8 #ifndef INCLUDED_UHD_USRP_MULTI_USRP_HPP     9 #define INCLUDED_UHD_USRP_MULTI_USRP_HPP    12 #define UHD_USRP_MULTI_USRP_REF_SOURCES_API    13 #define UHD_USRP_MULTI_USRP_GET_RATES_API    14 #define UHD_USRP_MULTI_USRP_FRONTEND_CAL_API    15 #define UHD_USRP_MULTI_USRP_FRONTEND_IQ_AUTO_API    16 #define UHD_USRP_MULTI_USRP_COMMAND_TIME_API    17 #define UHD_USRP_MULTI_USRP_BW_RANGE_API    18 #define UHD_USRP_MULTI_USRP_USER_REGS_API    19 #define UHD_USRP_MULTI_USRP_GET_USRP_INFO_API    20 #define UHD_USRP_MULTI_USRP_NORMALIZED_GAIN    21 #define UHD_USRP_MULTI_USRP_GPIO_API    22 #define UHD_USRP_MULTI_USRP_REGISTER_API    23 #define UHD_USRP_MULTI_USRP_FILTER_API    24 #define UHD_USRP_MULTI_USRP_LO_CONFIG_API    37 #include <boost/shared_ptr.hpp>    38 #include <boost/utility.hpp>    96     typedef boost::shared_ptr<multi_usrp>
sptr;
   101     static const size_t ALL_MBOARDS = size_t(~0);
   104     static const size_t ALL_CHANS = size_t(~0);
   130     virtual bool is_device3(
void) = 0;
   140     virtual boost::shared_ptr<uhd::device3> get_device3(
void) = 0;
   192     virtual void set_master_clock_rate(
double rate,
size_t mboard = ALL_MBOARDS) = 0;
   199     virtual double get_master_clock_rate(
size_t mboard = 0) = 0;
   219     virtual meta_range_t get_master_clock_rate_range(
const size_t mboard = 0) = 0;
   225     virtual std::string get_pp_string(
void) = 0;
   232     virtual std::string get_mboard_name(
   239     virtual time_spec_t get_time_now(
   246     virtual time_spec_t get_time_last_pps(
   259     virtual void set_time_now(
const time_spec_t &time_spec,
   273     virtual void set_time_next_pps(
   290     virtual void set_time_unknown_pps(
const time_spec_t &time_spec) = 0;
   298     virtual bool get_time_synchronized(
void) = 0;
   310     virtual void set_command_time(
const uhd::time_spec_t &time_spec,
   317     virtual void clear_command_time(
   331     virtual void issue_stream_cmd(
const stream_cmd_t &stream_cmd,
size_t chan = ALL_CHANS) = 0;
   341     virtual void set_clock_config(
const clock_config_t &clock_config,
   351     virtual void set_time_source(
const std::string &source,
const size_t mboard = ALL_MBOARDS) = 0;
   358     virtual std::string get_time_source(
const size_t mboard) = 0;
   365     virtual std::vector<std::string> get_time_sources(
   374     virtual void set_clock_source(
   381     virtual std::string get_clock_source(
   388     virtual std::vector<std::string> get_clock_sources(
   398     virtual void set_clock_source_out(
const bool enb,
   408     virtual void set_time_source_out(
const bool enb,
   413     virtual size_t get_num_mboards(
void) = 0;
   421     virtual sensor_value_t get_mboard_sensor(
const std::string &name,
   428     virtual std::vector<std::string> get_mboard_sensor_names(
   437     virtual void set_user_register(
const uint8_t addr,
const uint32_t data,
   464     virtual size_t get_rx_num_channels(
void) = 0;
   471     virtual std::string get_rx_subdev_name(
size_t chan = 0) = 0;
   478     virtual void set_rx_rate(
double rate,
   485     virtual double get_rx_rate(
   509     virtual double get_rx_freq(
   520     virtual freq_range_t get_rx_freq_range(
   527     virtual freq_range_t get_fe_rx_freq_range(
   545     virtual std::vector<std::string> get_rx_lo_names(
   558     virtual void set_rx_lo_source(
   559             const std::string &src,
   560             const std::string &name = ALL_LOS,
   572     virtual const std::string get_rx_lo_source(
   573             const std::string &name = ALL_LOS,
   588     virtual std::vector<std::string> get_rx_lo_sources(
   589             const std::string &name = ALL_LOS,
   603     virtual void set_rx_lo_export_enabled(
   605             const std::string &name = ALL_LOS,
   614     virtual bool get_rx_lo_export_enabled(
   615             const std::string &name = ALL_LOS,
   642     virtual double set_rx_lo_freq(
   644             const std::string &name,
   658     virtual double get_rx_lo_freq(
   659             const std::string &name,
   673             const std::string &name,
   689     virtual std::vector<std::string> get_tx_lo_names(
   702     virtual void set_tx_lo_source(
   703             const std::string &src,
   704             const std::string &name = ALL_LOS,
   705             const size_t chan = 0
   716     virtual const std::string get_tx_lo_source(
   717             const std::string &name = ALL_LOS,
   718             const size_t chan = 0
   731     virtual std::vector<std::string> get_tx_lo_sources(
   732             const std::string &name = ALL_LOS,
   733             const size_t chan = 0
   746     virtual void set_tx_lo_export_enabled(
   748             const std::string &name = ALL_LOS,
   749             const size_t chan = 0
   757     virtual bool get_tx_lo_export_enabled(
   758             const std::string &name = ALL_LOS,
   759             const size_t chan = 0
   785     virtual double set_tx_lo_freq(
   787             const std::string &name,
   801     virtual double get_tx_lo_freq(
   802             const std::string &name,
   816             const std::string &name,
   830     virtual void set_rx_gain(
double gain,
   844     virtual std::vector<std::string> get_rx_gain_profile_names(
const size_t chan = 0) = 0;
   851     virtual void set_rx_gain_profile(
const std::string& profile,
   858     virtual std::string get_rx_gain_profile(
   862         return this->set_rx_gain(gain, ALL_GAINS, chan);
   881     virtual void set_normalized_rx_gain(
double gain,
   891     virtual void set_rx_agc(
bool enable,
   900     virtual double get_rx_gain(
   904         return this->get_rx_gain(ALL_GAINS, chan);
   917     virtual double get_normalized_rx_gain(
   926     virtual gain_range_t get_rx_gain_range(
   930         return this->get_rx_gain_range(ALL_GAINS, chan);
   939     virtual std::vector<std::string> get_rx_gain_names(
   946     virtual void set_rx_antenna(
const std::string &ant,
   953     virtual std::string get_rx_antenna(
   960     virtual std::vector<std::string> get_rx_antennas(
   967     virtual void set_rx_bandwidth(
double bandwidth,
   974     virtual double get_rx_bandwidth(
   981     virtual meta_range_t get_rx_bandwidth_range(
   998     virtual sensor_value_t get_rx_sensor(
  1005     virtual std::vector<std::string> get_rx_sensor_names(
  1019     virtual void set_rx_dc_offset(
const bool enb,
  1028     virtual void set_rx_dc_offset(
const std::complex<double> &offset,
  1034     virtual meta_range_t get_rx_dc_offset_range(
  1042     virtual void set_rx_iq_balance(
const bool enb,
size_t chan) = 0;
  1051     virtual void set_rx_iq_balance(
const std::complex<double> &correction,
  1078     virtual size_t get_tx_num_channels(
void) = 0;
  1085     virtual std::string get_tx_subdev_name(
  1092     virtual void set_tx_rate(
double rate,
  1099     virtual double get_tx_rate(
  1106     virtual meta_range_t get_tx_rates(
  1123     virtual double get_tx_freq(
  1134     virtual freq_range_t get_tx_freq_range(
  1141     virtual freq_range_t get_fe_tx_freq_range(
  1150     virtual void set_tx_gain(
double gain,
  1164     virtual std::vector<std::string> get_tx_gain_profile_names(
  1171     virtual void set_tx_gain_profile(
  1178     virtual std::string get_tx_gain_profile(
  1182         return this->set_tx_gain(gain, ALL_GAINS, chan);
  1195     virtual void set_normalized_tx_gain(
double gain,
  1204     virtual double get_tx_gain(
  1208         return this->get_tx_gain(ALL_GAINS, chan);
  1221     virtual double get_normalized_tx_gain(
  1230     virtual gain_range_t get_tx_gain_range(
  1234         return this->get_tx_gain_range(ALL_GAINS, chan);
  1243     virtual std::vector<std::string> get_tx_gain_names(
  1250     virtual void set_tx_antenna(
  1257     virtual std::string get_tx_antenna(
  1264     virtual std::vector<std::string> get_tx_antennas(
  1271     virtual void set_tx_bandwidth(
double bandwidth,
  1278     virtual double get_tx_bandwidth(
  1285     virtual meta_range_t get_tx_bandwidth_range(
  1302     virtual sensor_value_t get_tx_sensor(
  1309     virtual std::vector<std::string> get_tx_sensor_names(
  1317     virtual void set_tx_dc_offset(
  1323     virtual meta_range_t get_tx_dc_offset_range(
  1332     virtual void set_tx_iq_balance(
  1343     virtual std::vector<std::string> get_gpio_banks(
  1361     virtual void set_gpio_attr(
const std::string &bank,
const std::string &attr,
const uint32_t value,
const uint32_t
mask = 0xffffffff,
  1388     virtual void set_gpio_attr(
const std::string &value,
const uint32_t
mask = 0xffffffff,
  1406     virtual uint32_t get_gpio_attr(
  1433     virtual std::vector<std::string> get_gpio_string_attr(
  1449     virtual std::vector<std::string> enumerate_registers(
  1457     virtual register_info_t get_register_info(
const std::string &path,
  1466     virtual void write_register(
const uint32_t field,
const uint64_t value,
  1475     virtual uint64_t read_register(
  1491     virtual std::vector<std::string> get_filter_names(
const std::string &search_mask =
"") = 0;
Definition: multi_usrp.hpp:929
Definition: stream_cmd.hpp:36
Definition: tune_result.hpp:19
Definition: multi_usrp.hpp:1207
Definition: multi_usrp.hpp:1181
Definition: time_spec.hpp:29
bool readable
Definition: multi_usrp.hpp:1440
Definition: device.hpp:31
boost::shared_ptr< multi_usrp > sptr
Definition: multi_usrp.hpp:96
Definition: multi_usrp.hpp:1438
Definition: multi_usrp.hpp:903
Definition: tune_request.hpp:25
Definition: stream.hpp:172
static const std::string ALL_GAINS
A wildcard gain element name.
Definition: multi_usrp.hpp:107
Definition: build_info.hpp:14
Definition: sensors.hpp:29
boost::shared_ptr< filter_info_base > sptr
Definition: filters.hpp:28
Definition: clock_config.hpp:26
Definition: multi_usrp.hpp:94
Definition: stream.hpp:58
Definition: config.h:63
Definition: soft_register.hpp:87
Definition: dboard_iface.hpp:54
Definition: multi_usrp.hpp:861
static const std::string ALL_LOS
A wildcard LO stage name.
Definition: multi_usrp.hpp:110
Definition: subdev_spec.hpp:62
bool writable
Definition: multi_usrp.hpp:1441
size_t bitwidth
Definition: multi_usrp.hpp:1439
Definition: stream.hpp:248
Definition: multi_usrp.hpp:1233
