8 #ifndef INCLUDED_UHD_UTILS_SOFT_REGISTER_HPP     9 #define INCLUDED_UHD_UTILS_SOFT_REGISTER_HPP    12 #include <boost/noncopyable.hpp>    16 #include <boost/thread/mutex.hpp>    17 #include <boost/thread/locks.hpp>    18 #include <boost/unordered_map.hpp>    19 #include <boost/tokenizer.hpp>    20 #include <boost/foreach.hpp>    41 #define UHD_DEFINE_SOFT_REG_FIELD(name, width, shift) \    42     static const uhd::soft_reg_field_t name = (((shift & 0xFF) << 8) | (width & 0xFF))    52     return __builtin_expect(expr,
true);
    62     return __builtin_expect(expr,
false);
    77 namespace soft_reg_field {
    79         return (field & 0xFF);
    83         return ((field >> 8) & 0xFF);
    86     template<
typename data_t>
    88         constexpr data_t ONE =
static_cast<data_t
>(1);
    89         constexpr data_t ALL_ONES = ~static_cast<data_t>(0);
    94             return ((ONE<<
width(field))-ONE)<<
shift(field);
    96             return ALL_ONES<<
shift(field);
   105     virtual void initialize(
wb_iface& iface,
bool sync =
false) = 0;
   106     virtual void flush() = 0;
   107     virtual void refresh() = 0;
   108     virtual size_t get_bitwidth() = 0;
   109     virtual bool is_readable() = 0;
   110     virtual bool is_writable() = 0;
   115     template <
typename soft_reg_t>
   117         soft_reg_t* ptr =
dynamic_cast<soft_reg_t*
   133 template<
typename reg_data_t,
bool readable,
bool writable>
   136     typedef boost::shared_ptr< soft_register_t<reg_data_t, readable, writable> >
sptr;
   148         _iface(NULL), _wr_addr(wr_addr), _rd_addr(rd_addr), _soft_copy(0), _flush_mode(mode)
   158         _iface(NULL), _wr_addr(addr), _rd_addr(addr), _soft_copy(0), _flush_mode(mode)
   171         if (sync && writable) flush();
   172         if (sync && readable) refresh();
   180     UHD_INLINE void set(
const soft_reg_field_t field,
const reg_data_t value)
   182         _soft_copy = (_soft_copy & ~soft_reg_field::mask<reg_data_t>(field)) |
   183                      ((value << soft_reg_field::shift(field)) & soft_reg_field::mask<reg_data_t>(field));
   200         if (writable && _iface) {
   204             if (_flush_mode == ALWAYS_FLUSH || _soft_copy.is_dirty()) {
   205                 if (get_bitwidth() <= 16) {
   206                     _iface->poke16(_wr_addr, static_cast<uint16_t>(_soft_copy));
   207                 }
else if (get_bitwidth() <= 32) {
   208                     _iface->poke32(_wr_addr, static_cast<uint32_t>(_soft_copy));
   209                 }
else if (get_bitwidth() <= 64) {
   210                     _iface->poke64(_wr_addr, static_cast<uint64_t>(_soft_copy));
   214                 _soft_copy.mark_clean();
   226         if (readable && _iface) {
   227             if (get_bitwidth() <= 16) {
   228                 _soft_copy =
static_cast<reg_data_t
>(_iface->peek16(_rd_addr));
   229             }
   230                 _soft_copy =
>(_iface->peek32(_rd_addr));
   231             }
   232                 _soft_copy =
>(_iface->peek64(_rd_addr));
   236             _soft_copy.mark_clean();
   265         static const size_t BITS_IN_BYTE = 8;
   266         return sizeof(reg_data_t) * BITS_IN_BYTE;
   297 template<
bool readable,
bool writable>
   300     typedef boost::shared_ptr< soft_register_sync_t<reg_data_t, readable, writable> >
sptr;
   306         soft_register_t<reg_data_t, readable, writable>(wr_addr, rd_addr, mode), _mutex()
   317         boost::lock_guard<boost::mutex> lock(_mutex);
   321     UHD_INLINE void set(
   323         boost::lock_guard<boost::mutex> lock(_mutex);
   329         boost::lock_guard<boost::mutex> lock(_mutex);
   335         boost::lock_guard<boost::mutex> lock(_mutex);
   341         boost::lock_guard<boost::mutex> lock(_mutex);
   347         boost::lock_guard<boost::mutex> lock(_mutex);
   353         boost::lock_guard<boost::mutex> lock(_mutex);
   437     typedef boost::shared_ptr<soft_regmap_accessor_t>
sptr;
   441     virtual std::vector<std::string> enumerate()
const = 0;
   442     virtual const std::string& get_name()
const = 0;
   472         boost::lock_guard<boost::mutex> lock(_mutex);
   484         boost::lock_guard<boost::mutex> lock(_mutex);
   496         boost::lock_guard<boost::mutex> lock(_mutex);
   507         regmap_t::const_iterator iter = _regmap.find(name);
   508         if (iter != _regmap.end()) {
   509             return *(iter->second);
   520         std::vector<std::string> temp;
   521         BOOST_FOREACH(
const regmap_t::value_type& reg, _regmap) {
   522             temp.push_back(_name +
"/" + reg.first);
   537         boost::lock_guard<boost::mutex> lock(_mutex);
   538         if (visible == PUBLIC) {
   540             if (not _regmap.insert(regmap_t::value_type(name, ®)).second) {
   544         _reglist.push_back(®);
   548     typedef boost::unordered_map<std::string, soft_register_base*> regmap_t;
   549     typedef std::list<soft_register_base*>                         reglist_t;
   551     const std::string   _name;
   566     typedef boost::shared_ptr<soft_regmap_db_t>
sptr;
   581     const std::string&
get_name()
 const {
return _name; }
   587         boost::lock_guard<boost::mutex> lock(_mutex);
   588         _regmaps.push_back(®map);
   595         boost::lock_guard<boost::mutex> lock(_mutex);
   599             _regmap_dbs.push_back(&db);
   616         std::list<std::string> tokens;
   618             const std::string& node,
   619             boost::tokenizer< boost::char_separator<char> >(path, boost::char_separator<char>(
   621             tokens.push_back(node);
   623         if ((tokens.size() > 2 && tokens.front() == _name) ||
   624             (tokens.size() > 1 && _name ==
   625             if (_name !=
"") tokens.pop_front();
   626             if (tokens.size() == 2) {
   628                     if (regmap->
get_name() == tokens.front()) {
   629                         return regmap->
lookup(tokens.back());
   633             }
else if (not _regmap_dbs.empty()) {
   636                 BOOST_FOREACH(
const std::string& node, tokens) {
   637                     newpath += (
"/" + node);
   642                         return db->
lookup(newpath.substr(1));
   643                     }
catch (std::exception&) {
   656         std::vector<std::string> paths;
   658             const std::vector<std::string>& regs = regmap->
enumerate();
   659             paths.insert(paths.end(), regs.begin(), regs.end());
   662             const std::vector<std::string>& regs = db->
enumerate();
   663             paths.insert(paths.end(), regs.begin(), regs.end());
   669     typedef std::list<soft_regmap_accessor_t*> db_t;
   671     const std::string   _name;
 void refresh()
Definition: soft_register.hpp:495
soft_register_sync_t< uint16_t, false, true > soft_reg16_wo_sync_t
Definition: soft_register.hpp:377
uint32_t soft_reg_field_t
Definition: soft_register.hpp:75
UHD_INLINE void flush()
Definition: soft_register.hpp:198
Definition: soft_register.hpp:126
soft_reg_flush_mode_t
boost::shared_ptr< soft_register_t< reg_data_t, readable, writable > > sptr
Definition: soft_register.hpp:136
Definition: soft_register.hpp:298
Definition: exception.hpp:145
soft_regmap_t(const std::string &name)
Definition: soft_register.hpp:457
UHD_INLINE bool unlikely(bool expr)
hint for the branch prediction
Definition: soft_register.hpp:59
UHD_INLINE void refresh()
Definition: soft_register.hpp:224
soft_register_t< uint64_t, false, true > soft_reg64_wo_t
Definition: soft_register.hpp:388
virtual std::vector< std::string > enumerate() const
Definition: soft_register.hpp:519
soft_register_t(wb_iface::wb_addr_type addr, soft_reg_flush_mode_t mode=ALWAYS_FLUSH)
Definition: soft_register.hpp:155
Definition: soft_register.hpp:41
soft_register_t< uint32_t, true, false > soft_reg32_ro_t
Definition: soft_register.hpp:382
UHD_INLINE size_t get_bitwidth()
Definition: soft_register.hpp:263
virtual soft_register_base & lookup(const std::string &name) const
Definition: soft_register.hpp:506
soft_register_sync_t(wb_iface::wb_addr_type addr, soft_reg_flush_mode_t mode=ALWAYS_FLUSH)
Definition: soft_register.hpp:309
UHD_INLINE bool is_writable()
Definition: soft_register.hpp:280
soft_register_sync_t< uint64_t, true, true > soft_reg64_rw_sync_t
Definition: soft_register.hpp:393
Definition: exception.hpp:125
Definition: soft_register.hpp:564
Definition: soft_register.hpp:655
soft_register_sync_t< uint32_t, false, true > soft_reg32_wo_sync_t
Definition: soft_register.hpp:384
soft_register_t< uint32_t, false, true > soft_reg32_wo_t
Definition: soft_register.hpp:381
UHD_INLINE size_t width(const soft_reg_field_t field)
Definition: soft_register.hpp:78
Definition: soft_register.hpp:529
UHD_INLINE void set(const soft_reg_field_t field, const reg_data_t value)
Definition: soft_register.hpp:180
soft_regmap_db_t(const std::string &name)
Definition: soft_register.hpp:576
virtual ~soft_regmap_accessor_t()
Definition: soft_register.hpp:439
Definition: soft_register.hpp:134
UHD_INLINE reg_data_t get(const soft_reg_field_t field)
Definition: soft_register.hpp:190
Definition: build_info.hpp:14
soft_regmap_db_t()
Definition: soft_register.hpp:571
UHD_INLINE void write(const soft_reg_field_t field, const reg_data_t value)
Definition: soft_register.hpp:345
virtual std::vector< std::string > enumerate() const =0
virtual soft_register_base & lookup(const std::string &path) const =0
virtual ~soft_register_base()
Definition: soft_register.hpp:103
void flush()
Definition: soft_register.hpp:483
visibility_t
Definition: soft_register.hpp:528
UHD_INLINE void initialize(wb_iface &iface, bool sync=false)
Definition: soft_register.hpp:166
boost::shared_ptr< soft_register_sync_t< reg_data_t, readable, writable > > sptr
Definition: soft_register.hpp:300
Definition: soft_register.hpp:471
virtual const std::string & get_name() const =0
soft_register_sync_t< uint64_t, true, false > soft_reg64_ro_sync_t
Definition: soft_register.hpp:392
virtual ~soft_regmap_t()
Definition: soft_register.hpp:458
soft_register_sync_t(wb_iface::wb_addr_type wr_addr, wb_iface::wb_addr_type rd_addr, soft_reg_flush_mode_t mode=ALWAYS_FLUSH)
Definition: soft_register.hpp:302
boost::shared_ptr< soft_regmap_accessor_t > sptr
Definition: soft_register.hpp:437
Definition: soft_register.hpp:435
UHD_INLINE bool is_readable()
Definition: soft_register.hpp:272
#define UHD_INLINE
Definition: config.h:53
Definition: soft_register.hpp:333
UHD_INLINE reg_data_t read(const soft_reg_field_t field)
Definition: soft_register.hpp:254
soft_register_t(wb_iface::wb_addr_type wr_addr, wb_iface::wb_addr_type rd_addr, soft_reg_flush_mode_t mode=ALWAYS_FLUSH)
Definition: soft_register.hpp:144
soft_register_t< uint64_t, true, false > soft_reg64_ro_t
Definition: soft_register.hpp:389
boost::shared_ptr< soft_regmap_db_t > sptr
Definition: soft_register.hpp:566
Definition: soft_register.hpp:455
Definition: soft_register.hpp:101
soft_register_sync_t< uint32_t, true, false > soft_reg32_ro_sync_t
Definition: soft_register.hpp:385
Definition: exception.hpp:48
Definition: config.h:68
Definition: soft_register.hpp:87
void add(soft_regmap_t ®map)
Definition: soft_register.hpp:586
Definition: soft_register.hpp:351
Definition: soft_register.hpp:581
Definition: soft_register.hpp:339
soft_register_t< uint64_t, true, true > soft_reg64_rw_t
Definition: soft_register.hpp:390
Definition: soft_register.hpp:245
soft_register_t< uint16_t, true, true > soft_reg16_rw_t
Definition: soft_register.hpp:376
Definition: exception.hpp:92
void add(soft_regmap_db_t &db)
Definition: soft_register.hpp:594
virtual void initialize(wb_iface &iface, bool sync=false)=0
Definition: soft_register.hpp:613
soft_register_sync_t< uint16_t, true, true > soft_reg16_rw_sync_t
Definition: soft_register.hpp:379
soft_register_sync_t< uint64_t, false, true > soft_reg64_wo_sync_t
Definition: soft_register.hpp:391
Definition: soft_register.hpp:315
soft_register_t< uint16_t, false, true > soft_reg16_wo_t
Definition: soft_register.hpp:374
UHD_INLINE bool likely(bool expr)
soft_register_sync_t< uint32_t, true, true > soft_reg32_rw_sync_t
Definition: soft_register.hpp:386
virtual UHD_INLINE const std::string & get_name() const
Definition: soft_register.hpp:463
UHD_INLINE void add_to_map(soft_register_base ®, const std::string &name, const visibility_t visible=PRIVATE)
Definition: soft_register.hpp:536
UHD_INLINE size_t shift(const soft_reg_field_t field)
Definition: soft_register.hpp:82
uint32_t wb_addr_type
Definition: wb_iface.hpp:23
static UHD_INLINE soft_reg_t & cast(soft_register_base ®)
Definition: soft_register.hpp:116
Definition: wb_iface.hpp:19
soft_register_t< uint16_t, true, false > soft_reg16_ro_t
Definition: soft_register.hpp:375
soft_register_sync_t< uint16_t, true, false > soft_reg16_ro_sync_t
Definition: soft_register.hpp:378
soft_register_t< uint32_t, true, true > soft_reg32_rw_t
Definition: soft_register.hpp:383
