multi_usrp.hpp
2 // Copyright 2010-2012,2014-2015 Ettus Research LLC
18 #ifndef INCLUDED_UHD_USRP_MULTI_USRP_HPP
19 #define INCLUDED_UHD_USRP_MULTI_USRP_HPP
21 //define API capabilities for compile time detection of new features
22 #define UHD_USRP_MULTI_USRP_REF_SOURCES_API
23 #define UHD_USRP_MULTI_USRP_GET_RATES_API
24 #define UHD_USRP_MULTI_USRP_FRONTEND_CAL_API
25 #define UHD_USRP_MULTI_USRP_FRONTEND_IQ_AUTO_API
26 #define UHD_USRP_MULTI_USRP_COMMAND_TIME_API
27 #define UHD_USRP_MULTI_USRP_BW_RANGE_API
28 #define UHD_USRP_MULTI_USRP_USER_REGS_API
29 #define UHD_USRP_MULTI_USRP_GET_USRP_INFO_API
30 #define UHD_USRP_MULTI_USRP_NORMALIZED_GAIN
31 #define UHD_USRP_MULTI_USRP_GPIO_API
32 #define UHD_USRP_MULTI_USRP_REGISTER_API
33 #define UHD_USRP_MULTI_USRP_FILTER_API
34 #define UHD_USRP_MULTI_USRP_LO_CONFIG_API
35
36 #include <uhd/config.hpp>
37 #include <uhd/device.hpp>
38 #include <uhd/deprecated.hpp>
39 #include <uhd/types/ranges.hpp>
40 #include <uhd/types/stream_cmd.hpp>
43 #include <uhd/types/sensors.hpp>
44 #include <uhd/types/filters.hpp>
45 #include <uhd/usrp/subdev_spec.hpp>
47 #include <boost/shared_ptr.hpp>
48 #include <boost/utility.hpp>
49 #include <complex>
50 #include <string>
51 #include <vector>
52
53 namespace uhd{ namespace usrp{
54
101 class UHD_API multi_usrp : boost::noncopyable{
102 public:
103  typedef boost::shared_ptr<multi_usrp> sptr;
104
105  virtual ~multi_usrp(void) = 0;
106
108  static const size_t ALL_MBOARDS = size_t(~0);
109
111  static const size_t ALL_CHANS = size_t(~0);
112
114  static const std::string ALL_GAINS;
115
117  static const std::string ALL_LOS;
118
126  static sptr make(const device_addr_t &dev_addr);
127
133  virtual device::sptr get_device(void) = 0;
134
136  virtual rx_streamer::sptr get_rx_stream(const stream_args_t &args) = 0;
137
139  virtual tx_streamer::sptr get_tx_stream(const stream_args_t &args) = 0;
140
148  virtual dict<std::string, std::string> get_usrp_rx_info(size_t chan = 0) = 0;
149
157  virtual dict<std::string, std::string> get_usrp_tx_info(size_t chan = 0) = 0;
158
159  /*******************************************************************
160  * Mboard methods
161  ******************************************************************/
162
185  virtual void set_master_clock_rate(double rate, size_t mboard = ALL_MBOARDS) = 0;
186
192  virtual double get_master_clock_rate(size_t mboard = 0) = 0;
193
198  virtual std::string get_pp_string(void) = 0;
199
205  virtual std::string get_mboard_name(size_t mboard = 0) = 0;
206
212  virtual time_spec_t get_time_now(size_t mboard = 0) = 0;
213
219  virtual time_spec_t get_time_last_pps(size_t mboard = 0) = 0;
220
232  virtual void set_time_now(const time_spec_t &time_spec, size_t mboard = ALL_MBOARDS) = 0;
233
246  virtual void set_time_next_pps(const time_spec_t &time_spec, size_t mboard = ALL_MBOARDS) = 0;
247
263  virtual void set_time_unknown_pps(const time_spec_t &time_spec) = 0;
264
271  virtual bool get_time_synchronized(void) = 0;
272
283  virtual void set_command_time(const uhd::time_spec_t &time_spec, size_t mboard = ALL_MBOARDS) = 0;
284
290  virtual void clear_command_time(size_t mboard = ALL_MBOARDS) = 0;
291
304  virtual void issue_stream_cmd(const stream_cmd_t &stream_cmd, size_t chan = ALL_CHANS) = 0;
305
314  virtual void set_clock_config(const clock_config_t &clock_config, size_t mboard = ALL_MBOARDS) = 0;
315
324  virtual void set_time_source(const std::string &source, const size_t mboard = ALL_MBOARDS) = 0;
325
331  virtual std::string get_time_source(const size_t mboard) = 0;
332
338  virtual std::vector<std::string> get_time_sources(const size_t mboard) = 0;
339
347  virtual void set_clock_source(const std::string &source, const size_t mboard = ALL_MBOARDS) = 0;
348
354  virtual std::string get_clock_source(const size_t mboard) = 0;
355
361  virtual std::vector<std::string> get_clock_sources(const size_t mboard) = 0;
362
371  virtual void set_clock_source_out(const bool enb, const size_t mboard = ALL_MBOARDS) = 0;
372
381  virtual void set_time_source_out(const bool enb, const size_t mboard = ALL_MBOARDS) = 0;
382
386  virtual size_t get_num_mboards(void) = 0;
387
394  virtual sensor_value_t get_mboard_sensor(const std::string &name, size_t mboard = 0) = 0;
395
401  virtual std::vector<std::string> get_mboard_sensor_names(size_t mboard = 0) = 0;
402
410  virtual void set_user_register(const uint8_t addr, const uint32_t data, size_t mboard = ALL_MBOARDS) = 0;
411
412  /*******************************************************************
413  * RX methods
414  ******************************************************************/
423  virtual void set_rx_subdev_spec(const uhd::usrp::subdev_spec_t &spec, size_t mboard = ALL_MBOARDS) = 0;
424
430  virtual uhd::usrp::subdev_spec_t get_rx_subdev_spec(size_t mboard = 0) = 0;
431
437  virtual size_t get_rx_num_channels(void) = 0;
438
444  virtual std::string get_rx_subdev_name(size_t chan = 0) = 0;
445
451  virtual void set_rx_rate(double rate, size_t chan = ALL_CHANS) = 0;
452
458  virtual double get_rx_rate(size_t chan = 0) = 0;
459
465  virtual meta_range_t get_rx_rates(size_t chan = 0) = 0;
466
473  virtual tune_result_t set_rx_freq(
474  const tune_request_t &tune_request, size_t chan = 0
475  ) = 0;
476
482  virtual double get_rx_freq(size_t chan = 0) = 0;
483
493  virtual freq_range_t get_rx_freq_range(size_t chan = 0) = 0;
494
500  virtual freq_range_t get_fe_rx_freq_range(size_t chan = 0) = 0;
501
507  virtual std::vector<std::string> get_rx_lo_names(size_t chan = 0) = 0;
508
518  virtual void set_rx_lo_source(const std::string &src, const std::string &name = ALL_LOS, size_t chan = 0) = 0;
519
528  virtual const std::string get_rx_lo_source(const std::string &name = ALL_LOS, size_t chan = 0) = 0;
529
538  virtual std::vector<std::string> get_rx_lo_sources(const std::string &name = ALL_LOS, size_t chan = 0) = 0;
539
548  virtual void set_rx_lo_export_enabled(bool enabled, const std::string &name = ALL_LOS, size_t chan = 0) = 0;
549
555  virtual bool get_rx_lo_export_enabled(const std::string &name = ALL_LOS, size_t chan = 0) = 0;
556
564  virtual double set_rx_lo_freq(double freq, const std::string &name, size_t chan = 0) = 0;
565
574  virtual double get_rx_lo_freq(const std::string &name, size_t chan = 0) = 0;
575
584  virtual freq_range_t get_rx_lo_freq_range(const std::string &name, size_t chan = 0) = 0;
585
593  virtual void set_rx_gain(double gain, const std::string &name, size_t chan = 0) = 0;
594
596  void set_rx_gain(double gain, size_t chan = 0){
597  return this->set_rx_gain(gain, ALL_GAINS, chan);
598  }
599
616  virtual void set_normalized_rx_gain(double gain, size_t chan = 0) = 0;
617
626  virtual void set_rx_agc(bool enable, size_t chan = 0) = 0;
627
635  virtual double get_rx_gain(const std::string &name, size_t chan = 0) = 0;
636
638  double get_rx_gain(size_t chan = 0){
639  return this->get_rx_gain(ALL_GAINS, chan);
640  }
641
652  virtual double get_normalized_rx_gain(size_t chan = 0) = 0;
653
661  virtual gain_range_t get_rx_gain_range(const std::string &name, size_t chan = 0) = 0;
662
664  gain_range_t get_rx_gain_range(size_t chan = 0){
665  return this->get_rx_gain_range(ALL_GAINS, chan);
666  }
667
674  virtual std::vector<std::string> get_rx_gain_names(size_t chan = 0) = 0;
675
681  virtual void set_rx_antenna(const std::string &ant, size_t chan = 0) = 0;
682
688  virtual std::string get_rx_antenna(size_t chan = 0) = 0;
689
695  virtual std::vector<std::string> get_rx_antennas(size_t chan = 0) = 0;
696
702  virtual void set_rx_bandwidth(double bandwidth, size_t chan = 0) = 0;
703
709  virtual double get_rx_bandwidth(size_t chan = 0) = 0;
710
716  virtual meta_range_t get_rx_bandwidth_range(size_t chan = 0) = 0;
717
725  virtual dboard_iface::sptr get_rx_dboard_iface(size_t chan = 0) = 0;
726
733  virtual sensor_value_t get_rx_sensor(const std::string &name, size_t chan = 0) = 0;
734
740  virtual std::vector<std::string> get_rx_sensor_names(size_t chan = 0) = 0;
741
754  virtual void set_rx_dc_offset(const bool enb, size_t chan = ALL_CHANS) = 0;
755
763  virtual void set_rx_dc_offset(const std::complex<double> &offset, size_t chan = ALL_CHANS) = 0;
764
771  virtual void set_rx_iq_balance(const bool enb, size_t chan) = 0;
772
780  virtual void set_rx_iq_balance(const std::complex<double> &correction, size_t chan = ALL_CHANS) = 0;
781
782  /*******************************************************************
783  * TX methods
784  ******************************************************************/
793  virtual void set_tx_subdev_spec(const uhd::usrp::subdev_spec_t &spec, size_t mboard = ALL_MBOARDS) = 0;
794
800  virtual uhd::usrp::subdev_spec_t get_tx_subdev_spec(size_t mboard = 0) = 0;
801
807  virtual size_t get_tx_num_channels(void) = 0;
808
814  virtual std::string get_tx_subdev_name(size_t chan = 0) = 0;
815
821  virtual void set_tx_rate(double rate, size_t chan = ALL_CHANS) = 0;
822
828  virtual double get_tx_rate(size_t chan = 0) = 0;
829
835  virtual meta_range_t get_tx_rates(size_t chan = 0) = 0;
836
843  virtual tune_result_t set_tx_freq(
844  const tune_request_t &tune_request, size_t chan = 0
845  ) = 0;
846
852  virtual double get_tx_freq(size_t chan = 0) = 0;
853
863  virtual freq_range_t get_tx_freq_range(size_t chan = 0) = 0;
864
870  virtual freq_range_t get_fe_tx_freq_range(size_t chan = 0) = 0;
871
879  virtual void set_tx_gain(double gain, const std::string &name, size_t chan = 0) = 0;
880
882  void set_tx_gain(double gain, size_t chan = 0){
883  return this->set_tx_gain(gain, ALL_GAINS, chan);
884  }
885
896  virtual void set_normalized_tx_gain(double gain, size_t chan = 0) = 0;
897
905  virtual double get_tx_gain(const std::string &name, size_t chan = 0) = 0;
906
908  double get_tx_gain(size_t chan = 0){
909  return this->get_tx_gain(ALL_GAINS, chan);
910  }
911
922  virtual double get_normalized_tx_gain(size_t chan = 0) = 0;
923
931  virtual gain_range_t get_tx_gain_range(const std::string &name, size_t chan = 0) = 0;
932
934  gain_range_t get_tx_gain_range(size_t chan = 0){
935  return this->get_tx_gain_range(ALL_GAINS, chan);
936  }
937
944  virtual std::vector<std::string> get_tx_gain_names(size_t chan = 0) = 0;
945
951  virtual void set_tx_antenna(const std::string &ant, size_t chan = 0) = 0;
952
958  virtual std::string get_tx_antenna(size_t chan = 0) = 0;
959
965  virtual std::vector<std::string> get_tx_antennas(size_t chan = 0) = 0;
966
972  virtual void set_tx_bandwidth(double bandwidth, size_t chan = 0) = 0;
973
979  virtual double get_tx_bandwidth(size_t chan = 0) = 0;
980
986  virtual meta_range_t get_tx_bandwidth_range(size_t chan = 0) = 0;
987
995  virtual dboard_iface::sptr get_tx_dboard_iface(size_t chan = 0) = 0;
996
1003  virtual sensor_value_t get_tx_sensor(const std::string &name, size_t chan = 0) = 0;
1004
1010  virtual std::vector<std::string> get_tx_sensor_names(size_t chan = 0) = 0;
1011
1018  virtual void set_tx_dc_offset(const std::complex<double> &offset, size_t chan = ALL_CHANS) = 0;
1019
1027  virtual void set_tx_iq_balance(const std::complex<double> &correction, size_t chan = ALL_CHANS) = 0;
1028
1029  /*******************************************************************
1030  * GPIO methods
1031  ******************************************************************/
1032
1038  virtual std::vector<std::string> get_gpio_banks(const size_t mboard) = 0;
1039
1056  virtual void set_gpio_attr(const std::string &bank, const std::string &attr, const uint32_t value, const uint32_t mask = 0xffffffff, const size_t mboard = 0) = 0;
1057
1074  virtual uint32_t get_gpio_attr(const std::string &bank, const std::string &attr, const size_t mboard = 0) = 0;
1075
1076  /*******************************************************************
1077  * Register IO methods
1078  ******************************************************************/
1080  size_t bitwidth;
1081  bool readable;
1082  bool writable;
1083  };
1084
1090  virtual std::vector<std::string> enumerate_registers(const size_t mboard = 0) = 0;
1091
1098  virtual register_info_t get_register_info(const std::string &path, const size_t mboard = 0) = 0;
1099
1107  virtual void write_register(const std::string &path, const uint32_t field, const uint64_t value, const size_t mboard = 0) = 0;
1108
1116  virtual uint64_t read_register(const std::string &path, const uint32_t field, const size_t mboard = 0) = 0;
1117
1118  /*******************************************************************
1119  * Filter API methods
1120  ******************************************************************/
1121
1132  virtual std::vector<std::string> get_filter_names(const std::string &search_mask = "") = 0;
1133
1139  virtual filter_info_base::sptr get_filter(const std::string &path) = 0;
1140
1148  virtual void set_filter(const std::string &path, filter_info_base::sptr filter) = 0;
1149
1150 };
1151
1152 }}
1153
1154 #endif /* INCLUDED_UHD_USRP_MULTI_USRP_HPP */
Definition: multi_usrp.hpp:664
Definition: stream_cmd.hpp:46
Definition: tune_result.hpp:29
Definition: multi_usrp.hpp:908
Definition: multi_usrp.hpp:882
Definition: time_spec.hpp:39
bool readable
Definition: multi_usrp.hpp:1081
Definition: device.hpp:41
boost::shared_ptr< multi_usrp > sptr
Definition: multi_usrp.hpp:103
Definition: multi_usrp.hpp:1079
Definition: multi_usrp.hpp:638
Definition: tune_request.hpp:33
Definition: stream.hpp:171
A wildcard gain element name.
Definition: multi_usrp.hpp:114
Definition: build_info.hpp:25
Definition: sensors.hpp:38
boost::shared_ptr< filter_info_base > sptr
Definition: filters.hpp:38
Definition: multi_usrp.hpp:101
Definition: stream.hpp:57
Definition: config.h:73
Definition: soft_register.hpp:98
Definition: dboard_iface.hpp:64
Definition: multi_usrp.hpp:596
Definition: multi_usrp.hpp:117
bool writable
Definition: multi_usrp.hpp:1082
Definition: ranges.hpp:68
size_t bitwidth
Definition: multi_usrp.hpp:1080
Definition: stream.hpp:247
Definition: multi_usrp.hpp:934
