Macros to do boilerplate testbench initialization and utilities to define test cases
// Initializes state for a test bench. // This macro *must be* called within the testbench module but // outside the primary initial block // Its sets up boilerplate code for: // - Logging to console // - Test execution tracking // - Gathering test results // - Bounding execution time based on the SIM_RUNTIME_US vdef // // Usage: `TEST_BENCH_INIT(test_name,min_tc_run_count,ns_per_tick) // where // - tb_name: Name of the testbench. (Only used during reporting) // - min_tc_run_count: Number of test cases in testbench. (Used to detect stalls and inf-loops) // - ns_per_tick: The time_unit_base from the timescale declaration //
// Indicates the start of a test case // This macro *must be* called inside the primary initial block // // Usage: `TEST_CASE_START(test_name) // where // - test_name: The name of the test. //
// Indicates the end of a test case // This macro must be called inside the primary initial block // The pass/fail status of test case is determined based on the // the user specified outcome and the number of fatal or error // ASSERTs triggered in the test case. // // Usage: `TEST_CASE_DONE(test_result) // where // - test_result: User specified outcome //
// Wrapper around a an assert. // ASSERT_FATAL throws an error assertion and halts the simulator // if cond is not satisfied // // Usage: `ASSERT_FATAL(cond,msg) // where // - cond: Condition for the assert // - msg: Message for the assert //
// Wrapper around a an assert. // ASSERT_ERROR throws an error assertion and fails the test case // if cond is not satisfied. The simulator will *not* halt // // Usage: `ASSERT_ERROR(cond,msg) // where // - cond: Condition for the assert // - msg: Message for the assert //
// Wrapper around a an assert. // ASSERT_WARNING throws an warning assertion but does not fail the // test case if cond is not satisfied. The simulator will *not* halt // // Usage: `ASSERT_WARNING(cond,msg) // where // - cond: Condition for the assert // - msg: Message for the assert //
Shortcut macros to create typical clock and reset signals.
// Generates a persistent clock that starts at t=0 and runs forever // // Usage: `DEFINE_CLK(clk_name,period,duty_cycle) // where // - clk_name: The clock net to be generated // - period: Period of the clock in simulator ticks // - duty_cycle: Percentage duty cycle //
// Generates a clock that starts at the specified time and runs forever // // Usage: `DEFINE_LATE_START_CLK(clk_name,period,duty_cycle,start_time,start_time_res) // where // - clk_name: The clock net to be generated // - period: Period of the clock in simulator ticks // - duty_cycle: Percentage duty cycle // - start_time: Start time for clock in simulator ticks // - start_time_res: Start time resolution (must be > timescale increment and < start_time) //
// Generates an active high reset // // Usage: `DEFINE_RESET(reset_name,reset_time,reset_duration) // where // - reset_name: The reset net to be generated // - reset_time: Time at which reset will be asserted (i.e. rst=1) // - reset_duration: Duration of reset assertion //
// Generates an active low reset // // Usage: `DEFINE_RESET_N(reset_name,reset_time,reset_duration) // where // - reset_name: The reset net to be generated // - reset_time: Time at which reset will be asserted (i.e. rst=0) // - reset_duration: Duration of reset assertion //
Defines a data_file_t interface with the following functions:
// Create a handle to a data_file with // - FILENAME: Name of the file // - FORMAT: Data format (HEX, DEC, OCT, BIN, FLOAT) // - DWIDTH: Width of each element stored in the file (one line per word) //
// Open the data file for reading or writing. // // Usage: open(mode) // where // - mode: RW mode (Choose from: READ, WRITE, APPEND) //
// Close an open data file. No-op if file isn't already open // // Usage: close() //
// Is end-of-file reached. // // Usage: is_eof() Returns eof // where // - eof: A boolean //
// Read a line from the datafile // // Usage: readline() Returns data // where // - data: A logic array of width DWIDTH containing the read word //
// Write a line to the datafile // // Usage: writeline(data) // where // - data: A logic array of width DWIDTH to write to the file //
