Each executable testbench has its own Makefile that automatically pulls in support for all supported simulators. The build infrastructure supports the following simulators:
In general running make <sim_target> will run the simulation and report results in the console. Running make help will print out all supported simulator targets. Currently, the following targets will work:
Supported Targets: ipclean: Cleanup all IP intermediate files clean: Cleanup all simulator intermediate files cleanall: Cleanup everything! xsim: Run the simulation using the Xilinx Vivado Simulator xclean: Cleanup Xilinx Vivado Simulator intermediate files vsim: Run the simulation using Modelsim vclean: Cleanup Modelsim intermediate files
XSim is the built-in simulator in the Xilinx Vivado toolchain. If you already met the prerequisites for building an FPGA image, then you don't need to install anything else.
Follow these steps to run a testbench:
Run the setenv.sh script for the USRP product that you are trying to simulate
$ source <repo>/usrp3/top/<product>/setupenv.sh
This step is required even if the simulation is generic because the toolchain requires an FPGA part number to load simulation models.
Run the simulator specific target
$ make xsim
ModelSim is a third-party simulation tool that is compatible with Vivado and the USRP FPGA build infrastructure.
Use the following one-time setup to install and configure Modelsim on your system
$ build_simlibsTo validate that everything was install properly run setupenv.sh again. You should see the following
Setting up X3x0 FPGA build environment (64-bit)... - Vivado: Found (/opt/Xilinx/Vivado/2014.4/bin) - Modelsim: Found (/opt/mentor/modelsim/modeltech/bin) - Modelsim Compiled Libs: Found (/opt/Xilinx/Vivado/2014.4/modelsim) Environment successfully initialized.
$ make vsim
If running the setupenv.sh script return an error like the following:
Vivado: Not found! (ERROR.. Builds and simulations will not work)
then it is possible that Vivado was not installed or it was not installed in the default location. If Vivado is installed in a non-default location, just run the following:
$ source <repo>/usrp3/top/<product>/setupenv.sh --vivado-path=<PATH>
Setting up X3x0 FPGA build environment (64-bit)... - Vivado: Found (/opt/Xilinx/Vivado/2014.4/bin) - Modelsim: Not found! (WARNING.. Simulations with vsim will not work) Environment successfully initialized.
or something like this (even when Modelsim is installed)
Setting up X3x0 FPGA build environment (64-bit)... - Vivado: Found (/opt/Xilinx/Vivado/2014.4/bin) Environment successfully initialized.
then it is possible that Modelsim was not installed or it was not installed in the default location. If Modelsim is installed in a non-default location, just run the following:
$ source <repo>/usrp3/top/<product>/setupenv.sh --modelsim-path=<PATH>
Setting up X3x0 FPGA build environment (64-bit)... - Vivado: Found (/opt/Xilinx/Vivado/2014.4/bin) - Modelsim: Found (/opt/mentor/modelsim/modeltech/bin) - Modelsim Compiled Libs: Not found! (Run build_simlibs to generate them.) Environment successfully initialized.
$ build_simlibs
