serial.hpp
4 //
6 //
7
8 #ifndef INCLUDED_UHD_TYPES_SERIAL_HPP
9 #define INCLUDED_UHD_TYPES_SERIAL_HPP
10
11 #include <uhd/config.hpp>
12 #include <boost/shared_ptr.hpp>
13 #include <stdint.h>
14 #include <vector>
15
16 namespace uhd{
21  typedef std::vector<uint8_t> byte_vector_t;
22
36  public:
37  typedef boost::shared_ptr<i2c_iface> sptr;
38
39  virtual ~i2c_iface(void);
40
42  i2c_iface::sptr eeprom16(void);
43
49  virtual void write_i2c(
50  uint16_t addr,
51  const byte_vector_t &buf
52  ) = 0;
53
60  virtual byte_vector_t read_i2c(
61  uint16_t addr,
62  size_t num_bytes
63  ) = 0;
64
71  virtual void write_eeprom(
72  uint16_t addr,
73  uint16_t offset,
74  const byte_vector_t &buf
75  );
76
84  virtual byte_vector_t read_eeprom(
85  uint16_t addr,
86  uint16_t offset,
87  size_t num_bytes
88  );
89  };
90
100  enum edge_t{
101  EDGE_RISE = 'r',
102  EDGE_FALL = 'f'
103  };
104
107
110
113
115  size_t divider;
116
121  spi_config_t(edge_t edge = EDGE_RISE);
122  };
123
129  public:
130  typedef boost::shared_ptr<spi_iface> sptr;
131
132  virtual ~spi_iface(void);
133
143  virtual uint32_t transact_spi(
144  int which_slave,
145  const spi_config_t &config,
146  uint32_t data,
147  size_t num_bits,
148  bool readback
149  ) = 0;
150
159  virtual uint32_t read_spi(
160  int which_slave,
161  const spi_config_t &config,
162  uint32_t data,
163  size_t num_bits
164  );
165
173  virtual void write_spi(
174  int which_slave,
175  const spi_config_t &config,
176  uint32_t data,
177  size_t num_bits
178  );
179  };
180
185  public:
186  typedef boost::shared_ptr<uart_iface> sptr;
187
188  virtual ~uart_iface(void);
189
194  virtual void write_uart(const std::string &buf) = 0;
195
201  virtual std::string read_uart(double timeout) = 0;
202  };
203
204 } //namespace uhd
205
206 #endif /* INCLUDED_UHD_TYPES_SERIAL_HPP */
size_t divider
Optionally set the SPI clock divider for this transaction.
Definition: serial.hpp:115
Definition: serial.hpp:128
Definition: serial.hpp:35
bool use_custom_divider
Set the clock speed for this transaction.
Definition: serial.hpp:112
edge_t mosi_edge
on what edge is the mosi data valid?
Definition: serial.hpp:106
Definition: build_info.hpp:14
Definition: serial.hpp:95
boost::shared_ptr< spi_iface > sptr
Definition: serial.hpp:130
Definition: config.h:63
edge_t miso_edge
on what edge is the miso data valid?
Definition: serial.hpp:109
Definition: serial.hpp:184
Definition: serial.hpp:186
edge_t
Definition: serial.hpp:100
boost::shared_ptr< i2c_iface > sptr
Definition: serial.hpp:37
Definition: byte_vector.hpp:20
