8 #ifndef INCLUDED_UHD_UTILS_LOG_HPP     9 #define INCLUDED_UHD_UTILS_LOG_HPP    12 #include <boost/current_function.hpp>    13 #include <boost/thread/thread.hpp>   121                 : verbosity(
uhd::log::
off) {}
   123                 const boost::posix_time::ptime &time_,
   125                 const std::string &file_,
   127                 const std::string &component_,
   128                 const boost::thread::id &thread_id_
   130                 verbosity(verbosity_),
   133                 component(component_),
   134                 thread_id(thread_id_)
   179 #define _UHD_LOG_INTERNAL(component, level) \   180     uhd::_log::log(level, __FILE__, __LINE__, component, boost::this_thread::get_id())   184 #if UHD_LOG_MIN_LEVEL < 1   185 #define UHD_LOG_TRACE(component, message) \   186     _UHD_LOG_INTERNAL(component, uhd::log::trace) << message;   188 #define UHD_LOG_TRACE(component, message)   191 #if UHD_LOG_MIN_LEVEL < 2   192 #define UHD_LOG_DEBUG(component, message) \   193     _UHD_LOG_INTERNAL(component, uhd::log::debug) << message;   195 #define UHD_LOG_DEBUG(component, message)   198 #if UHD_LOG_MIN_LEVEL < 3   199 #define UHD_LOG_INFO(component, message) \   200     _UHD_LOG_INTERNAL(component, uhd::log::info) << message;   202 #define UHD_LOG_INFO(component, message)   205 #if UHD_LOG_MIN_LEVEL < 4   206 #define UHD_LOG_WARNING(component, message) \   207     _UHD_LOG_INTERNAL(component, uhd::log::warning) << message;   209 #define UHD_LOG_WARNING(component, message)   212 #if UHD_LOG_MIN_LEVEL < 5   213 #define UHD_LOG_ERROR(component, message) \   214     _UHD_LOG_INTERNAL(component, uhd::log::error) << message;   216 #define UHD_LOG_ERROR(component, message)   219 #if UHD_LOG_MIN_LEVEL < 6   220 #define UHD_LOG_FATAL(component, message) \   221     _UHD_LOG_INTERNAL(component, uhd::log::fatal) << message;   223 #define UHD_LOG_FATAL(component, message)   226 #ifndef UHD_LOG_FASTPATH_DISABLE   231 #define UHD_LOG_FASTPATH(message)               \   232     uhd::_log::log_fastpath(message);   234 #define UHD_LOG_FASTPATH(message)   238 #define UHD_LOGGER_TRACE(component) _UHD_LOG_INTERNAL(component, uhd::log::trace)   239 #define UHD_LOGGER_DEBUG(component) _UHD_LOG_INTERNAL(component, uhd::log::debug)   240 #define UHD_LOGGER_INFO(component) _UHD_LOG_INTERNAL(component, uhd::log::info)   241 #define UHD_LOGGER_WARNING(component) _UHD_LOG_INTERNAL(component, uhd::log::warning)   242 #define UHD_LOGGER_ERROR(component) _UHD_LOG_INTERNAL(component, uhd::log::error)   243 #define UHD_LOGGER_FATAL(component) _UHD_LOG_INTERNAL(component, uhd::log::fatal)   246 #if defined(__GNUG__)   249     UHD_LOGGER_DEBUG("DEBUG") << __FILE__ << ":" << __LINE__ << " (" << __PRETTY_FUNCTION__ << ")";   253     UHD_LOGGER_DEBUG("DEBUG") << __FILE__ << ":" << __LINE__;   257 #define UHD_VAR(var)                                        \   258     UHD_LOGGER_DEBUG("DEBUG") << #var << " = " << var;   261 #define UHD_HEX(var)                                                    \   262     UHD_LOGGER_DEBUG("DEBUG") << #var << " = 0x" << std::hex << std::setfill('0') << std::setw(8) << var << std::dec;   265 namespace uhd{
namespace _log {
   268     void UHD_API log_fastpath(
const std::string &);
   275             const std::string &file,
   276             const unsigned int line,
   277             const std::string &component,
   278             const boost::thread::id thread_id
   285         #define INSERTION_OVERLOAD(x)   log& operator<< (x)             \   294         template <
typename T>
   295         INSERTION_OVERLOAD(T val)
   298         INSERTION_OVERLOAD(std::ostream& (*val)(std::ostream&))
   299         INSERTION_OVERLOAD(std::ios& (*val)(std::ios&))
   300         INSERTION_OVERLOAD(std::ios_base& (*val)(std::ios_base&))
   304         std::ostringstream _ss;
 boost::posix_time::ptime time
Definition: log.hpp:137
std::string file
Definition: log.hpp:139
unsigned int line
Definition: log.hpp:140
logging_info()
Definition: log.hpp:120
severity_level
Definition: log.hpp:104
logging_info(const boost::posix_time::ptime &time_, const uhd::log::severity_level &verbosity_, const std::string &file_, const size_t &line_, const std::string &component_, const boost::thread::id &thread_id_)
Definition: log.hpp:122
Definition: build_info.hpp:14
UHD_API void set_file_level(uhd::log::severity_level level)
uhd::log::severity_level verbosity
Definition: log.hpp:138
UHD_API void set_log_level(uhd::log::severity_level level)
UHD_API void set_logger_level(const std::string &logger, uhd::log::severity_level level)
Definition: log.hpp:142
Definition: config.h:63
std::string message
Definition: log.hpp:143
UHD_API void set_console_level(uhd::log::severity_level level)
std::string component
Definition: log.hpp:141
