8 #ifndef INCLUDED_UHD_USRP_DBOARD_IFACE_HPP     9 #define INCLUDED_UHD_USRP_DBOARD_IFACE_HPP    17 #include <boost/shared_ptr.hpp>    19 #include <boost/thread/thread.hpp>    23 namespace uhd{
namespace usrp{
    54     typedef boost::shared_ptr<dboard_iface>
sptr;
    88     virtual special_props_t get_special_props(
void) = 0;
    97     virtual void write_aux_dac(
unit_t unit,
aux_dac_t which_dac,
double value) = 0;
   115     virtual void set_pin_ctrl(
   116         unit_t unit, uint32_t value, uint32_t
mask = 0xffff
   125     virtual uint32_t get_pin_ctrl(
unit_t unit) = 0;
   135     virtual void set_atr_reg(
   136         unit_t unit, atr_reg_t reg, uint32_t value, uint32_t
mask = 0xffff
   146     virtual uint32_t get_atr_reg(
unit_t unit, atr_reg_t reg) = 0;
   155     virtual void set_gpio_ddr(
   156         unit_t unit, uint32_t value, uint32_t
mask = 0xffff
   165     virtual uint32_t get_gpio_ddr(
unit_t unit) = 0;
   174     virtual void set_gpio_out(
   175         unit_t unit, uint32_t value, uint32_t
mask = 0xffff
   184     virtual uint32_t get_gpio_out(
unit_t unit) = 0;
   192     virtual uint32_t read_gpio(
unit_t unit) = 0;
   202     virtual void write_spi(
   218     virtual uint32_t read_write_spi(
   231     virtual void set_clock_rate(
unit_t unit,
double rate) = 0;
   239     virtual double get_clock_rate(
unit_t unit) = 0;
   247     virtual std::vector<double> get_clock_rates(
unit_t unit) = 0;
   255     virtual void set_clock_enabled(
unit_t unit,
bool enb) = 0;
   264     virtual double get_codec_rate(
unit_t unit) = 0;
   273     virtual void set_fe_connection(
   275         const std::string& fe_name,
   299     virtual void sleep(
const boost::chrono::nanoseconds& time);
 virtual ~dboard_iface(void)
Definition: dboard_iface.hpp:80
aux_adc_t
Definition: dboard_iface.hpp:73
Definition: serial.hpp:35
uhd::usrp::gpio_atr::gpio_atr_reg_t atr_reg_t
Definition: dboard_iface.hpp:78
Definition: time_spec.hpp:29
aux_dac_t
Definition: dboard_iface.hpp:65
Definition: build_info.hpp:14
Definition: dboard_iface.hpp:52
bool soft_clock_divider
Definition: dboard_iface.hpp:33
Definition: serial.hpp:95
Definition: fe_connection.hpp:17
gpio_atr_reg_t
Definition: gpio_defs.hpp:13
Definition: config.h:63
Definition: soft_register.hpp:87
Definition: dboard_iface.hpp:54
Definition: dboard_iface.hpp:55
Definition: dboard_iface.hpp:26
virtual bool has_set_fe_connection(const unit_t)
Definition: dboard_iface.hpp:281
unit_t
Definition: dboard_iface.hpp:58
bool mangle_i2c_addrs
Definition: dboard_iface.hpp:43
