18 #ifndef INCLUDED_UHD_TYPES_SID_HPP    19 #define INCLUDED_UHD_TYPES_SID_HPP    23 #include <boost/shared_ptr.hpp>    93         sid_t(uint8_t src_addr, uint8_t src_ep, uint8_t dst_addr, uint8_t dst_ep);
    95         sid_t(
const std::string &);
    98         std::string to_pp_string()
const;
   100         std::string to_pp_string_hex()
const;
   113             return (_sid >> 16) & 0xFFFF;
   117             return _sid & 0xFFFF;
   121             return (get_src() >> 8) & 0xFF;
   125             return get_src() & 0xFF;
   129             return (get_src_endpoint() >> 4) & 0xF;
   133             return (get_src_endpoint()) & 0xF;
   137             return (get_dst() >> 8) & 0xFF;
   141             return get_dst() & 0xFF;
   145             return (get_dst_endpoint() >> 4) & 0xF;
   149             return (get_dst_endpoint()) & 0xF;
   155         void set(uint32_t new_sid) { set_sid(new_sid); };
   159         void set_from_str(
   160         void set_sid(uint32_t new_sid);
   163         void set_src(uint32_t new_addr);
   166         void set_dst(uint32_t new_addr);
   167         void set_src_addr(uint32_t new_addr);
   168         void set_src_endpoint(uint32_t new_addr);
   169         void set_dst_addr(uint32_t new_addr);
   170         void set_dst_endpoint(uint32_t new_addr);
   171         void set_dst_xbarport(uint32_t new_xbarport);
   172         void set_dst_blockport(uint32_t new_blockport);
   184         sid_t operator = (uint32_t new_sid) {
   194         sid_t operator = (
const std::string &sid_str) {
   195             set_from_str(sid_str);
   200             return (not _set and not sid.
is_set()) or (_sid == sid.
get_sid());
   204             return _set and _sid == sid;
   217         operator uint32_t()
 const {
   221         operator bool()
 const {
   232         std::ios_base::fmtflags ff = out.flags();
   233         if (ff & std::ios::hex) {
Definition: algorithm.hpp:56
UHD_INLINE uint32_t get_dst_xbarport() const
Return crossbar port of the source.
Definition: sid.hpp:144
UHD_INLINE uint32_t get_src_xbarport() const
Definition: sid.hpp:128
UHD_INLINE uint32_t get_src() const
Return the 16-bit source address of this SID.
Definition: sid.hpp:112
UHD_INLINE uint32_t get_dst_addr() const
Return 8-bit address of the destination.
Definition: sid.hpp:136
UHD_INLINE uint32_t get_sid() const
Returns a 32-Bit representation of the SID if set, or zero otherwise.
Definition: sid.hpp:110
UHD_INLINE uint32_t get_dst() const
Return the 16-bit destination address of this SID.
Definition: sid.hpp:116
UHD_INLINE uint32_t get_src_blockport() const
Return block port of the source.
Definition: sid.hpp:132
Definition: build_info.hpp:25
UHD_INLINE uint32_t get_src_addr() const
Return 8-bit address of the source.
Definition: sid.hpp:120
std::string to_pp_string() const
Return a decimal string representation of the SID.
UHD_INLINE uint32_t get_src_endpoint() const
Return endpoint of the source.
Definition: sid.hpp:124
Represents a stream ID (SID).
Definition: sid.hpp:85
#define UHD_INLINE
Definition: config.h:63
Definition: config.h:73
bool is_set() const
Returns true if this actually holds a valid SID.
Definition: sid.hpp:103
UHD_INLINE uint32_t get_dst_endpoint() const
Return endpoint of the destination.
Definition: sid.hpp:140
UHD_API bool operator==(const time_spec_t &, const time_spec_t &)
std::string to_pp_string_hex() const
Return a hexadecimal string representation of the SID.
UHD_INLINE uint32_t get_dst_blockport() const
Definition: sid.hpp:148
