18 #ifndef INCLUDED_UHD_USRP_MULTI_USRP_HPP    19 #define INCLUDED_UHD_USRP_MULTI_USRP_HPP    22 #define UHD_USRP_MULTI_USRP_REF_SOURCES_API    23 #define UHD_USRP_MULTI_USRP_GET_RATES_API    24 #define UHD_USRP_MULTI_USRP_FRONTEND_CAL_API    25 #define UHD_USRP_MULTI_USRP_FRONTEND_IQ_AUTO_API    26 #define UHD_USRP_MULTI_USRP_COMMAND_TIME_API    27 #define UHD_USRP_MULTI_USRP_BW_RANGE_API    28 #define UHD_USRP_MULTI_USRP_USER_REGS_API    29 #define UHD_USRP_MULTI_USRP_GET_USRP_INFO_API    30 #define UHD_USRP_MULTI_USRP_NORMALIZED_GAIN    31 #define UHD_USRP_MULTI_USRP_GPIO_API    32 #define UHD_USRP_MULTI_USRP_REGISTER_API    33 #define UHD_USRP_MULTI_USRP_FILTER_API    34 #define UHD_USRP_MULTI_USRP_LO_CONFIG_API    47 #include <boost/shared_ptr.hpp>    48 #include <boost/utility.hpp>    53 namespace uhd{
namespace usrp{
   103     typedef boost::shared_ptr<multi_usrp>
sptr;
   108     static const size_t ALL_MBOARDS = size_t(~0);
   111     static const size_t ALL_CHANS = size_t(~0);
   185     virtual void set_master_clock_rate(
double rate,
size_t mboard = ALL_MBOARDS) = 0;
   192     virtual double get_master_clock_rate(
size_t mboard = 0) = 0;
   198     virtual std::string get_pp_string(
void) = 0;
   205     virtual std::string get_mboard_name(
   212     virtual time_spec_t get_time_now(
   219     virtual time_spec_t get_time_last_pps(
   232     virtual void set_time_now(
const time_spec_t &time_spec,
   246     virtual void set_time_next_pps(
   263     virtual void set_time_unknown_pps(
const time_spec_t &time_spec) = 0;
   271     virtual bool get_time_synchronized(
void) = 0;
   283     virtual void set_command_time(
const uhd::time_spec_t &time_spec,
   290     virtual void clear_command_time(
   304     virtual void issue_stream_cmd(
const stream_cmd_t &stream_cmd,
size_t chan = ALL_CHANS) = 0;
   314     virtual void set_clock_config(
const clock_config_t &clock_config,
   324     virtual void set_time_source(
const std::string &source,
const size_t mboard = ALL_MBOARDS) = 0;
   331     virtual std::string get_time_source(
const size_t mboard) = 0;
   338     virtual std::vector<std::string> get_time_sources(
   347     virtual void set_clock_source(
   354     virtual std::string get_clock_source(
   361     virtual std::vector<std::string> get_clock_sources(
   371     virtual void set_clock_source_out(
const bool enb,
   381     virtual void set_time_source_out(
const bool enb,
   386     virtual size_t get_num_mboards(
void) = 0;
   394     virtual sensor_value_t get_mboard_sensor(
const std::string &name,
   401     virtual std::vector<std::string> get_mboard_sensor_names(
   410     virtual void set_user_register(
const uint8_t addr,
const uint32_t data,
   437     virtual size_t get_rx_num_channels(
void) = 0;
   444     virtual std::string get_rx_subdev_name(
size_t chan = 0) = 0;
   451     virtual void set_rx_rate(
double rate,
   458     virtual double get_rx_rate(
   482     virtual double get_rx_freq(
   493     virtual freq_range_t get_rx_freq_range(
   500     virtual freq_range_t get_fe_rx_freq_range(
   507     virtual std::vector<std::string> get_rx_lo_names(
   518     virtual void set_rx_lo_source(
const std::string &src,
const std::string &name = ALL_LOS,
   528     virtual const std::string get_rx_lo_source(
   538     virtual std::vector<std::string> get_rx_lo_sources(
   548     virtual void set_rx_lo_export_enabled(
bool enabled,
   555     virtual bool get_rx_lo_export_enabled(
   564     virtual double set_rx_lo_freq(
double freq,
   574     virtual double get_rx_lo_freq(
   584     virtual freq_range_t get_rx_lo_freq_range(
   593     virtual void set_rx_gain(
double gain,
   597         return this->set_rx_gain(gain, ALL_GAINS, chan);
   616     virtual void set_normalized_rx_gain(
double gain,
   626     virtual void set_rx_agc(
bool enable,
   635     virtual double get_rx_gain(
   639         return this->get_rx_gain(ALL_GAINS, chan);
   652     virtual double get_normalized_rx_gain(
   661     virtual gain_range_t get_rx_gain_range(
   665         return this->get_rx_gain_range(ALL_GAINS, chan);
   674     virtual std::vector<std::string> get_rx_gain_names(
   681     virtual void set_rx_antenna(
const std::string &ant,
   688     virtual std::string get_rx_antenna(
   695     virtual std::vector<std::string> get_rx_antennas(
   702     virtual void set_rx_bandwidth(
double bandwidth,
   709     virtual double get_rx_bandwidth(
   716     virtual meta_range_t get_rx_bandwidth_range(
   733     virtual sensor_value_t get_rx_sensor(
   740     virtual std::vector<std::string> get_rx_sensor_names(
   754     virtual void set_rx_dc_offset(
const bool enb,
   763     virtual void set_rx_dc_offset(
const std::complex<double> &offset,
   771     virtual void set_rx_iq_balance(
const bool enb,
size_t chan) = 0;
   780     virtual void set_rx_iq_balance(
const std::complex<double> &correction,
   807     virtual size_t get_tx_num_channels(
void) = 0;
   814     virtual std::string get_tx_subdev_name(
   821     virtual void set_tx_rate(
double rate,
   828     virtual double get_tx_rate(
   852     virtual double get_tx_freq(
   863     virtual freq_range_t get_tx_freq_range(
   870     virtual freq_range_t get_fe_tx_freq_range(
   879     virtual void set_tx_gain(
double gain,
   883         return this->set_tx_gain(gain, ALL_GAINS, chan);
   896     virtual void set_normalized_tx_gain(
double gain,
   905     virtual double get_tx_gain(
   909         return this->get_tx_gain(ALL_GAINS, chan);
   922     virtual double get_normalized_tx_gain(
   931     virtual gain_range_t get_tx_gain_range(
   935         return this->get_tx_gain_range(ALL_GAINS, chan);
   944     virtual std::vector<std::string> get_tx_gain_names(
   951     virtual void set_tx_antenna(
   958     virtual std::string get_tx_antenna(
   965     virtual std::vector<std::string> get_tx_antennas(
   972     virtual void set_tx_bandwidth(
double bandwidth,
   979     virtual double get_tx_bandwidth(
   986     virtual meta_range_t get_tx_bandwidth_range(
  1003     virtual sensor_value_t get_tx_sensor(
  1010     virtual std::vector<std::string> get_tx_sensor_names(
  1018     virtual void set_tx_dc_offset(
  1027     virtual void set_tx_iq_balance(
  1038     virtual std::vector<std::string> get_gpio_banks(
  1056     virtual void set_gpio_attr(
const std::string &bank,
const std::string &attr,
const uint32_t value,
const uint32_t
mask = 0xffffffff,
const size_t mboard = 0) = 0;
  1074     virtual uint32_t get_gpio_attr(
  1090     virtual std::vector<std::string> enumerate_registers(
  1098     virtual register_info_t get_register_info(
const std::string &path,
  1107     virtual void write_register(
const uint32_t field,
const uint64_t value,
  1116     virtual uint64_t read_register(
  1132     virtual std::vector<std::string> get_filter_names(
const std::string &search_mask =
"") = 0;
Definition: multi_usrp.hpp:664
Definition: stream_cmd.hpp:46
Definition: tune_result.hpp:29
Definition: multi_usrp.hpp:908
Definition: multi_usrp.hpp:882
Definition: time_spec.hpp:39
bool readable
Definition: multi_usrp.hpp:1081
Definition: device.hpp:41
boost::shared_ptr< multi_usrp > sptr
Definition: multi_usrp.hpp:103
Definition: multi_usrp.hpp:1079
Definition: multi_usrp.hpp:638
Definition: tune_request.hpp:33
Definition: stream.hpp:171
static const std::string ALL_GAINS
A wildcard gain element name.
Definition: multi_usrp.hpp:114
Definition: build_info.hpp:25
Definition: sensors.hpp:38
boost::shared_ptr< filter_info_base > sptr
Definition: filters.hpp:38
Definition: multi_usrp.hpp:101
Definition: stream.hpp:57
Definition: config.h:73
Definition: soft_register.hpp:98
Definition: dboard_iface.hpp:64
Definition: multi_usrp.hpp:596
static const std::string ALL_LOS
Definition: multi_usrp.hpp:117
bool writable
Definition: multi_usrp.hpp:1082
size_t bitwidth
Definition: multi_usrp.hpp:1080
Definition: stream.hpp:247
Definition: multi_usrp.hpp:934
