vrt_if_packet.hpp
2 // Copyright 2010-2014 Ettus Research LLC
4 //
6 //
7
8 #ifndef INCLUDED_UHD_TRANSPORT_VRT_IF_PACKET_HPP
9 #define INCLUDED_UHD_TRANSPORT_VRT_IF_PACKET_HPP
10
11 #include <uhd/config.hpp>
12 #include <stdint.h>
13 #include <cstddef> //size_t
14
15 namespace uhd{ namespace transport{
16
17 namespace vrt{
18
20  static const size_t num_vrl_words32 = 3;
21
23  static const size_t max_if_hdr_words32 = 7; //hdr+sid+cid+tsi+tsf
31  {
32  if_packet_info_t(void);
33
34  //link layer type - always set for pack and unpack
36  {
37  LINK_TYPE_NONE = 0x0,
38  LINK_TYPE_CHDR = 0x1,
39  LINK_TYPE_VRLP = 0x2
40  } link_type;
41
42  //packet type
44  {
45  // VRT language:
46  PACKET_TYPE_DATA = 0x0,
47  PACKET_TYPE_IF_EXT = 0x1,
48  PACKET_TYPE_CONTEXT = 0x2, //extension context: has_sid = true
49
50  // CHDR language:
51  //PACKET_TYPE_DATA = 0x0, // Data
52  PACKET_TYPE_FC = 0x1, // Flow control
53  PACKET_TYPE_ACK = 0x1, // Flow control (ack)
54  PACKET_TYPE_CMD = 0x2, // Command
55  PACKET_TYPE_RESP = 0x3, // Command response
56  PACKET_TYPE_ERROR = 0x3 // Command response: Error (the EOB bit is raised in this case)
57  } packet_type;
58
59  //size fields
60  size_t num_payload_words32; //required in pack, derived in unpack
61  size_t num_payload_bytes; //required in pack, derived in unpack
62  size_t num_header_words32; //derived in pack, derived in unpack
63  size_t num_packet_words32; //derived in pack, required in unpack
64
65  //header fields
66  size_t packet_count;
68  bool sob, eob;
70  bool error;
71
72  //optional fields
74  bool has_sid; uint32_t sid;
76  bool has_cid; uint64_t cid;
78  bool has_tsi; uint32_t tsi;
80  bool has_tsf; uint64_t tsf;
82  bool has_tlr; uint32_t tlr;
83  };
84
110  UHD_API void if_hdr_pack_be(
111  uint32_t *packet_buff,
112  if_packet_info_t &if_packet_info
113  );
114
149  const uint32_t *packet_buff,
150  if_packet_info_t &if_packet_info
151  );
152
161  UHD_API void if_hdr_pack_le(
162  uint32_t *packet_buff,
163  if_packet_info_t &if_packet_info
164  );
165
175  const uint32_t *packet_buff,
176  if_packet_info_t &if_packet_info
177  );
178
180  link_type(LINK_TYPE_NONE),
181  packet_type(PACKET_TYPE_DATA),
182  num_payload_words32(0),
183  num_payload_bytes(0),
184  num_header_words32(0),
185  num_packet_words32(0),
186  packet_count(0),
187  sob(false), eob(false),
188  error(false),
189  has_sid(false), sid(0),
190  has_cid(false), cid(0),
191  has_tsi(false), tsi(0),
192  has_tsf(false), tsf(0),
193  has_tlr(false), tlr(0)
194  {}
195
196 } //namespace vrt
197
198 }} //namespace
199
200 #endif /* INCLUDED_UHD_TRANSPORT_VRT_IF_PACKET_HPP */
Definition: vrt_if_packet.hpp:30
Definition: vrt_if_packet.hpp:63
UHD_API void if_hdr_unpack_le(const uint32_t *packet_buff, if_packet_info_t &if_packet_info)
Definition: vrt_if_packet.hpp:179
packet_type_t
Definition: vrt_if_packet.hpp:43
uint64_t tsf
Definition: vrt_if_packet.hpp:80
UHD_API void if_hdr_unpack_be(const uint32_t *packet_buff, if_packet_info_t &if_packet_info)
bool has_cid
Class ID.
Definition: vrt_if_packet.hpp:76
link_type_t
Definition: vrt_if_packet.hpp:35
uint32_t tlr
Definition: vrt_if_packet.hpp:82
Definition: build_info.hpp:14
uint32_t sid
Definition: vrt_if_packet.hpp:74
UHD_API void if_hdr_pack_be(uint32_t *packet_buff, if_packet_info_t &if_packet_info)
bool error
This is asserted for command responses that are errors (CHDR only)
Definition: vrt_if_packet.hpp:70
Definition: vrt_if_packet.hpp:61
#define UHD_INLINE
Definition: config.h:53
Definition: log.hpp:109
size_t packet_count
Definition: vrt_if_packet.hpp:66
Definition: config.h:63
Definition: vrt_if_packet.hpp:60
UHD_API void if_hdr_pack_le(uint32_t *packet_buff, if_packet_info_t &if_packet_info)
Definition: vrt_if_packet.hpp:62
bool sob
Asserted for start- or end-of-burst.
Definition: vrt_if_packet.hpp:68
uint32_t tsi
Definition: vrt_if_packet.hpp:78
