Coding to the API
Various API interfaces
High-Level: The Multi-USRP
The Multi-USRP class provides a high-level interface to a single USRP device with one or more channels, or multiple USRP devices in a homogeneous setup. See the documentation for uhd::usrp::multi_usrp.
High-Level: The Multi-USRP-Clock
The Multi-USRP-Clock class provides a high-level interface to a single clock device or set of clock devices, from which the time can be queried. See the documentation for uhd::usrp_clock::multi_usrp_clock.
High-Level: The C API
Both USRP and clock devices can be interacted with using a C API wrapper included by default in all UHD builds. More information can be found here.
Low-Level: The device API
A device is an abstraction for hardware that is connected to the host system. For a USRP device, this means that the motherboard and everything on it would be considered to be a "device". For a clock device, the device itself would be considered a "device" in software. The device API provides ways to:
  • Discover devices that are physically connected to the host system.
  • Create a device object for a particular device identified by address.
  • Register a device driver into the discovery and factory sub-system.
  • Streaming samples with metadata into and out of the device.
  • Set and get properties on the device object.
  • Access various sensors on the device.
See the documentation for uhd::device.
