multi_usrp.hpp
2 // Copyright 2010-2012,2014-2015 Ettus Research LLC
4 //
6 //
7
8 #ifndef INCLUDED_UHD_USRP_MULTI_USRP_HPP
9 #define INCLUDED_UHD_USRP_MULTI_USRP_HPP
10
11 //define API capabilities for compile time detection of new features
12 #define UHD_USRP_MULTI_USRP_REF_SOURCES_API
13 #define UHD_USRP_MULTI_USRP_GET_RATES_API
14 #define UHD_USRP_MULTI_USRP_FRONTEND_CAL_API
15 #define UHD_USRP_MULTI_USRP_FRONTEND_IQ_AUTO_API
16 #define UHD_USRP_MULTI_USRP_COMMAND_TIME_API
17 #define UHD_USRP_MULTI_USRP_BW_RANGE_API
18 #define UHD_USRP_MULTI_USRP_USER_REGS_API
19 #define UHD_USRP_MULTI_USRP_GET_USRP_INFO_API
20 #define UHD_USRP_MULTI_USRP_NORMALIZED_GAIN
21 #define UHD_USRP_MULTI_USRP_GPIO_API
22 #define UHD_USRP_MULTI_USRP_REGISTER_API
23 #define UHD_USRP_MULTI_USRP_FILTER_API
24 #define UHD_USRP_MULTI_USRP_LO_CONFIG_API
25
26 #include <uhd/config.hpp>
27 #include <uhd/device.hpp>
28 #include <uhd/deprecated.hpp>
29 #include <uhd/types/ranges.hpp>
30 #include <uhd/types/stream_cmd.hpp>
33 #include <uhd/types/sensors.hpp>
34 #include <uhd/types/filters.hpp>
35 #include <uhd/usrp/subdev_spec.hpp>
37 #include <boost/shared_ptr.hpp>
38 #include <boost/utility.hpp>
39 #include <complex>
40 #include <string>
41 #include <vector>
42
43 namespace uhd {
44  class device3;
45
46  namespace usrp{
47
94 class UHD_API multi_usrp : boost::noncopyable{
95 public:
96  typedef boost::shared_ptr<multi_usrp> sptr;
97
98  virtual ~multi_usrp(void) = 0;
99
101  static const size_t ALL_MBOARDS = size_t(~0);
102
104  static const size_t ALL_CHANS = size_t(~0);
105
107  static const std::string ALL_GAINS;
108
110  static const std::string ALL_LOS;
111
119  static sptr make(const device_addr_t &dev_addr);
120
126  virtual device::sptr get_device(void) = 0;
127
130  virtual bool is_device3(void) = 0;
131
140  virtual boost::shared_ptr<uhd::device3> get_device3(void) = 0;
141
143  virtual rx_streamer::sptr get_rx_stream(const stream_args_t &args) = 0;
144
146  virtual tx_streamer::sptr get_tx_stream(const stream_args_t &args) = 0;
147
155  virtual dict<std::string, std::string> get_usrp_rx_info(size_t chan = 0) = 0;
156
164  virtual dict<std::string, std::string> get_usrp_tx_info(size_t chan = 0) = 0;
165
166  /*******************************************************************
167  * Mboard methods
168  ******************************************************************/
169
192  virtual void set_master_clock_rate(double rate, size_t mboard = ALL_MBOARDS) = 0;
193
199  virtual double get_master_clock_rate(size_t mboard = 0) = 0;
200
219  virtual meta_range_t get_master_clock_rate_range(const size_t mboard = 0) = 0;
220
225  virtual std::string get_pp_string(void) = 0;
226
232  virtual std::string get_mboard_name(size_t mboard = 0) = 0;
233
239  virtual time_spec_t get_time_now(size_t mboard = 0) = 0;
240
246  virtual time_spec_t get_time_last_pps(size_t mboard = 0) = 0;
247
259  virtual void set_time_now(const time_spec_t &time_spec, size_t mboard = ALL_MBOARDS) = 0;
260
273  virtual void set_time_next_pps(const time_spec_t &time_spec, size_t mboard = ALL_MBOARDS) = 0;
274
290  virtual void set_time_unknown_pps(const time_spec_t &time_spec) = 0;
291
298  virtual bool get_time_synchronized(void) = 0;
299
310  virtual void set_command_time(const uhd::time_spec_t &time_spec, size_t mboard = ALL_MBOARDS) = 0;
311
317  virtual void clear_command_time(size_t mboard = ALL_MBOARDS) = 0;
318
331  virtual void issue_stream_cmd(const stream_cmd_t &stream_cmd, size_t chan = ALL_CHANS) = 0;
332
341  virtual void set_clock_config(const clock_config_t &clock_config, size_t mboard = ALL_MBOARDS) = 0;
342
351  virtual void set_time_source(const std::string &source, const size_t mboard = ALL_MBOARDS) = 0;
352
358  virtual std::string get_time_source(const size_t mboard) = 0;
359
365  virtual std::vector<std::string> get_time_sources(const size_t mboard) = 0;
366
374  virtual void set_clock_source(const std::string &source, const size_t mboard = ALL_MBOARDS) = 0;
375
381  virtual std::string get_clock_source(const size_t mboard) = 0;
382
388  virtual std::vector<std::string> get_clock_sources(const size_t mboard) = 0;
389
398  virtual void set_clock_source_out(const bool enb, const size_t mboard = ALL_MBOARDS) = 0;
399
408  virtual void set_time_source_out(const bool enb, const size_t mboard = ALL_MBOARDS) = 0;
409
413  virtual size_t get_num_mboards(void) = 0;
414
421  virtual sensor_value_t get_mboard_sensor(const std::string &name, size_t mboard = 0) = 0;
422
428  virtual std::vector<std::string> get_mboard_sensor_names(size_t mboard = 0) = 0;
429
437  virtual void set_user_register(const uint8_t addr, const uint32_t data, size_t mboard = ALL_MBOARDS) = 0;
438
439  /*******************************************************************
440  * RX methods
441  ******************************************************************/
450  virtual void set_rx_subdev_spec(const uhd::usrp::subdev_spec_t &spec, size_t mboard = ALL_MBOARDS) = 0;
451
457  virtual uhd::usrp::subdev_spec_t get_rx_subdev_spec(size_t mboard = 0) = 0;
458
464  virtual size_t get_rx_num_channels(void) = 0;
465
471  virtual std::string get_rx_subdev_name(size_t chan = 0) = 0;
472
478  virtual void set_rx_rate(double rate, size_t chan = ALL_CHANS) = 0;
479
485  virtual double get_rx_rate(size_t chan = 0) = 0;
486
492  virtual meta_range_t get_rx_rates(size_t chan = 0) = 0;
493
500  virtual tune_result_t set_rx_freq(
501  const tune_request_t &tune_request, size_t chan = 0
502  ) = 0;
503
509  virtual double get_rx_freq(size_t chan = 0) = 0;
510
520  virtual freq_range_t get_rx_freq_range(size_t chan = 0) = 0;
521
527  virtual freq_range_t get_fe_rx_freq_range(size_t chan = 0) = 0;
528
529  /**************************************************************************
530  * LO controls
531  *************************************************************************/
545  virtual std::vector<std::string> get_rx_lo_names(size_t chan = 0) = 0;
546
558  virtual void set_rx_lo_source(
559  const std::string &src,
560  const std::string &name = ALL_LOS,
561  size_t chan = 0
562  ) = 0;
563
572  virtual const std::string get_rx_lo_source(
573  const std::string &name = ALL_LOS,
574  size_t chan = 0
575  ) = 0;
576
588  virtual std::vector<std::string> get_rx_lo_sources(
589  const std::string &name = ALL_LOS,
590  size_t chan = 0
591  ) = 0;
592
603  virtual void set_rx_lo_export_enabled(
604  bool enabled,
605  const std::string &name = ALL_LOS,
606  size_t chan = 0
607  ) = 0;
608
614  virtual bool get_rx_lo_export_enabled(
615  const std::string &name = ALL_LOS,
616  size_t chan = 0
617  ) = 0;
618
642  virtual double set_rx_lo_freq(
643  double freq,
644  const std::string &name,
645  size_t chan = 0
646  ) = 0;
647
658  virtual double get_rx_lo_freq(
659  const std::string &name,
660  size_t chan = 0
661  ) = 0;
662
672  virtual freq_range_t get_rx_lo_freq_range(
673  const std::string &name,
674  size_t chan = 0
675  ) = 0;
676
689  virtual std::vector<std::string> get_tx_lo_names(size_t chan = 0) = 0;
690
702  virtual void set_tx_lo_source(
703  const std::string &src,
704  const std::string &name = ALL_LOS,
705  const size_t chan = 0
706  ) = 0;
707
716  virtual const std::string get_tx_lo_source(
717  const std::string &name = ALL_LOS,
718  const size_t chan = 0
719  ) = 0;
720
731  virtual std::vector<std::string> get_tx_lo_sources(
732  const std::string &name = ALL_LOS,
733  const size_t chan = 0
734  ) = 0;
735
746  virtual void set_tx_lo_export_enabled(
747  const bool enabled,
748  const std::string &name = ALL_LOS,
749  const size_t chan = 0
750  ) = 0;
751
757  virtual bool get_tx_lo_export_enabled(
758  const std::string &name = ALL_LOS,
759  const size_t chan = 0
760  ) = 0;
761
785  virtual double set_tx_lo_freq(
786  const double freq,
787  const std::string &name,
788  const size_t chan=0
789  ) = 0;
790
801  virtual double get_tx_lo_freq(
802  const std::string &name,
803  const size_t chan=0
804  ) = 0;
805
815  virtual freq_range_t get_tx_lo_freq_range(
816  const std::string &name,
817  const size_t chan=0
818  ) = 0;
819
820  /**************************************************************************
821  * Gain controls
822  *************************************************************************/
830  virtual void set_rx_gain(double gain, const std::string &name, size_t chan = 0) = 0;
831
844  virtual std::vector<std::string> get_rx_gain_profile_names(const size_t chan = 0) = 0;
845
851  virtual void set_rx_gain_profile(const std::string& profile, const size_t chan = 0) = 0;
852
858  virtual std::string get_rx_gain_profile(const size_t chan = 0) = 0;
859
861  void set_rx_gain(double gain, size_t chan = 0){
862  return this->set_rx_gain(gain, ALL_GAINS, chan);
863  }
864
881  virtual void set_normalized_rx_gain(double gain, size_t chan = 0) = 0;
882
891  virtual void set_rx_agc(bool enable, size_t chan = 0) = 0;
892
900  virtual double get_rx_gain(const std::string &name, size_t chan = 0) = 0;
901
903  double get_rx_gain(size_t chan = 0){
904  return this->get_rx_gain(ALL_GAINS, chan);
905  }
906
917  virtual double get_normalized_rx_gain(size_t chan = 0) = 0;
918
926  virtual gain_range_t get_rx_gain_range(const std::string &name, size_t chan = 0) = 0;
927
929  gain_range_t get_rx_gain_range(size_t chan = 0){
930  return this->get_rx_gain_range(ALL_GAINS, chan);
931  }
932
939  virtual std::vector<std::string> get_rx_gain_names(size_t chan = 0) = 0;
940
946  virtual void set_rx_antenna(const std::string &ant, size_t chan = 0) = 0;
947
953  virtual std::string get_rx_antenna(size_t chan = 0) = 0;
954
960  virtual std::vector<std::string> get_rx_antennas(size_t chan = 0) = 0;
961
967  virtual void set_rx_bandwidth(double bandwidth, size_t chan = 0) = 0;
968
974  virtual double get_rx_bandwidth(size_t chan = 0) = 0;
975
981  virtual meta_range_t get_rx_bandwidth_range(size_t chan = 0) = 0;
982
990  virtual dboard_iface::sptr get_rx_dboard_iface(size_t chan = 0) = 0;
991
998  virtual sensor_value_t get_rx_sensor(const std::string &name, size_t chan = 0) = 0;
999
1005  virtual std::vector<std::string> get_rx_sensor_names(size_t chan = 0) = 0;
1006
1019  virtual void set_rx_dc_offset(const bool enb, size_t chan = ALL_CHANS) = 0;
1020
1028  virtual void set_rx_dc_offset(const std::complex<double> &offset, size_t chan = ALL_CHANS) = 0;
1029
1034  virtual meta_range_t get_rx_dc_offset_range(size_t chan = ALL_CHANS) = 0;
1035
1042  virtual void set_rx_iq_balance(const bool enb, size_t chan) = 0;
1043
1051  virtual void set_rx_iq_balance(const std::complex<double> &correction, size_t chan = ALL_CHANS) = 0;
1052
1053  /*******************************************************************
1054  * TX methods
1055  ******************************************************************/
1064  virtual void set_tx_subdev_spec(const uhd::usrp::subdev_spec_t &spec, size_t mboard = ALL_MBOARDS) = 0;
1065
1071  virtual uhd::usrp::subdev_spec_t get_tx_subdev_spec(size_t mboard = 0) = 0;
1072
1078  virtual size_t get_tx_num_channels(void) = 0;
1079
1085  virtual std::string get_tx_subdev_name(size_t chan = 0) = 0;
1086
1092  virtual void set_tx_rate(double rate, size_t chan = ALL_CHANS) = 0;
1093
1099  virtual double get_tx_rate(size_t chan = 0) = 0;
1100
1106  virtual meta_range_t get_tx_rates(size_t chan = 0) = 0;
1107
1114  virtual tune_result_t set_tx_freq(
1115  const tune_request_t &tune_request, size_t chan = 0
1116  ) = 0;
1117
1123  virtual double get_tx_freq(size_t chan = 0) = 0;
1124
1134  virtual freq_range_t get_tx_freq_range(size_t chan = 0) = 0;
1135
1141  virtual freq_range_t get_fe_tx_freq_range(size_t chan = 0) = 0;
1142
1150  virtual void set_tx_gain(double gain, const std::string &name, size_t chan = 0) = 0;
1151
1164  virtual std::vector<std::string> get_tx_gain_profile_names(const size_t chan = 0) = 0;
1165
1171  virtual void set_tx_gain_profile(const std::string& profile, const size_t chan = 0) = 0;
1172
1178  virtual std::string get_tx_gain_profile(const size_t chan = 0) = 0;
1179
1181  void set_tx_gain(double gain, size_t chan = 0){
1182  return this->set_tx_gain(gain, ALL_GAINS, chan);
1183  }
1184
1195  virtual void set_normalized_tx_gain(double gain, size_t chan = 0) = 0;
1196
1204  virtual double get_tx_gain(const std::string &name, size_t chan = 0) = 0;
1205
1207  double get_tx_gain(size_t chan = 0){
1208  return this->get_tx_gain(ALL_GAINS, chan);
1209  }
1210
1221  virtual double get_normalized_tx_gain(size_t chan = 0) = 0;
1222
1230  virtual gain_range_t get_tx_gain_range(const std::string &name, size_t chan = 0) = 0;
1231
1234  return this->get_tx_gain_range(ALL_GAINS, chan);
1235  }
1236
1243  virtual std::vector<std::string> get_tx_gain_names(size_t chan = 0) = 0;
1244
1250  virtual void set_tx_antenna(const std::string &ant, size_t chan = 0) = 0;
1251
1257  virtual std::string get_tx_antenna(size_t chan = 0) = 0;
1258
1264  virtual std::vector<std::string> get_tx_antennas(size_t chan = 0) = 0;
1265
1271  virtual void set_tx_bandwidth(double bandwidth, size_t chan = 0) = 0;
1272
1278  virtual double get_tx_bandwidth(size_t chan = 0) = 0;
1279
1285  virtual meta_range_t get_tx_bandwidth_range(size_t chan = 0) = 0;
1286
1294  virtual dboard_iface::sptr get_tx_dboard_iface(size_t chan = 0) = 0;
1295
1302  virtual sensor_value_t get_tx_sensor(const std::string &name, size_t chan = 0) = 0;
1303
1309  virtual std::vector<std::string> get_tx_sensor_names(size_t chan = 0) = 0;
1310
1317  virtual void set_tx_dc_offset(const std::complex<double> &offset, size_t chan = ALL_CHANS) = 0;
1318
1323  virtual meta_range_t get_tx_dc_offset_range(size_t chan = ALL_CHANS) = 0;
1324
1332  virtual void set_tx_iq_balance(const std::complex<double> &correction, size_t chan = ALL_CHANS) = 0;
1333
1334  /*******************************************************************
1335  * GPIO methods
1336  ******************************************************************/
1337
1343  virtual std::vector<std::string> get_gpio_banks(const size_t mboard) = 0;
1344
1361  virtual void set_gpio_attr(const std::string &bank, const std::string &attr, const uint32_t value, const uint32_t mask = 0xffffffff, const size_t mboard = 0) = 0;
1362
1388  virtual void set_gpio_attr(const std::string &bank, const std::string &attr, const std::string &value, const uint32_t mask = 0xffffffff, const size_t mboard = 0) = 0;
1389
1406  virtual uint32_t get_gpio_attr(const std::string &bank, const std::string &attr, const size_t mboard = 0) = 0;
1407
1433  virtual std::vector<std::string> get_gpio_string_attr(const std::string &bank, const std::string &attr, const size_t mboard = 0) = 0;
1434
1435  /*******************************************************************
1436  * Register IO methods
1437  ******************************************************************/
1439  size_t bitwidth;
1440  bool readable;
1441  bool writable;
1442  };
1443
1449  virtual std::vector<std::string> enumerate_registers(const size_t mboard = 0) = 0;
1450
1457  virtual register_info_t get_register_info(const std::string &path, const size_t mboard = 0) = 0;
1458
1466  virtual void write_register(const std::string &path, const uint32_t field, const uint64_t value, const size_t mboard = 0) = 0;
1467
1475  virtual uint64_t read_register(const std::string &path, const uint32_t field, const size_t mboard = 0) = 0;
1476
1477  /*******************************************************************
1478  * Filter API methods
1479  ******************************************************************/
1480
1491  virtual std::vector<std::string> get_filter_names(const std::string &search_mask = "") = 0;
1492
1498  virtual filter_info_base::sptr get_filter(const std::string &path) = 0;
1499
1507  virtual void set_filter(const std::string &path, filter_info_base::sptr filter) = 0;
1508
1509 };
1510
1511 }}
1512
1513 #endif /* INCLUDED_UHD_USRP_MULTI_USRP_HPP */
Definition: multi_usrp.hpp:929
Definition: stream_cmd.hpp:36
Definition: tune_result.hpp:19
Definition: multi_usrp.hpp:1207
Definition: multi_usrp.hpp:1181
Definition: time_spec.hpp:28
bool readable
Definition: multi_usrp.hpp:1440
Definition: device.hpp:31
boost::shared_ptr< multi_usrp > sptr
Definition: multi_usrp.hpp:96
Definition: multi_usrp.hpp:1438
Definition: multi_usrp.hpp:903
Definition: tune_request.hpp:25
Definition: stream.hpp:172
A wildcard gain element name.
Definition: multi_usrp.hpp:107
Definition: build_info.hpp:14
Definition: sensors.hpp:29
boost::shared_ptr< filter_info_base > sptr
Definition: filters.hpp:28
Definition: clock_config.hpp:26
Definition: multi_usrp.hpp:94
Definition: stream.hpp:58
Definition: config.h:68
Definition: soft_register.hpp:87
Definition: dboard_iface.hpp:54
Definition: multi_usrp.hpp:861
A wildcard LO stage name.
Definition: multi_usrp.hpp:110
Definition: subdev_spec.hpp:62
bool writable
Definition: multi_usrp.hpp:1441
Definition: ranges.hpp:64
size_t bitwidth
Definition: multi_usrp.hpp:1439
Definition: stream.hpp:248
Definition: multi_usrp.hpp:1233
