fpga=usrp1_fpga_4rx.rbf -- OR -- fw=usrp1_fw_custom.ihx -- OR -- fpga=usrp1_fpga_4rx.rbf, fw=usrp1_fw_custom.ihx
cd <install-path>/lib/uhd/utils ./usrp_burn_mb_eeprom --args=<optional device args> --values="mcr=<rate>"
The user may override the clock rate specified in the EEPROM by using a device address. Example:
