8 #ifndef INCLUDED_UHD_USRP_MULTI_USRP_HPP     9 #define INCLUDED_UHD_USRP_MULTI_USRP_HPP    12 #define UHD_USRP_MULTI_USRP_REF_SOURCES_API    13 #define UHD_USRP_MULTI_USRP_GET_RATES_API    14 #define UHD_USRP_MULTI_USRP_FRONTEND_CAL_API    15 #define UHD_USRP_MULTI_USRP_FRONTEND_IQ_AUTO_API    16 #define UHD_USRP_MULTI_USRP_COMMAND_TIME_API    17 #define UHD_USRP_MULTI_USRP_BW_RANGE_API    18 #define UHD_USRP_MULTI_USRP_USER_REGS_API    19 #define UHD_USRP_MULTI_USRP_GET_USRP_INFO_API    20 #define UHD_USRP_MULTI_USRP_NORMALIZED_GAIN    21 #define UHD_USRP_MULTI_USRP_GPIO_API    22 #define UHD_USRP_MULTI_USRP_REGISTER_API    23 #define UHD_USRP_MULTI_USRP_FILTER_API    24 #define UHD_USRP_MULTI_USRP_LO_CONFIG_API    25 #define UHD_USRP_MULTI_USRP_TX_LO_CONFIG_API    39 #include <boost/shared_ptr.hpp>    40 #include <boost/utility.hpp>    98     typedef boost::shared_ptr<multi_usrp>
sptr;
   132     virtual bool is_device3(
void) = 0;
   142     virtual boost::shared_ptr<uhd::device3> get_device3(
void) = 0;
   194     virtual void set_master_clock_rate(
double rate,
size_t mboard = ALL_MBOARDS) = 0;
   201     virtual double get_master_clock_rate(
size_t mboard = 0) = 0;
   221     virtual meta_range_t get_master_clock_rate_range(
const size_t mboard = 0) = 0;
   227     virtual std::string get_pp_string(
void) = 0;
   234     virtual std::string get_mboard_name(
   241     virtual time_spec_t get_time_now(
   248     virtual time_spec_t get_time_last_pps(
   261     virtual void set_time_now(
const time_spec_t &time_spec,
   275     virtual void set_time_next_pps(
   292     virtual void set_time_unknown_pps(
const time_spec_t &time_spec) = 0;
   300     virtual bool get_time_synchronized(
void) = 0;
   312     virtual void set_command_time(
const uhd::time_spec_t &time_spec,
   319     virtual void clear_command_time(
   333     virtual void issue_stream_cmd(
const stream_cmd_t &stream_cmd,
size_t chan = ALL_CHANS) = 0;
   343     virtual void set_clock_config(
const clock_config_t &clock_config,
   387     virtual void set_time_source(
   388             const std::string &source,
   389             const size_t mboard = ALL_MBOARDS
   397     virtual std::string get_time_source(
const size_t mboard) = 0;
   404     virtual std::vector<std::string> get_time_sources(
   448     virtual void set_clock_source(
   449             const std::string &source,
   450             const size_t mboard = ALL_MBOARDS
   458     virtual std::string get_clock_source(
   465     virtual std::vector<std::string> get_clock_sources(
   477     virtual void set_sync_source(
   478         const std::string &clock_source,
   479         const std::string &time_source,
   480         const size_t mboard = ALL_MBOARDS
   505     virtual void set_sync_source(
   507         const size_t mboard = ALL_MBOARDS
   515     virtual device_addr_t get_sync_source(
   522     virtual std::vector<device_addr_t> get_sync_sources(
   532     virtual void set_clock_source_out(
const bool enb,
const size_t mboard = ALL_MBOARDS) = 0;
   542     virtual void set_time_source_out(
const bool enb,
   547     virtual size_t get_num_mboards(
void) = 0;
   555     virtual sensor_value_t get_mboard_sensor(
const std::string &name,
   562     virtual std::vector<std::string> get_mboard_sensor_names(
   571     virtual void set_user_register(
const uint8_t addr,
const uint32_t data,
   624     virtual size_t get_rx_num_channels(
void) = 0;
   631     virtual std::string get_rx_subdev_name(
size_t chan = 0) = 0;
   638     virtual void set_rx_rate(
double rate,
   645     virtual double get_rx_rate(
   669     virtual double get_rx_freq(
   680     virtual freq_range_t get_rx_freq_range(
   687     virtual freq_range_t get_fe_rx_freq_range(
   705     virtual std::vector<std::string> get_rx_lo_names(
   718     virtual void set_rx_lo_source(
   719             const std::string &src,
   720             const std::string &name = ALL_LOS,
   732     virtual const std::string get_rx_lo_source(
   733             const std::string &name = ALL_LOS,
   748     virtual std::vector<std::string> get_rx_lo_sources(
   749             const std::string &name = ALL_LOS,
   763     virtual void set_rx_lo_export_enabled(
   765             const std::string &name = ALL_LOS,
   774     virtual bool get_rx_lo_export_enabled(
   775             const std::string &name = ALL_LOS,
   802     virtual double set_rx_lo_freq(
   804             const std::string &name,
   818     virtual double get_rx_lo_freq(
   819             const std::string &name,
   833             const std::string &name,
   849     virtual std::vector<std::string> get_tx_lo_names(
   862     virtual void set_tx_lo_source(
   863             const std::string &src,
   864             const std::string &name = ALL_LOS,
   865             const size_t chan = 0
   876     virtual const std::string get_tx_lo_source(
   877             const std::string &name = ALL_LOS,
   878             const size_t chan = 0
   891     virtual std::vector<std::string> get_tx_lo_sources(
   892             const std::string &name = ALL_LOS,
   893             const size_t chan = 0
   906     virtual void set_tx_lo_export_enabled(
   908             const std::string &name = ALL_LOS,
   909             const size_t chan = 0
   917     virtual bool get_tx_lo_export_enabled(
   918             const std::string &name = ALL_LOS,
   919             const size_t chan = 0
   945     virtual double set_tx_lo_freq(
   947             const std::string &name,
   961     virtual double get_tx_lo_freq(
   962             const std::string &name,
   976             const std::string &name,
   990     virtual void set_rx_gain(
double gain,
  1004     virtual std::vector<std::string> get_rx_gain_profile_names(
const size_t chan = 0) = 0;
  1011     virtual void set_rx_gain_profile(
const std::string& profile,
  1018     virtual std::string get_rx_gain_profile(
  1022         return this->set_rx_gain(gain, ALL_GAINS, chan);
  1041     virtual void set_normalized_rx_gain(
double gain,
  1051     virtual void set_rx_agc(
bool enable,
  1060     virtual double get_rx_gain(
  1064         return this->get_rx_gain(ALL_GAINS, chan);
  1077     virtual double get_normalized_rx_gain(
  1086     virtual gain_range_t get_rx_gain_range(
  1090         return this->get_rx_gain_range(ALL_GAINS, chan);
  1099     virtual std::vector<std::string> get_rx_gain_names(
  1106     virtual void set_rx_antenna(
const std::string &ant,
  1113     virtual std::string get_rx_antenna(
  1120     virtual std::vector<std::string> get_rx_antennas(
  1127     virtual void set_rx_bandwidth(
double bandwidth,
  1134     virtual double get_rx_bandwidth(
  1141     virtual meta_range_t get_rx_bandwidth_range(
  1158     virtual sensor_value_t get_rx_sensor(
  1165     virtual std::vector<std::string> get_rx_sensor_names(
  1179     virtual void set_rx_dc_offset(
const bool enb,
  1188     virtual void set_rx_dc_offset(
const std::complex<double> &offset,
  1194     virtual meta_range_t get_rx_dc_offset_range(
  1202     virtual void set_rx_iq_balance(
const bool enb,
size_t chan) = 0;
  1211     virtual void set_rx_iq_balance(
const std::complex<double> &correction,
  1238     virtual size_t get_tx_num_channels(
void) = 0;
  1245     virtual std::string get_tx_subdev_name(
  1252     virtual void set_tx_rate(
double rate,
  1259     virtual double get_tx_rate(
  1266     virtual meta_range_t get_tx_rates(
  1283     virtual double get_tx_freq(
  1294     virtual freq_range_t get_tx_freq_range(
  1301     virtual freq_range_t get_fe_tx_freq_range(
  1310     virtual void set_tx_gain(
double gain,
  1324     virtual std::vector<std::string> get_tx_gain_profile_names(
  1331     virtual void set_tx_gain_profile(
  1338     virtual std::string get_tx_gain_profile(
  1342         return this->set_tx_gain(gain, ALL_GAINS, chan);
  1355     virtual void set_normalized_tx_gain(
double gain,
  1364     virtual double get_tx_gain(
  1368         return this->get_tx_gain(ALL_GAINS, chan);
  1381     virtual double get_normalized_tx_gain(
  1390     virtual gain_range_t get_tx_gain_range(
  1394         return this->get_tx_gain_range(ALL_GAINS, chan);
  1403     virtual std::vector<std::string> get_tx_gain_names(
  1410     virtual void set_tx_antenna(
  1417     virtual std::string get_tx_antenna(
  1424     virtual std::vector<std::string> get_tx_antennas(
  1431     virtual void set_tx_bandwidth(
double bandwidth,
  1438     virtual double get_tx_bandwidth(
  1445     virtual meta_range_t get_tx_bandwidth_range(
  1462     virtual sensor_value_t get_tx_sensor(
  1469     virtual std::vector<std::string> get_tx_sensor_names(
  1477     virtual void set_tx_dc_offset(
  1483     virtual meta_range_t get_tx_dc_offset_range(
  1492     virtual void set_tx_iq_balance(
  1503     virtual std::vector<std::string> get_gpio_banks(
  1521     virtual void set_gpio_attr(
const std::string &bank,
const std::string &attr,
const uint32_t value,
const uint32_t
mask = 0xffffffff,
  1548     virtual void set_gpio_attr(
const std::string &value,
const uint32_t
mask = 0xffffffff,
  1566     virtual uint32_t get_gpio_attr(
  1593     virtual std::vector<std::string> get_gpio_string_attr(
  1609     virtual std::vector<std::string> enumerate_registers(
  1617     virtual register_info_t get_register_info(
const std::string &path,
  1626     virtual void write_register(
const uint32_t field,
const uint64_t value,
  1635     virtual uint64_t read_register(
  1651     virtual std::vector<std::string> get_filter_names(
const std::string &search_mask =
"") = 0;
Definition: multi_usrp.hpp:1089
boost::shared_ptr< wb_iface > sptr
Definition: wb_iface.hpp:22
Definition: stream_cmd.hpp:36
Definition: tune_result.hpp:19
Definition: multi_usrp.hpp:1367
Definition: multi_usrp.hpp:1341
Definition: time_spec.hpp:29
static const size_t ALL_MBOARDS
A wildcard motherboard index.
Definition: multi_usrp.hpp:103
bool readable
Definition: multi_usrp.hpp:1600
Definition: device.hpp:31
boost::shared_ptr< multi_usrp > sptr
Definition: multi_usrp.hpp:98
Definition: multi_usrp.hpp:1598
Definition: multi_usrp.hpp:1063
Definition: tune_request.hpp:25
Definition: stream.hpp:172
static const std::string ALL_GAINS
A wildcard gain element name.
Definition: multi_usrp.hpp:109
Definition: build_info.hpp:14
Definition: sensors.hpp:29
boost::shared_ptr< filter_info_base > sptr
Definition: filters.hpp:28
Definition: clock_config.hpp:26
Definition: multi_usrp.hpp:96
Definition: stream.hpp:58
Definition: config.h:68
Definition: soft_register.hpp:87
Definition: dboard_iface.hpp:54
Definition: multi_usrp.hpp:1021
static const std::string ALL_LOS
A wildcard LO stage name.
Definition: multi_usrp.hpp:112
Definition: subdev_spec.hpp:62
bool writable
Definition: multi_usrp.hpp:1601
size_t bitwidth
Definition: multi_usrp.hpp:1599
Definition: stream.hpp:248
static const size_t ALL_CHANS
A wildcard channel index.
Definition: multi_usrp.hpp:1393
