18 #ifndef INCLUDED_UHD_TYPES_SERIAL_HPP    19 #define INCLUDED_UHD_TYPES_SERIAL_HPP    22 #include <boost/shared_ptr.hpp>    47         typedef boost::shared_ptr<i2c_iface>
sptr;
    59         virtual void write_i2c(
    61             const byte_vector_t &buf
    70         virtual byte_vector_t read_i2c(
    81         virtual void write_eeprom(
    84             const byte_vector_t &buf
    94         virtual byte_vector_t read_eeprom(
   140         typedef boost::shared_ptr<spi_iface>
sptr;
   153         virtual uint32_t transact_spi(
   169         virtual uint32_t read_spi(
   183         virtual void write_spi(
   196         typedef boost::shared_ptr<uart_iface>
sptr;
   204         virtual void write_uart(
const std::string &buf) = 0;
   211         virtual std::string read_uart(
double timeout) = 0;
 size_t divider
Optionally set the SPI clock divider for this transaction.
Definition: serial.hpp:125
Definition: serial.hpp:138
Definition: serial.hpp:45
bool use_custom_divider
Set the clock speed for this transaction.
Definition: serial.hpp:122
edge_t mosi_edge
on what edge is the mosi data valid?
Definition: serial.hpp:116
Definition: build_info.hpp:25
Definition: serial.hpp:105
boost::shared_ptr< spi_iface > sptr
Definition: serial.hpp:140
Definition: config.h:73
edge_t miso_edge
on what edge is the miso data valid?
Definition: serial.hpp:119
Definition: serial.hpp:194
Definition: serial.hpp:196
edge_t
Definition: serial.hpp:110
boost::shared_ptr< i2c_iface > sptr
Definition: serial.hpp:47
Definition: byte_vector.hpp:33
