MULTI_USRP_USER_REGS_API
29 #define UHD_USRP_MULTI_USRP_GET_USRP_INFO_API
30 #define UHD_USRP_MULTI_USRP_NORMALIZED_GAIN
31 #define UHD_USRP_MULTI_USRP_GPIO_API
32 #define UHD_USRP_MULTI_USRP_REGISTER_API
33 #define UHD_USRP_MULTI_USRP_FILTER_API
34 #define UHD_USRP_MULTI_USRP_LO_CONFIG_API
35
36 #include <uhd/config.hpp>
37 #include <uhd/device.hpp>
38 #include <uhd/deprecated.hpp>
39 #include <uhd/types/ranges.hpp>
40 #include <uhd/types/stream_cmd.hpp>
43 #include <uhd/types/sensors.hpp>
44 #include <uhd/types/filters.hpp>
45 #include <uhd/usrp/subdev_spec.hpp>
47 #include <boost/shared_ptr.hpp>
48 #include <boost/utility.hpp>
49 #include <complex>
50 #include <string>
51 #include <vector>
52
53 namespace uhd{ namespace usrp{
54
101 class UHD_API multi_usrp : boost::noncopyable{
102 public:
103  typedef boost::shared_ptr<multi_usrp> sptr;
104
105  virtual ~multi_usrp(void) = 0;
106
108  static const size_t ALL_MBOARDS = size_t(~0);
109
111  static const size_t ALL_CHANS = size_t(~0);
112
114  static const std::string ALL_GAINS;
115
117  static const std::string ALL_LOS;
118
124  static sptr make(const device_addr_t &dev_addr);
125
131  virtual device::sptr get_device(void) = 0;
132
134  virtual rx_streamer::sptr get_rx_stream(const stream_args_t &args) = 0;
135
137  virtual tx_streamer::sptr get_tx_stream(const stream_args_t &args) = 0;
138
146  virtual dict<std::string, std::string> get_usrp_rx_info(size_t chan = 0) = 0;
147
155  virtual dict<std::string, std::string> get_usrp_tx_info(size_t chan = 0) = 0;
156
157  /*******************************************************************
158  * Mboard methods
159  ******************************************************************/
160
183  virtual void set_master_clock_rate(double rate, size_t mboard = ALL_MBOARDS) = 0;
184
190  virtual double get_master_clock_rate(size_t mboard = 0) = 0;
191
196  virtual std::string get_pp_string(void) = 0;
197
203  virtual std::string get_mboard_name(size_t mboard = 0) = 0;
204
210  virtual time_spec_t get_time_now(size_t mboard = 0) = 0;
211
217  virtual time_spec_t get_time_last_pps(size_t mboard = 0) = 0;
218
230  virtual void set_time_now(const time_spec_t &time_spec, size_t mboard = ALL_MBOARDS) = 0;
231
244  virtual void set_time_next_pps(const time_spec_t &time_spec, size_t mboard = ALL_MBOARDS) = 0;
245
261  virtual void set_time_unknown_pps(const time_spec_t &time_spec) = 0;
262
269  virtual bool get_time_synchronized(void) = 0;
270
281  virtual void set_command_time(const uhd::time_spec_t &time_spec, size_t mboard = ALL_MBOARDS) = 0;
282
288  virtual void clear_command_time(size_t mboard = ALL_MBOARDS) = 0;
289
302  virtual void issue_stream_cmd(const stream_cmd_t &stream_cmd, size_t chan = ALL_CHANS) = 0;
303
312  virtual void set_clock_config(const clock_config_t &clock_config, size_t mboard = ALL_MBOARDS) = 0;
313
322  virtual void set_time_source(const std::string &source, const size_t mboard = ALL_MBOARDS) = 0;
323
329  virtual std::string get_time_source(const size_t mboard) = 0;
330
336  virtual std::vector<std::string> get_time_sources(const size_t mboard) = 0;
337
345  virtual void set_clock_source(const std::string &source, const size_t mboard = ALL_MBOARDS) = 0;
346
352  virtual std::string get_clock_source(const size_t mboard) = 0;
353
359  virtual std::vector<std::string> get_clock_sources(const size_t mboard) = 0;
360
369  virtual void set_clock_source_out(const bool enb, const size_t mboard = ALL_MBOARDS) = 0;
370
379  virtual void set_time_source_out(const bool enb, const size_t mboard = ALL_MBOARDS) = 0;
380
384  virtual size_t get_num_mboards(void) = 0;
385
392  virtual sensor_value_t get_mboard_sensor(const std::string &name, size_t mboard = 0) = 0;
393
399  virtual std::vector<std::string> get_mboard_sensor_names(size_t mboard = 0) = 0;
400
408  virtual void set_user_register(const boost::uint8_t addr, const boost::uint32_t data, size_t mboard = ALL_MBOARDS) = 0;
409
410  /*******************************************************************
411  * RX methods
412  ******************************************************************/
421  virtual void set_rx_subdev_spec(const uhd::usrp::subdev_spec_t &spec, size_t mboard = ALL_MBOARDS) = 0;
422
428  virtual uhd::usrp::subdev_spec_t get_rx_subdev_spec(size_t mboard = 0) = 0;
429
435  virtual size_t get_rx_num_channels(void) = 0;
436
442  virtual std::string get_rx_subdev_name(size_t chan = 0) = 0;
443
449  virtual void set_rx_rate(double rate, size_t chan = ALL_CHANS) = 0;
450
456  virtual double get_rx_rate(size_t chan = 0) = 0;
457
463  virtual meta_range_t get_rx_rates(size_t chan = 0) = 0;
464
471  virtual tune_result_t set_rx_freq(
472  const tune_request_t &tune_request, size_t chan = 0
473  ) = 0;
474
480  virtual double get_rx_freq(size_t chan = 0) = 0;
481
491  virtual freq_range_t get_rx_freq_range(size_t chan = 0) = 0;
492
498  virtual freq_range_t get_fe_rx_freq_range(size_t chan = 0) = 0;
499
505  virtual std::vector<std::string> get_rx_lo_names(size_t chan = 0) = 0;
506
516  virtual void set_rx_lo_source(const std::string &src, const std::string &name = ALL_LOS, size_t chan = 0) = 0;
517
526  virtual const std::string get_rx_lo_source(const std::string &name = ALL_LOS, size_t chan = 0) = 0;
527
536  virtual std::vector<std::string> get_rx_lo_sources(const std::string &name = ALL_LOS, size_t chan = 0) = 0;
537
546  virtual void set_rx_lo_export_enabled(bool enabled, const std::string &name = ALL_LOS, size_t chan = 0) = 0;
547
553  virtual bool get_rx_lo_export_enabled(const std::string &name = ALL_LOS, size_t chan = 0) = 0;
554
562  virtual double set_rx_lo_freq(double freq, const std::string &name, size_t chan = 0) = 0;
563
572  virtual double get_rx_lo_freq(const std::string &name, size_t chan = 0) = 0;
573
582  virtual freq_range_t get_rx_lo_freq_range(const std::string &name, size_t chan = 0) = 0;
583
591  virtual void set_rx_gain(double gain, const std::string &name, size_t chan = 0) = 0;
592
594  void set_rx_gain(double gain, size_t chan = 0){
595  return this->set_rx_gain(gain, ALL_GAINS, chan);
596  }
597
614  virtual void set_normalized_rx_gain(double gain, size_t chan = 0) = 0;
615
624  virtual void set_rx_agc(bool enable, size_t chan = 0) = 0;
625
633  virtual double get_rx_gain(const std::string &name, size_t chan = 0) = 0;
634
636  double get_rx_gain(size_t chan = 0){
637  return this->get_rx_gain(ALL_GAINS, chan);
638  }
639
650  virtual double get_normalized_rx_gain(size_t chan = 0) = 0;
651
659  virtual gain_range_t get_rx_gain_range(const std::string &name, size_t chan = 0) = 0;
660
662  gain_range_t get_rx_gain_range(size_t chan = 0){
663  return this->get_rx_gain_range(ALL_GAINS, chan);
664  }
665
672  virtual std::vector<std::string> get_rx_gain_names(size_t chan = 0) = 0;
673
679  virtual void set_rx_antenna(const std::string &ant, size_t chan = 0) = 0;
680
686  virtual std::string get_rx_antenna(size_t chan = 0) = 0;
687
693  virtual std::vector<std::string> get_rx_antennas(size_t chan = 0) = 0;
694
700  virtual void set_rx_bandwidth(double bandwidth, size_t chan = 0) = 0;
701
707  virtual double get_rx_bandwidth(size_t chan = 0) = 0;
708
714  virtual meta_range_t get_rx_bandwidth_range(size_t chan = 0) = 0;
715
723  virtual dboard_iface::sptr get_rx_dboard_iface(size_t chan = 0) = 0;
724
731  virtual sensor_value_t get_rx_sensor(const std::string &name, size_t chan = 0) = 0;
732
738  virtual std::vector<std::string> get_rx_sensor_names(size_t chan = 0) = 0;
739
752  virtual void set_rx_dc_offset(const bool enb, size_t chan = ALL_CHANS) = 0;
753
761  virtual void set_rx_dc_offset(const std::complex<double> &offset, size_t chan = ALL_CHANS) = 0;
762
769  virtual void set_rx_iq_balance(const bool enb, size_t chan) = 0;
770
778  virtual void set_rx_iq_balance(const std::complex<double> &correction, size_t chan = ALL_CHANS) = 0;
779
780  /*******************************************************************
781  * TX methods
782  ******************************************************************/
791  virtual void set_tx_subdev_spec(const uhd::usrp::subdev_spec_t &spec, size_t mboard = ALL_MBOARDS) = 0;
792
798  virtual uhd::usrp::subdev_spec_t get_tx_subdev_spec(size_t mboard = 0) = 0;
799
805  virtual size_t get_tx_num_channels(void) = 0;
806
812  virtual std::string get_tx_subdev_name(size_t chan = 0) = 0;
813
819  virtual void set_tx_rate(double rate, size_t chan = ALL_CHANS) = 0;
820
826  virtual double get_tx_rate(size_t chan = 0) = 0;
827
833  virtual meta_range_t get_tx_rates(size_t chan = 0) = 0;
834
841  virtual tune_result_t set_tx_freq(
842  const tune_request_t &tune_request, size_t chan = 0
843  ) = 0;
844
850  virtual double get_tx_freq(size_t chan = 0) = 0;
851
861  virtual freq_range_t get_tx_freq_range(size_t chan = 0) = 0;
862
868  virtual freq_range_t get_fe_tx_freq_range(size_t chan = 0) = 0;
869
877  virtual void set_tx_gain(double gain, const std::string &name, size_t chan = 0) = 0;
878
880  void set_tx_gain(double gain, size_t chan = 0){
881  return this->set_tx_gain(gain, ALL_GAINS, chan);
882  }
883
894  virtual void set_normalized_tx_gain(double gain, size_t chan = 0) = 0;
895
903  virtual double get_tx_gain(const std::string &name, size_t chan = 0) = 0;
904
906  double get_tx_gain(size_t chan = 0){
907  return this->get_tx_gain(ALL_GAINS, chan);
908  }
909
920  virtual double get_normalized_tx_gain(size_t chan = 0) = 0;
921
929  virtual gain_range_t get_tx_gain_range(const std::string &name, size_t chan = 0) = 0;
930
932  gain_range_t get_tx_gain_range(size_t chan = 0){
933  return this->get_tx_gain_range(ALL_GAINS, chan);
934  }
935
942  virtual std::vector<std::string> get_tx_gain_names(size_t chan = 0) = 0;
943
949  virtual void set_tx_antenna(const std::string &ant, size_t chan = 0) = 0;
950
956  virtual std::string get_tx_antenna(size_t chan = 0) = 0;
957
963  virtual std::vector<std::string> get_tx_antennas(size_t chan = 0) = 0;
964
970  virtual void set_tx_bandwidth(double bandwidth, size_t chan = 0) = 0;
971
977  virtual double get_tx_bandwidth(size_t chan = 0) = 0;
978
984  virtual meta_range_t get_tx_bandwidth_range(size_t chan = 0) = 0;
985
993  virtual dboard_iface::sptr get_tx_dboard_iface(size_t chan = 0) = 0;
994
1001  virtual sensor_value_t get_tx_sensor(const std::string &name, size_t chan = 0) = 0;
1002
1008  virtual std::vector<std::string> get_tx_sensor_names(size_t chan = 0) = 0;
1009
1016  virtual void set_tx_dc_offset(const std::complex<double> &offset, size_t chan = ALL_CHANS) = 0;
1017
1025  virtual void set_tx_iq_balance(const std::complex<double> &correction, size_t chan = ALL_CHANS) = 0;
1026
1027  /*******************************************************************
1028  * GPIO methods
1029  ******************************************************************/
1030
1036  virtual std::vector<std::string> get_gpio_banks(const size_t mboard) = 0;
1037
1054  virtual void set_gpio_attr(const std::string &bank, const std::string &attr, const boost::uint32_t value, const boost::uint32_t mask = 0xffffffff, const size_t mboard = 0) = 0;
1055
1072  virtual boost::uint32_t get_gpio_attr(const std::string &bank, const std::string &attr, const size_t mboard = 0) = 0;
1073
1074  /*******************************************************************
1075  * Register IO methods
1076  ******************************************************************/
1078  size_t bitwidth;
1079  bool readable;
1080  bool writable;
1081  };
1082
1088  virtual std::vector<std::string> enumerate_registers(const size_t mboard = 0) = 0;
1089
1096  virtual register_info_t get_register_info(const std::string &path, const size_t mboard = 0) = 0;
1097
1105  virtual void write_register(const std::string &path, const boost::uint32_t field, const boost::uint64_t value, const size_t mboard = 0) = 0;
1106
1114  virtual boost::uint64_t read_register(const std::string &path, const boost::uint32_t field, const size_t mboard = 0) = 0;
1115
1116  /*******************************************************************
1117  * Filter API methods
1118  ******************************************************************/
1119
1130  virtual std::vector<std::string> get_filter_names(const std::string &search_mask = "") = 0;
1131
1137  virtual filter_info_base::sptr get_filter(const std::string &path) = 0;
1138
1146  virtual void set_filter(const std::string &path, filter_info_base::sptr filter) = 0;
1147
1148 };
1149
1150 }}
1151
1152 #endif /* INCLUDED_UHD_USRP_MULTI_USRP_HPP */
Definition: multi_usrp.hpp:662
Definition: stream_cmd.hpp:46
Definition: tune_result.hpp:29
Definition: multi_usrp.hpp:906
Definition: multi_usrp.hpp:880
Definition: time_spec.hpp:39
bool readable
Definition: multi_usrp.hpp:1079
Definition: device.hpp:41
boost::shared_ptr< multi_usrp > sptr
Definition: multi_usrp.hpp:103
Definition: multi_usrp.hpp:1077
Definition: multi_usrp.hpp:636
Definition: tune_request.hpp:33
Definition: stream.hpp:171
A wildcard gain element name.
Definition: multi_usrp.hpp:114
Definition: build_info.hpp:25
Definition: sensors.hpp:38
boost::shared_ptr< filter_info_base > sptr
Definition: filters.hpp:38
Definition: multi_usrp.hpp:101
Definition: stream.hpp:57
Definition: config.h:73
Definition: soft_register.hpp:98
Definition: dboard_iface.hpp:64
Definition: multi_usrp.hpp:594
Definition: multi_usrp.hpp:117
bool writable
Definition: multi_usrp.hpp:1080
Definition: ranges.hpp:68
size_t bitwidth
Definition: multi_usrp.hpp:1078
Definition: stream.hpp:247
Definition: multi_usrp.hpp:932
