dboard_eeprom.h
4 //
6 //
7
8 #ifndef INCLUDED_UHD_USRP_DBOARD_EEPROM_H
9 #define INCLUDED_UHD_USRP_DBOARD_EEPROM_H
10
11 #include <uhd/config.h>
12 #include <uhd/error.h>
13
14 #ifdef __cplusplus
16 #include <string>
18 struct uhd_dboard_eeprom_t {
19  uhd::usrp::dboard_eeprom_t dboard_eeprom_cpp;
20  std::string last_error;
21 };
22
23 extern "C" {
24 #else
25 struct uhd_dboard_eeprom_t;
26 #endif
27
29
35 typedef struct uhd_dboard_eeprom_t* uhd_dboard_eeprom_handle;
36
39  uhd_dboard_eeprom_handle* h
40 );
41
43
48  uhd_dboard_eeprom_handle* h
49 );
50
53  uhd_dboard_eeprom_handle h,
54  char* id_out,
55  size_t strbuffer_len
56 );
57
60  uhd_dboard_eeprom_handle h,
61  const char* id
62 );
63
66  uhd_dboard_eeprom_handle h,
67  char* serial_out,
68  size_t strbuffer_len
69 );
70
73  uhd_dboard_eeprom_handle h,
74  const char* serial
75 );
76
83  uhd_dboard_eeprom_handle h,
84  int* revision_out
85 );
86
89  uhd_dboard_eeprom_handle h,
90  int revision
91 );
92
95  uhd_dboard_eeprom_handle h,
96  char* error_out,
97  size_t strbuffer_len
98 );
99
100 #ifdef __cplusplus
101 }
102 #endif
103
104 #endif /* INCLUDED_UHD_USRP_DBOARD_EEPROM_H */
UHD_API uhd_error uhd_dboard_eeprom_free(uhd_dboard_eeprom_handle *h)
Safely destroy the given handle.
UHD_API uhd_error uhd_dboard_eeprom_get_serial(uhd_dboard_eeprom_handle h, char *serial_out, size_t strbuffer_len)
Get the daughterboard&#39;s serial.
UHD_API uhd_error uhd_dboard_eeprom_set_revision(uhd_dboard_eeprom_handle h, int revision)
Set the daughterboard&#39;s revision.
uhd_error
UHD error codes.
Definition: error.h:21
UHD_API uhd_error uhd_dboard_eeprom_get_id(uhd_dboard_eeprom_handle h, char *id_out, size_t strbuffer_len)
Get the ID associated with the given daughterboard as a string hex representation.
struct uhd_dboard_eeprom_t * uhd_dboard_eeprom_handle
A C-level interface for interacting with a daughterboard EEPROM.
Definition: dboard_eeprom.h:35
Definition: dboard_eeprom.hpp:18
UHD_API uhd_error uhd_dboard_eeprom_get_revision(uhd_dboard_eeprom_handle h, int *revision_out)
UHD_API uhd_error uhd_dboard_eeprom_set_serial(uhd_dboard_eeprom_handle h, const char *serial)
Set the daughterboard&#39;s serial.
UHD_API uhd_error uhd_dboard_eeprom_make(uhd_dboard_eeprom_handle *h)
Create handle for a USRP daughterboard EEPROM.
Definition: config.h:68
UHD_API uhd_error uhd_dboard_eeprom_set_id(uhd_dboard_eeprom_handle h, const char *id)
Set the daughterboard ID using a string hex representation.
UHD_API uhd_error uhd_dboard_eeprom_last_error(uhd_dboard_eeprom_handle h, char *error_out, size_t strbuffer_len)
Get the last error reported by the handle.
