UHD supports a C API, in case the C++ or Python APIs are not the right solution for your application.
In order to install the C API when building UHD from source, make sure you have the CMake variable ENABLE_C_API set to ON (e.g., by running cmake -DENABLE_C_API=ON).
The C API mirrors the C++ API, so the C++ reference manual can be used to understand the behaviour of the Python API as well.
The examples/ subdirectory provides several examples on how to use the C API. See also the usrp.h include file, which provides all the functionality that would be provided by uhd::usrp::multi_usrp in the C++ case.
UHD supports a Python API, in case the C++ or C APIs are not the right solution for your application.
In order to install the Python API when building UHD from source, make sure all the dependencies are available (see also Building and Installing UHD from source, you need Boost.Python from your Boost library). Make sure you have the CMake variable ENABLE_PYTHON_API set to ON (e.g., by running cmake -DENABLE_PYTHON_API=ON).
The Python API supports both Python 2 and 3, but if you have both versions installed, CMake might require some hints which version is the desired one. To force Python 3, UHD has a CMake variable ENABLE_PYTHON3
On Windows, only certain combinations of MSVC and Boost have proven functional. The following combinations are known to work (others might also work):
Static linking on is currently unsupported on Windows.
The Python API mirrors the C++ API, so the C++ reference manual can be used to understand the behaviour of the Python API as well.
Names in the Python API have been modified to follow a PEP8-compatible naming convention, for example, uhd::usrp::multi_usrp in C++ corresponds to uhd.usrp.MultiUSRP in Python (this makes UHD/Python code implicitly compatible with most linters, but it also has the side-effect of hiding symbols that get imported from the C++ domain). The following two snippets are equivalent. First the C++ version:
Now the Python version:
Not all API calls from the C++ API are also supported in the Python API, and the Python API has some additional functions that are not available in C++, but for the most part, the uhd::usrp::multi_usrp API is identical.
A common type of Python-based SDR applications are those which produce or consume a limited number of samples. For example, an application could receive a second's worth of samples, then do offline processing, print the result, and exit. For this case, convenience API calls were added to the Python API. The following snippet is an example of how to store 1 second of samples acquired at 1 Msps:
This kind of API is particularly useful in combination with Jupyter Notebooks or similar interactive environments.
