8 #ifndef INCLUDED_UHD_USRP_MULTI_USRP_HPP     9 #define INCLUDED_UHD_USRP_MULTI_USRP_HPP    12 #define UHD_USRP_MULTI_USRP_REF_SOURCES_API    13 #define UHD_USRP_MULTI_USRP_GET_RATES_API    14 #define UHD_USRP_MULTI_USRP_FRONTEND_CAL_API    15 #define UHD_USRP_MULTI_USRP_FRONTEND_IQ_AUTO_API    16 #define UHD_USRP_MULTI_USRP_COMMAND_TIME_API    17 #define UHD_USRP_MULTI_USRP_BW_RANGE_API    18 #define UHD_USRP_MULTI_USRP_USER_REGS_API    19 #define UHD_USRP_MULTI_USRP_GET_USRP_INFO_API    20 #define UHD_USRP_MULTI_USRP_NORMALIZED_GAIN    21 #define UHD_USRP_MULTI_USRP_GPIO_API    22 #define UHD_USRP_MULTI_USRP_REGISTER_API    23 #define UHD_USRP_MULTI_USRP_FILTER_API    24 #define UHD_USRP_MULTI_USRP_LO_CONFIG_API    37 #include <boost/shared_ptr.hpp>    38 #include <boost/utility.hpp>    43 namespace uhd{
namespace usrp{
    93     typedef boost::shared_ptr<multi_usrp>
sptr;
    98     static const size_t ALL_MBOARDS = size_t(~0);
   101     static const size_t ALL_CHANS = size_t(~0);
   175     virtual void set_master_clock_rate(
double rate,
size_t mboard = ALL_MBOARDS) = 0;
   182     virtual double get_master_clock_rate(
size_t mboard = 0) = 0;
   202     virtual meta_range_t get_master_clock_rate_range(
const size_t mboard = 0) = 0;
   208     virtual std::string get_pp_string(
void) = 0;
   215     virtual std::string get_mboard_name(
   222     virtual time_spec_t get_time_now(
   229     virtual time_spec_t get_time_last_pps(
   242     virtual void set_time_now(
const time_spec_t &time_spec,
   256     virtual void set_time_next_pps(
   273     virtual void set_time_unknown_pps(
const time_spec_t &time_spec) = 0;
   281     virtual bool get_time_synchronized(
void) = 0;
   293     virtual void set_command_time(
const uhd::time_spec_t &time_spec,
   300     virtual void clear_command_time(
   314     virtual void issue_stream_cmd(
const stream_cmd_t &stream_cmd,
size_t chan = ALL_CHANS) = 0;
   324     virtual void set_clock_config(
const clock_config_t &clock_config,
   334     virtual void set_time_source(
const std::string &source,
const size_t mboard = ALL_MBOARDS) = 0;
   341     virtual std::string get_time_source(
const size_t mboard) = 0;
   348     virtual std::vector<std::string> get_time_sources(
   357     virtual void set_clock_source(
   364     virtual std::string get_clock_source(
   371     virtual std::vector<std::string> get_clock_sources(
   381     virtual void set_clock_source_out(
const bool enb,
   391     virtual void set_time_source_out(
const bool enb,
   396     virtual size_t get_num_mboards(
void) = 0;
   404     virtual sensor_value_t get_mboard_sensor(
const std::string &name,
   411     virtual std::vector<std::string> get_mboard_sensor_names(
   420     virtual void set_user_register(
const uint8_t addr,
const uint32_t data,
   447     virtual size_t get_rx_num_channels(
void) = 0;
   454     virtual std::string get_rx_subdev_name(
size_t chan = 0) = 0;
   461     virtual void set_rx_rate(
double rate,
   468     virtual double get_rx_rate(
   492     virtual double get_rx_freq(
   503     virtual freq_range_t get_rx_freq_range(
   510     virtual freq_range_t get_fe_rx_freq_range(
   528     virtual std::vector<std::string> get_rx_lo_names(
   541     virtual void set_rx_lo_source(
   542             const std::string &src,
   543             const std::string &name = ALL_LOS,
   555     virtual const std::string get_rx_lo_source(
   556             const std::string &name = ALL_LOS,
   571     virtual std::vector<std::string> get_rx_lo_sources(
   572             const std::string &name = ALL_LOS,
   586     virtual void set_rx_lo_export_enabled(
   588             const std::string &name = ALL_LOS,
   597     virtual bool get_rx_lo_export_enabled(
   598             const std::string &name = ALL_LOS,
   625     virtual double set_rx_lo_freq(
   627             const std::string &name,
   641     virtual double get_rx_lo_freq(
   642             const std::string &name,
   656             const std::string &name,
   672     virtual std::vector<std::string> get_tx_lo_names(
   685     virtual void set_tx_lo_source(
   686             const std::string &src,
   687             const std::string &name = ALL_LOS,
   688             const size_t chan = 0
   699     virtual const std::string get_tx_lo_source(
   700             const std::string &name = ALL_LOS,
   701             const size_t chan = 0
   714     virtual std::vector<std::string> get_tx_lo_sources(
   715             const std::string &name = ALL_LOS,
   716             const size_t chan = 0
   729     virtual void set_tx_lo_export_enabled(
   731             const std::string &name = ALL_LOS,
   732             const size_t chan = 0
   740     virtual bool get_tx_lo_export_enabled(
   741             const std::string &name = ALL_LOS,
   742             const size_t chan = 0
   768     virtual double set_tx_lo_freq(
   770             const std::string &name,
   784     virtual double get_tx_lo_freq(
   785             const std::string &name,
   799             const std::string &name,
   813     virtual void set_rx_gain(
double gain,
   827     virtual std::vector<std::string> get_rx_gain_profile_names(
const size_t chan = 0) = 0;
   834     virtual void set_rx_gain_profile(
const std::string& profile,
   841     virtual std::string get_rx_gain_profile(
   845         return this->set_rx_gain(gain, ALL_GAINS, chan);
   864     virtual void set_normalized_rx_gain(
double gain,
   874     virtual void set_rx_agc(
bool enable,
   883     virtual double get_rx_gain(
   887         return this->get_rx_gain(ALL_GAINS, chan);
   900     virtual double get_normalized_rx_gain(
   909     virtual gain_range_t get_rx_gain_range(
   913         return this->get_rx_gain_range(ALL_GAINS, chan);
   922     virtual std::vector<std::string> get_rx_gain_names(
   929     virtual void set_rx_antenna(
const std::string &ant,
   936     virtual std::string get_rx_antenna(
   943     virtual std::vector<std::string> get_rx_antennas(
   950     virtual void set_rx_bandwidth(
double bandwidth,
   957     virtual double get_rx_bandwidth(
   964     virtual meta_range_t get_rx_bandwidth_range(
   981     virtual sensor_value_t get_rx_sensor(
   988     virtual std::vector<std::string> get_rx_sensor_names(
  1002     virtual void set_rx_dc_offset(
const bool enb,
  1011     virtual void set_rx_dc_offset(
const std::complex<double> &offset,
  1019     virtual void set_rx_iq_balance(
const bool enb,
size_t chan) = 0;
  1028     virtual void set_rx_iq_balance(
const std::complex<double> &correction,
  1055     virtual size_t get_tx_num_channels(
void) = 0;
  1062     virtual std::string get_tx_subdev_name(
  1069     virtual void set_tx_rate(
double rate,
  1076     virtual double get_tx_rate(
  1083     virtual meta_range_t get_tx_rates(
  1100     virtual double get_tx_freq(
  1111     virtual freq_range_t get_tx_freq_range(
  1118     virtual freq_range_t get_fe_tx_freq_range(
  1127     virtual void set_tx_gain(
double gain,
  1141     virtual std::vector<std::string> get_tx_gain_profile_names(
  1148     virtual void set_tx_gain_profile(
  1155     virtual std::string get_tx_gain_profile(
  1159         return this->set_tx_gain(gain, ALL_GAINS, chan);
  1172     virtual void set_normalized_tx_gain(
double gain,
  1181     virtual double get_tx_gain(
  1185         return this->get_tx_gain(ALL_GAINS, chan);
  1198     virtual double get_normalized_tx_gain(
  1207     virtual gain_range_t get_tx_gain_range(
  1211         return this->get_tx_gain_range(ALL_GAINS, chan);
  1220     virtual std::vector<std::string> get_tx_gain_names(
  1227     virtual void set_tx_antenna(
  1234     virtual std::string get_tx_antenna(
  1241     virtual std::vector<std::string> get_tx_antennas(
  1248     virtual void set_tx_bandwidth(
double bandwidth,
  1255     virtual double get_tx_bandwidth(
  1262     virtual meta_range_t get_tx_bandwidth_range(
  1279     virtual sensor_value_t get_tx_sensor(
  1286     virtual std::vector<std::string> get_tx_sensor_names(
  1294     virtual void set_tx_dc_offset(
  1303     virtual void set_tx_iq_balance(
  1314     virtual std::vector<std::string> get_gpio_banks(
  1332     virtual void set_gpio_attr(
const std::string &bank,
const std::string &attr,
const uint32_t value,
const uint32_t
mask = 0xffffffff,
  1359     virtual void set_gpio_attr(
const std::string &value,
const uint32_t
mask = 0xffffffff,
  1377     virtual uint32_t get_gpio_attr(
  1404     virtual std::vector<std::string> get_gpio_string_attr(
  1420     virtual std::vector<std::string> enumerate_registers(
  1428     virtual register_info_t get_register_info(
const std::string &path,
  1437     virtual void write_register(
const uint32_t field,
const uint64_t value,
  1446     virtual uint64_t read_register(
  1462     virtual std::vector<std::string> get_filter_names(
const std::string &search_mask =
"") = 0;
Definition: multi_usrp.hpp:912
Definition: stream_cmd.hpp:36
Definition: tune_result.hpp:19
Definition: multi_usrp.hpp:1184
Definition: multi_usrp.hpp:1158
Definition: time_spec.hpp:29
bool readable
Definition: multi_usrp.hpp:1411
Definition: device.hpp:31
boost::shared_ptr< multi_usrp > sptr
Definition: multi_usrp.hpp:93
Definition: multi_usrp.hpp:1409
Definition: multi_usrp.hpp:886
Definition: tune_request.hpp:25
Definition: stream.hpp:161
static const std::string ALL_GAINS
A wildcard gain element name.
Definition: multi_usrp.hpp:104
Definition: build_info.hpp:14
Definition: sensors.hpp:29
boost::shared_ptr< filter_info_base > sptr
Definition: filters.hpp:28
Definition: clock_config.hpp:26
Definition: stream.hpp:47
Definition: config.h:63
Definition: soft_register.hpp:87
Definition: dboard_iface.hpp:54
Definition: multi_usrp.hpp:844
static const std::string ALL_LOS
A wildcard LO stage name.
Definition: multi_usrp.hpp:107
Definition: subdev_spec.hpp:62
bool writable
Definition: multi_usrp.hpp:1412
size_t bitwidth
Definition: multi_usrp.hpp:1410
Definition: stream.hpp:237
Definition: multi_usrp.hpp:1210
