Firmware and FPGA Images
Images Overview
Every USRP device must be loaded with special firmware and FPGA images. The methods of loading images into the device vary among devices:
  • USRP1: The host code will automatically load the firmware and FPGA at runtime.
  • USRP2: The user must manually write the images onto the USRP2 SD card.
  • USRP-N Series: The user programs an image into on-board storage, which then is automatically loaded at runtime.
  • USRP-E Series: The host code will automatically load the FPGA at runtime.
  • USRP-B Series: The host code will automatically load the FPGA at runtime.
  • USRP-X Series: The user programs an image into on-board storage, which then is automatically loaded at runtime.
Pre-built Images
Pre-built images are available for download.
The pre-built images come in two forms:
  • bundled with UHD software in a platform-specific installer
  • stand-alone platform-independent archive files
UHD Images Downloader
The UHD images downloader downloads UHD images compatible with the host code and places them in the default images directory.
The download script is typically installed into your $PATH and can be invoked by calling
uhd_images_downloader
It can also be found at: <install-path>/lib/uhd/utils/uhd_images_downloader.py
By default, it installs images to: <install-path>/share/uhd/images
Platform installers
The UNIX-based installers will install the images into /usr/share/uhd/images.
The Windows installers will install the images into C:/Program Files/UHD/share/uhd/images.
Archive install
When installing images from an archive, there are two options:
Option 1:
Unpack the archive into the UHD installation prefix. UHD software will always search <install-path>/share/uhd/images for image files. Where <install-path> was set by the CMAKE_INSTALL_PREFIX at configure-time.
Option 2:
Unpack the archive anywhere and set the UHD_IMAGES_DIR environment variable. The UHD_IMAGES_DIR environment variable may contain a list of paths. They should be ordered by preference.
Building Images
The UHD source repository comes with the source code necessary to build both firmware and FPGA images for all supported devices.
The build commands for a particular image can be found in <uhd-repo-path>/images/Makefile.
Xilinx FPGA builds
USRP Xilinx FPGA images are built with two different versions of ISE, depending on the device.
The build requires that you have a UNIX-like environment with Make. Make sure that xtclsh from the Xilinx ISE bin directory is in your $PATH.
  • Xilinx ISE 14.7: USRP X3x0 Series, USRP B2x0
See <uhd-repo-path>/fpga/usrp3/top/.
  • Xilinx ISSE 12.2: USRP N2x0, USRP B1x0, USRP E1x0, USRP2
See <uhd-repo-path>/fpga/usrp2/top/.
ZPU firmware builds
The ZPU GCC compiler is required to build the ZPU firmware images. The build requires that you have a UNIX-like environment with CMake and Make. Make sure that zpu-elf-gcc is in your $PATH.
See <uhd-repo-path>/firmware/zpu.
Altera FPGA builds
Quartus is required to build the Altera FPGA image for the USRP1. Pre-built images can also be found in <uhd-repo-path>/fpga/usrp1/rbf.
See <uhd-repo-path>/fpga/usrp1/toplevel/.
FX2 firmware builds
The SDCC compiler is required to build the FX2 firmware images. The build requires that you have a UNIX-like environment with CMake and Make.
See <uhd-repo-path>/firmware/fx2.
