sid.hpp
18 #ifndef INCLUDED_UHD_TYPES_SID_HPP
19 #define INCLUDED_UHD_TYPES_SID_HPP
24 #include <iostream>
25
26 namespace uhd {
79  class UHD_API sid_t
80  {
81  public:
83  sid_t();
85  sid_t(boost::uint32_t sid);
87  sid_t(boost::uint8_t src_addr, boost::uint8_t src_ep, boost::uint8_t dst_addr, boost::uint8_t dst_ep);
89  sid_t(const std::string &);
90
92  std::string to_pp_string() const;
94  std::string to_pp_string_hex() const;
95
97  bool is_set() const { return _set; };
98
99  // Getters
100  //
102  UHD_INLINE boost::uint32_t get() const { return get_sid(); };
104  UHD_INLINE boost::uint32_t get_sid() const { return _set ? _sid : 0; };
106  UHD_INLINE boost::uint32_t get_src() const {
107  return (_sid >> 16) & 0xFFFF;
108  }
110  UHD_INLINE boost::uint32_t get_dst() const {
111  return _sid & 0xFFFF;
112  }
114  UHD_INLINE boost::uint32_t get_src_addr() const {
115  return (get_src() >> 8) & 0xFF;
116  }
118  UHD_INLINE boost::uint32_t get_src_endpoint() const {
119  return get_src() & 0xFF;
120  }
122  UHD_INLINE boost::uint32_t get_src_xbarport() const {
123  return (get_src_endpoint() >> 4) & 0xF;
124  }
126  UHD_INLINE boost::uint32_t get_src_blockport() const {
127  return (get_src_endpoint()) & 0xF;
128  }
130  UHD_INLINE boost::uint32_t get_dst_addr() const {
131  return (get_dst() >> 8) & 0xFF;
132  }
134  UHD_INLINE boost::uint32_t get_dst_endpoint() const {
135  return get_dst() & 0xFF;
136  }
138  UHD_INLINE boost::uint32_t get_dst_xbarport() const {
139  return (get_dst_endpoint() >> 4) & 0xF;
140  }
142  UHD_INLINE boost::uint32_t get_dst_blockport() const {
143  return (get_dst_endpoint()) & 0xF;
144  }
145
146  // Setters
147
149  void set(boost::uint32_t new_sid) { set_sid(new_sid); };
151  // Throws uhd::value_error if the string is not a valid SID
152  // representation.
153  void set_from_str(const std::string &);
154  void set_sid(boost::uint32_t new_sid);
156  // (the first 16 Bits)
157  void set_src(boost::uint32_t new_addr);
159  // (the last 16 Bits)
160  void set_dst(boost::uint32_t new_addr);
161  void set_src_addr(boost::uint32_t new_addr);
162  void set_src_endpoint(boost::uint32_t new_addr);
163  void set_dst_addr(boost::uint32_t new_addr);
164  void set_dst_endpoint(boost::uint32_t new_addr);
165  void set_dst_xbarport(boost::uint32_t new_xbarport);
166  void set_dst_blockport(boost::uint32_t new_blockport);
167
168  // Manipulators
169
171  sid_t reversed();
172
174  void reverse();
175
176  // Overloaded operators
177
178  sid_t operator = (boost::uint32_t new_sid) {
179  set_sid(new_sid);
180  return *this;
181  }
182
183  sid_t operator = (sid_t &sid) {
184  set_sid(sid.get_sid());
185  return *this;
186  }
187
188  sid_t operator = (const std::string &sid_str) {
189  set_from_str(sid_str);
190  return *this;
191  }
192
193  bool operator == (const sid_t &sid) const {
194  return (not _set and not sid.is_set()) or (_sid == sid.get_sid());
195  }
196
197  bool operator == (boost::uint32_t sid) const {
198  return _set and _sid == sid;
199  }
200
201  bool operator == (const std::string &sid_str) const {
202  sid_t rhs(sid_str);
203  return *this == rhs;
204  }
205
206  // overloaded type casts are tricky, but for now we'll need them
207  // for backward compatibility. consider them deprecated.
208
210  // Use is_set() to check if the return value is valid.
211  operator boost::uint32_t() const {
212  return get();
213  }
214
215  operator bool() const {
216  return _set;
217  }
218
219  private:
220  boost::uint32_t _sid;
221  bool _set;
222  };
223
225  UHD_INLINE std::ostream& operator<< (std::ostream& out, const sid_t &sid) {
226  std::ios_base::fmtflags ff = out.flags();
227  if (ff & std::ios::hex) {
228  out << sid.to_pp_string_hex();
229  } else {
230  out << sid.to_pp_string();
231  }
232  return out;
233  }
234
235 } //namespace uhd
236
237 #endif /* INCLUDED_UHD_TYPES_SID_HPP */
238 // vim: sw=4 et:
Definition: algorithm.hpp:56
Return block port of the source.
Definition: sid.hpp:142
Return the 16-bit source address of this SID.
Definition: sid.hpp:106
Return 8-bit address of the source.
Definition: sid.hpp:114
Return the 16-bit destination address of this SID.
Definition: sid.hpp:110
Return endpoint of the source.
Definition: sid.hpp:118
Return 8-bit address of the destination.
Definition: sid.hpp:130
Definition: build_info.hpp:25
Return a decimal string representation of the SID.
Represents a stream ID (SID).
Definition: sid.hpp:79
Definition: sid.hpp:126
Return endpoint of the destination.
Definition: sid.hpp:134
#define UHD_INLINE
Definition: config.h:63
Return crossbar port of the source.
Definition: sid.hpp:122
Definition: config.h:73
Returns a 32-Bit representation of the SID if set, or zero otherwise.
Definition: sid.hpp:104
bool is_set() const
Returns true if this actually holds a valid SID.
Definition: sid.hpp:97
Definition: sid.hpp:138
UHD_API bool operator==(const time_spec_t &, const time_spec_t &)
Return a hexadecimal string representation of the SID.
