multi_usrp.hpp
2 // Copyright 2010-2012,2014-2015 Ettus Research LLC
4 //
6 //
7
8 #ifndef INCLUDED_UHD_USRP_MULTI_USRP_HPP
9 #define INCLUDED_UHD_USRP_MULTI_USRP_HPP
10
11 //define API capabilities for compile time detection of new features
12 #define UHD_USRP_MULTI_USRP_REF_SOURCES_API
13 #define UHD_USRP_MULTI_USRP_GET_RATES_API
14 #define UHD_USRP_MULTI_USRP_FRONTEND_CAL_API
15 #define UHD_USRP_MULTI_USRP_FRONTEND_IQ_AUTO_API
16 #define UHD_USRP_MULTI_USRP_COMMAND_TIME_API
17 #define UHD_USRP_MULTI_USRP_BW_RANGE_API
18 #define UHD_USRP_MULTI_USRP_USER_REGS_API
19 #define UHD_USRP_MULTI_USRP_GET_USRP_INFO_API
20 #define UHD_USRP_MULTI_USRP_NORMALIZED_GAIN
21 #define UHD_USRP_MULTI_USRP_GPIO_API
22 #define UHD_USRP_MULTI_USRP_REGISTER_API
23 #define UHD_USRP_MULTI_USRP_FILTER_API
24 #define UHD_USRP_MULTI_USRP_LO_CONFIG_API
25 #define UHD_USRP_MULTI_USRP_TX_LO_CONFIG_API
26
27 #include <uhd/config.hpp>
28 #include <uhd/device.hpp>
29 #include <uhd/deprecated.hpp>
30 #include <uhd/types/ranges.hpp>
31 #include <uhd/types/stream_cmd.hpp>
34 #include <uhd/types/sensors.hpp>
35 #include <uhd/types/filters.hpp>
36 #include <uhd/types/wb_iface.hpp>
37 #include <uhd/usrp/subdev_spec.hpp>
39 #include <boost/shared_ptr.hpp>
40 #include <boost/utility.hpp>
41 #include <complex>
42 #include <string>
43 #include <vector>
44
45 namespace uhd {
46  class device3;
47
48  namespace usrp{
49
96 class UHD_API multi_usrp : boost::noncopyable{
97 public:
98  typedef boost::shared_ptr<multi_usrp> sptr;
99
100  virtual ~multi_usrp(void) = 0;
101
103  static const size_t ALL_MBOARDS;
104
106  static const size_t ALL_CHANS;
107
109  static const std::string ALL_GAINS;
110
112  static const std::string ALL_LOS;
113
121  static sptr make(const device_addr_t &dev_addr);
122
128  virtual device::sptr get_device(void) = 0;
129
132  virtual bool is_device3(void) = 0;
133
142  virtual boost::shared_ptr<uhd::device3> get_device3(void) = 0;
143
145  virtual rx_streamer::sptr get_rx_stream(const stream_args_t &args) = 0;
146
148  virtual tx_streamer::sptr get_tx_stream(const stream_args_t &args) = 0;
149
157  virtual dict<std::string, std::string> get_usrp_rx_info(size_t chan = 0) = 0;
158
166  virtual dict<std::string, std::string> get_usrp_tx_info(size_t chan = 0) = 0;
167
168  /*******************************************************************
169  * Mboard methods
170  ******************************************************************/
171
194  virtual void set_master_clock_rate(double rate, size_t mboard = ALL_MBOARDS) = 0;
195
201  virtual double get_master_clock_rate(size_t mboard = 0) = 0;
202
221  virtual meta_range_t get_master_clock_rate_range(const size_t mboard = 0) = 0;
222
227  virtual std::string get_pp_string(void) = 0;
228
234  virtual std::string get_mboard_name(size_t mboard = 0) = 0;
235
241  virtual time_spec_t get_time_now(size_t mboard = 0) = 0;
242
248  virtual time_spec_t get_time_last_pps(size_t mboard = 0) = 0;
249
261  virtual void set_time_now(const time_spec_t &time_spec, size_t mboard = ALL_MBOARDS) = 0;
262
275  virtual void set_time_next_pps(const time_spec_t &time_spec, size_t mboard = ALL_MBOARDS) = 0;
276
292  virtual void set_time_unknown_pps(const time_spec_t &time_spec) = 0;
293
300  virtual bool get_time_synchronized(void) = 0;
301
312  virtual void set_command_time(const uhd::time_spec_t &time_spec, size_t mboard = ALL_MBOARDS) = 0;
313
319  virtual void clear_command_time(size_t mboard = ALL_MBOARDS) = 0;
320
333  virtual void issue_stream_cmd(const stream_cmd_t &stream_cmd, size_t chan = ALL_CHANS) = 0;
334
343  virtual void set_clock_config(const clock_config_t &clock_config, size_t mboard = ALL_MBOARDS) = 0;
344
387  virtual void set_time_source(
388  const std::string &source,
389  const size_t mboard = ALL_MBOARDS
390  ) = 0;
391
397  virtual std::string get_time_source(const size_t mboard) = 0;
398
404  virtual std::vector<std::string> get_time_sources(const size_t mboard) = 0;
405
448  virtual void set_clock_source(
449  const std::string &source,
450  const size_t mboard = ALL_MBOARDS
451  ) = 0;
452
458  virtual std::string get_clock_source(const size_t mboard) = 0;
459
465  virtual std::vector<std::string> get_clock_sources(const size_t mboard) = 0;
466
477  virtual void set_sync_source(
478  const std::string &clock_source,
479  const std::string &time_source,
480  const size_t mboard = ALL_MBOARDS
481  ) = 0;
482
505  virtual void set_sync_source(
506  const device_addr_t& sync_source,
507  const size_t mboard = ALL_MBOARDS
508  ) = 0;
509
515  virtual device_addr_t get_sync_source(const size_t mboard) = 0;
516
522  virtual std::vector<device_addr_t> get_sync_sources(const size_t mboard) = 0;
523
532  virtual void set_clock_source_out(const bool enb, const size_t mboard = ALL_MBOARDS) = 0;
533
542  virtual void set_time_source_out(const bool enb, const size_t mboard = ALL_MBOARDS) = 0;
543
547  virtual size_t get_num_mboards(void) = 0;
548
555  virtual sensor_value_t get_mboard_sensor(const std::string &name, size_t mboard = 0) = 0;
556
562  virtual std::vector<std::string> get_mboard_sensor_names(size_t mboard = 0) = 0;
563
571  virtual void set_user_register(const uint8_t addr, const uint32_t data, size_t mboard = ALL_MBOARDS) = 0;
572
597  virtual uhd::wb_iface::sptr get_user_settings_iface(const size_t chan = 0) = 0;
598
599  /*******************************************************************
600  * RX methods
601  ******************************************************************/
610  virtual void set_rx_subdev_spec(const uhd::usrp::subdev_spec_t &spec, size_t mboard = ALL_MBOARDS) = 0;
611
617  virtual uhd::usrp::subdev_spec_t get_rx_subdev_spec(size_t mboard = 0) = 0;
618
624  virtual size_t get_rx_num_channels(void) = 0;
625
631  virtual std::string get_rx_subdev_name(size_t chan = 0) = 0;
632
638  virtual void set_rx_rate(double rate, size_t chan = ALL_CHANS) = 0;
639
645  virtual double get_rx_rate(size_t chan = 0) = 0;
646
652  virtual meta_range_t get_rx_rates(size_t chan = 0) = 0;
653
660  virtual tune_result_t set_rx_freq(
661  const tune_request_t &tune_request, size_t chan = 0
662  ) = 0;
663
669  virtual double get_rx_freq(size_t chan = 0) = 0;
670
680  virtual freq_range_t get_rx_freq_range(size_t chan = 0) = 0;
681
687  virtual freq_range_t get_fe_rx_freq_range(size_t chan = 0) = 0;
688
689  /**************************************************************************
690  * LO controls
691  *************************************************************************/
705  virtual std::vector<std::string> get_rx_lo_names(size_t chan = 0) = 0;
706
718  virtual void set_rx_lo_source(
719  const std::string &src,
720  const std::string &name = ALL_LOS,
721  size_t chan = 0
722  ) = 0;
723
732  virtual const std::string get_rx_lo_source(
733  const std::string &name = ALL_LOS,
734  size_t chan = 0
735  ) = 0;
736
748  virtual std::vector<std::string> get_rx_lo_sources(
749  const std::string &name = ALL_LOS,
750  size_t chan = 0
751  ) = 0;
752
763  virtual void set_rx_lo_export_enabled(
764  bool enabled,
765  const std::string &name = ALL_LOS,
766  size_t chan = 0
767  ) = 0;
768
774  virtual bool get_rx_lo_export_enabled(
775  const std::string &name = ALL_LOS,
776  size_t chan = 0
777  ) = 0;
778
802  virtual double set_rx_lo_freq(
803  double freq,
804  const std::string &name,
805  size_t chan = 0
806  ) = 0;
807
818  virtual double get_rx_lo_freq(
819  const std::string &name,
820  size_t chan = 0
821  ) = 0;
822
832  virtual freq_range_t get_rx_lo_freq_range(
833  const std::string &name,
834  size_t chan = 0
835  ) = 0;
836
849  virtual std::vector<std::string> get_tx_lo_names(size_t chan = 0) = 0;
850
862  virtual void set_tx_lo_source(
863  const std::string &src,
864  const std::string &name = ALL_LOS,
865  const size_t chan = 0
866  ) = 0;
867
876  virtual const std::string get_tx_lo_source(
877  const std::string &name = ALL_LOS,
878  const size_t chan = 0
879  ) = 0;
880
891  virtual std::vector<std::string> get_tx_lo_sources(
892  const std::string &name = ALL_LOS,
893  const size_t chan = 0
894  ) = 0;
895
906  virtual void set_tx_lo_export_enabled(
907  const bool enabled,
908  const std::string &name = ALL_LOS,
909  const size_t chan = 0
910  ) = 0;
911
917  virtual bool get_tx_lo_export_enabled(
918  const std::string &name = ALL_LOS,
919  const size_t chan = 0
920  ) = 0;
921
945  virtual double set_tx_lo_freq(
946  const double freq,
947  const std::string &name,
948  const size_t chan=0
949  ) = 0;
950
961  virtual double get_tx_lo_freq(
962  const std::string &name,
963  const size_t chan=0
964  ) = 0;
965
975  virtual freq_range_t get_tx_lo_freq_range(
976  const std::string &name,
977  const size_t chan=0
978  ) = 0;
979
980  /**************************************************************************
981  * Gain controls
982  *************************************************************************/
990  virtual void set_rx_gain(double gain, const std::string &name, size_t chan = 0) = 0;
991
1004  virtual std::vector<std::string> get_rx_gain_profile_names(const size_t chan = 0) = 0;
1005
1011  virtual void set_rx_gain_profile(const std::string& profile, const size_t chan = 0) = 0;
1012
1018  virtual std::string get_rx_gain_profile(const size_t chan = 0) = 0;
1019
1021  void set_rx_gain(double gain, size_t chan = 0){
1022  return this->set_rx_gain(gain, ALL_GAINS, chan);
1023  }
1024
1041  virtual void set_normalized_rx_gain(double gain, size_t chan = 0) = 0;
1042
1051  virtual void set_rx_agc(bool enable, size_t chan = 0) = 0;
1052
1060  virtual double get_rx_gain(const std::string &name, size_t chan = 0) = 0;
1061
1063  double get_rx_gain(size_t chan = 0){
1064  return this->get_rx_gain(ALL_GAINS, chan);
1065  }
1066
1077  virtual double get_normalized_rx_gain(size_t chan = 0) = 0;
1078
1086  virtual gain_range_t get_rx_gain_range(const std::string &name, size_t chan = 0) = 0;
1087
1090  return this->get_rx_gain_range(ALL_GAINS, chan);
1091  }
1092
1099  virtual std::vector<std::string> get_rx_gain_names(size_t chan = 0) = 0;
1100
1106  virtual void set_rx_antenna(const std::string &ant, size_t chan = 0) = 0;
1107
1113  virtual std::string get_rx_antenna(size_t chan = 0) = 0;
1114
1120  virtual std::vector<std::string> get_rx_antennas(size_t chan = 0) = 0;
1121
1127  virtual void set_rx_bandwidth(double bandwidth, size_t chan = 0) = 0;
1128
1134  virtual double get_rx_bandwidth(size_t chan = 0) = 0;
1135
1141  virtual meta_range_t get_rx_bandwidth_range(size_t chan = 0) = 0;
1142
1150  virtual dboard_iface::sptr get_rx_dboard_iface(size_t chan = 0) = 0;
1151
1158  virtual sensor_value_t get_rx_sensor(const std::string &name, size_t chan = 0) = 0;
1159
1165  virtual std::vector<std::string> get_rx_sensor_names(size_t chan = 0) = 0;
1166
1179  virtual void set_rx_dc_offset(const bool enb, size_t chan = ALL_CHANS) = 0;
1180
1188  virtual void set_rx_dc_offset(const std::complex<double> &offset, size_t chan = ALL_CHANS) = 0;
1189
1194  virtual meta_range_t get_rx_dc_offset_range(size_t chan = ALL_CHANS) = 0;
1195
1202  virtual void set_rx_iq_balance(const bool enb, size_t chan) = 0;
1203
1211  virtual void set_rx_iq_balance(const std::complex<double> &correction, size_t chan = ALL_CHANS) = 0;
1212
1213  /*******************************************************************
1214  * TX methods
1215  ******************************************************************/
1224  virtual void set_tx_subdev_spec(const uhd::usrp::subdev_spec_t &spec, size_t mboard = ALL_MBOARDS) = 0;
1225
1231  virtual uhd::usrp::subdev_spec_t get_tx_subdev_spec(size_t mboard = 0) = 0;
1232
1238  virtual size_t get_tx_num_channels(void) = 0;
1239
1245  virtual std::string get_tx_subdev_name(size_t chan = 0) = 0;
1246
1252  virtual void set_tx_rate(double rate, size_t chan = ALL_CHANS) = 0;
1253
1259  virtual double get_tx_rate(size_t chan = 0) = 0;
1260
1266  virtual meta_range_t get_tx_rates(size_t chan = 0) = 0;
1267
1274  virtual tune_result_t set_tx_freq(
1275  const tune_request_t &tune_request, size_t chan = 0
1276  ) = 0;
1277
1283  virtual double get_tx_freq(size_t chan = 0) = 0;
1284
1294  virtual freq_range_t get_tx_freq_range(size_t chan = 0) = 0;
1295
1301  virtual freq_range_t get_fe_tx_freq_range(size_t chan = 0) = 0;
1302
1310  virtual void set_tx_gain(double gain, const std::string &name, size_t chan = 0) = 0;
1311
1324  virtual std::vector<std::string> get_tx_gain_profile_names(const size_t chan = 0) = 0;
1325
1331  virtual void set_tx_gain_profile(const std::string& profile, const size_t chan = 0) = 0;
1332
1338  virtual std::string get_tx_gain_profile(const size_t chan = 0) = 0;
1339
1341  void set_tx_gain(double gain, size_t chan = 0){
1342  return this->set_tx_gain(gain, ALL_GAINS, chan);
1343  }
1344
1355  virtual void set_normalized_tx_gain(double gain, size_t chan = 0) = 0;
1356
1364  virtual double get_tx_gain(const std::string &name, size_t chan = 0) = 0;
1365
1367  double get_tx_gain(size_t chan = 0){
1368  return this->get_tx_gain(ALL_GAINS, chan);
1369  }
1370
1381  virtual double get_normalized_tx_gain(size_t chan = 0) = 0;
1382
1390  virtual gain_range_t get_tx_gain_range(const std::string &name, size_t chan = 0) = 0;
1391
1394  return this->get_tx_gain_range(ALL_GAINS, chan);
1395  }
1396
1403  virtual std::vector<std::string> get_tx_gain_names(size_t chan = 0) = 0;
1404
1410  virtual void set_tx_antenna(const std::string &ant, size_t chan = 0) = 0;
1411
1417  virtual std::string get_tx_antenna(size_t chan = 0) = 0;
1418
1424  virtual std::vector<std::string> get_tx_antennas(size_t chan = 0) = 0;
1425
1431  virtual void set_tx_bandwidth(double bandwidth, size_t chan = 0) = 0;
1432
1438  virtual double get_tx_bandwidth(size_t chan = 0) = 0;
1439
1445  virtual meta_range_t get_tx_bandwidth_range(size_t chan = 0) = 0;
1446
1454  virtual dboard_iface::sptr get_tx_dboard_iface(size_t chan = 0) = 0;
1455
1462  virtual sensor_value_t get_tx_sensor(const std::string &name, size_t chan = 0) = 0;
1463
1469  virtual std::vector<std::string> get_tx_sensor_names(size_t chan = 0) = 0;
1470
1477  virtual void set_tx_dc_offset(const std::complex<double> &offset, size_t chan = ALL_CHANS) = 0;
1478
1483  virtual meta_range_t get_tx_dc_offset_range(size_t chan = ALL_CHANS) = 0;
1484
1492  virtual void set_tx_iq_balance(const std::complex<double> &correction, size_t chan = ALL_CHANS) = 0;
1493
1494  /*******************************************************************
1495  * GPIO methods
1496  ******************************************************************/
1497
1503  virtual std::vector<std::string> get_gpio_banks(const size_t mboard) = 0;
1504
1521  virtual void set_gpio_attr(const std::string &bank, const std::string &attr, const uint32_t value, const uint32_t mask = 0xffffffff, const size_t mboard = 0) = 0;
1522
1548  virtual void set_gpio_attr(const std::string &bank, const std::string &attr, const std::string &value, const uint32_t mask = 0xffffffff, const size_t mboard = 0) = 0;
1549
1566  virtual uint32_t get_gpio_attr(const std::string &bank, const std::string &attr, const size_t mboard = 0) = 0;
1567
1593  virtual std::vector<std::string> get_gpio_string_attr(const std::string &bank, const std::string &attr, const size_t mboard = 0) = 0;
1594
1595  /*******************************************************************
1596  * Register IO methods
1597  ******************************************************************/
1599  size_t bitwidth;
1600  bool readable;
1601  bool writable;
1602  };
1603
1609  virtual std::vector<std::string> enumerate_registers(const size_t mboard = 0) = 0;
1610
1617  virtual register_info_t get_register_info(const std::string &path, const size_t mboard = 0) = 0;
1618
1626  virtual void write_register(const std::string &path, const uint32_t field, const uint64_t value, const size_t mboard = 0) = 0;
1627
1635  virtual uint64_t read_register(const std::string &path, const uint32_t field, const size_t mboard = 0) = 0;
1636
1637  /*******************************************************************
1638  * Filter API methods
1639  ******************************************************************/
1640
1651  virtual std::vector<std::string> get_filter_names(const std::string &search_mask = "") = 0;
1652
1658  virtual filter_info_base::sptr get_filter(const std::string &path) = 0;
1659
1667  virtual void set_filter(const std::string &path, filter_info_base::sptr filter) = 0;
1668
1669 };
1670
1671 }}
1672
1673 #endif /* INCLUDED_UHD_USRP_MULTI_USRP_HPP */
Definition: multi_usrp.hpp:1089
boost::shared_ptr< wb_iface > sptr
Definition: wb_iface.hpp:22
Definition: stream_cmd.hpp:36
Definition: tune_result.hpp:19
Definition: multi_usrp.hpp:1367
Definition: multi_usrp.hpp:1341
Definition: time_spec.hpp:29
A wildcard motherboard index.
Definition: multi_usrp.hpp:103
bool readable
Definition: multi_usrp.hpp:1600
Definition: device.hpp:31
boost::shared_ptr< multi_usrp > sptr
Definition: multi_usrp.hpp:98
Definition: multi_usrp.hpp:1598
Definition: multi_usrp.hpp:1063
Definition: tune_request.hpp:25
Definition: stream.hpp:172
A wildcard gain element name.
Definition: multi_usrp.hpp:109
Definition: build_info.hpp:14
Definition: sensors.hpp:29
boost::shared_ptr< filter_info_base > sptr
Definition: filters.hpp:28
Definition: clock_config.hpp:26
Definition: multi_usrp.hpp:96
Definition: stream.hpp:58
Definition: config.h:68
Definition: soft_register.hpp:87
Definition: dboard_iface.hpp:54
Definition: multi_usrp.hpp:1021
A wildcard LO stage name.
Definition: multi_usrp.hpp:112
Definition: subdev_spec.hpp:62
bool writable
Definition: multi_usrp.hpp:1601
Definition: ranges.hpp:64
size_t bitwidth
Definition: multi_usrp.hpp:1599
Definition: stream.hpp:248
A wildcard channel index.
Definition: multi_usrp.hpp:1393
