convert.hpp
2 // Copyright 2011-2012,2014 Ettus Research LLC
4 //
6 //
7
8 #ifndef INCLUDED_UHD_CONVERT_HPP
9 #define INCLUDED_UHD_CONVERT_HPP
10
11 #include <uhd/config.hpp>
12 #include <uhd/types/ref_vector.hpp>
13 #include <boost/function.hpp>
14 #include <boost/operators.hpp>
15 #include <boost/shared_ptr.hpp>
16 #include <string>
18 namespace uhd { namespace convert {
19
21 class converter
22 {
23 public:
24  typedef boost::shared_ptr<converter> sptr;
27
28  virtual ~converter(void) = 0;
29
31  virtual void set_scalar(const double) = 0;
32
34  UHD_INLINE void conv(const input_type& in, const output_type& out, const size_t num)
35  {
36  if (num != 0)
37  (*this)(in, out, num);
38  }
39
40 private:
42  //
43  // This is the guts of the converter. When deriving new converter types,
44  // this is where the actual conversion routines go.
45  //
46  // \param in Pointers to the input buffers
47  // \param out Pointers to the output buffers
48  // \param num Number of items in the input buffers to convert
49  virtual void operator()(
50  const input_type& in, const output_type& out, const size_t num) = 0;
51 };
52
54 typedef boost::function<converter::sptr(void)> function_type;
55
57 typedef int priority_type;
58
60 struct UHD_API id_type : boost::equality_comparable<id_type>
61 {
62  std::string input_format;
63  size_t num_inputs;
64  std::string output_format;
65  size_t num_outputs;
66  std::string to_pp_string(void) const;
67  std::string to_string(void) const;
68 };
69
71 UHD_API bool operator==(const id_type&, const id_type&);
72
83  const id_type& id, const function_type& fcn, const priority_type prio);
84
91 UHD_API function_type get_converter(const id_type& id, const priority_type prio = -1);
92
98 UHD_API void register_bytes_per_item(const std::string& format, const size_t size);
99
101 UHD_API size_t get_bytes_per_item(const std::string& format);
102
103 }} // namespace uhd::convert
104
105 #endif /* INCLUDED_UHD_CONVERT_HPP */
UHD_API function_type get_converter(const id_type &id, const priority_type prio=-1)
Identify a conversion routine in the registry.
Definition: convert.hpp:60
UHD_API void register_bytes_per_item(const std::string &format, const size_t size)
boost::function< converter::sptr(void)> function_type
Conversion factory function typedef.
Definition: convert.hpp:54
virtual void set_scalar(const double)=0
Set the scale factor (used in floating point conversions)
UHD_API size_t get_bytes_per_item(const std::string &format)
Convert an item format to a size in bytes.
UHD_API bool operator==(const id_type &, const id_type &)
A conversion class that implements a conversion from inputs -> outputs.
Definition: convert.hpp:21
Definition: convert.hpp:64
Definition: build_info.hpp:13
UHD_INLINE void conv(const input_type &in, const output_type &out, const size_t num)
The public conversion method to convert inputs -> outputs.
Definition: convert.hpp:34
Definition: ref_vector.hpp:21
uhd::ref_vector< const void * > input_type
Definition: convert.hpp:26
#define UHD_INLINE
Definition: config.h:53
int priority_type
Priority of conversion routines.
Definition: convert.hpp:57
virtual ~converter(void)=0
Definition: config.h:68
size_t num_inputs
Definition: convert.hpp:63
UHD_API void register_converter(const id_type &id, const function_type &fcn, const priority_type prio)
uhd::ref_vector< void * > output_type
Definition: convert.hpp:25
size_t num_outputs
Definition: convert.hpp:65
boost::shared_ptr< converter > sptr
Definition: convert.hpp:24
Definition: convert.hpp:62
